06-18-2011, 12:06 AM
Real Name: Manolo Rodriguez
Differential Fluid
So, my mom called me telling me that her 99 4runner was shifting hard when switching from park to reverse and drive. I checked the differential and has a major leak. To top it off, The filler plug is completly stripped. Tomorrow i'm heading to the stealership and pick up the filler plug and two crush washers. Now, what gear oil should i use? I'm going to get conventional but don't know what weight to get. Should i get 75-90 or go thicker? 4runner has 189k miles
Reason: Forgot the mileage
06-18-2011, 12:59 AM
. -Kenny- (formerly icantsee) .
• **SOLD** 2007 Toyota 4Runner V6 SR5 4WD - Titanium Metallic
Daystar Spacer Lift 2.5/1.5 (Preload/Topout)|P265/70R17 Bridgestone Dueler A/T Revos|XenonDepot H11 4300k Xtreme HID Kit|Weathertech Floor & Cargo Liners|Rear Axle Diff Breather Extension|Color Matching Grill|Debadged Emblems|FatCat6|Soon/Wishlist|CB Radio|BL 1"|Demello Bolt On Sliders|Icons or Radflo|BajaRack or Rola Rack
06-18-2011, 03:22 AM
Originally Posted by Singtoe
If you want to keep your diffs alive, don't run synthetic...
What's your rationale for that?
I've run Synthetic (Mobil 1 or Redline) in every diff I've owned or worked on for twenty years. No excess wear issues, or leaks with any of them.
06-18-2011, 03:55 AM
Sorry guys. Just had time to check the thread. My mom told me she's looking into a 02 4runner right now. So i'm thinking of going conventional. Just wondering what weight. I too have a 99 4runner. Same color same model but with 155k miles. Im thinking of switching my trans, diff, and motor to synthetic. Just want to do a quick fix on my moms. The leak is actually on the filler plug.
06-18-2011, 08:16 AM
There is no rationale for that, synthetic is far superior in every way.
If anything you would have less leaks and certainly less wear.
2002 3.4L 4X4 Sport Edition
06-18-2011, 08:19 AM
For what you are doing Singtoe is correct the 85W 140 would work very well for that purpose.
But definitely change the fluids on yours to full synthetic though.
06-18-2011, 09:22 AM
Alright, cool guys. So when it's time to drain and fill my differential, with no leaks, what weight of synthetic should i use and how many quarts does it take?
06-18-2011, 10:18 AM
I'm curious why nobody has mentioned that your issue of hard shifting has nothing to do with the differential?? You need to check the transmission fluid and change THAT.
2001 SR5~Thundercloud Metallic~3.4L Auto~4x4~260k miles~TRD 2gen black Supercharger~URD AFR Calibrator~B&M 70264~Bilstein Adjustable w/ tall '99 fronts~ProComp 3" rear springs~Nitto Ridge Grappler 285/70R17's on 17x9 Enduro's~Yakima RailRider w/48" bars~ScanGauge II
06-18-2011, 10:27 AM
Also grease the zerk fittings on the driveshaft, sometimes those joints get sloppy with no grease in them and can cause it to shift hard from park to drive and reverse.
1985 4runner 22re solid axle 5 speed 5.29's
1996 4runner Limited E-Locker, Boosted, OME, KM2's, 4x Sliders, ARB Prado Bar, Warn M8000
06-18-2011, 12:09 PM
That post has all the information you need for amount required and torque. I run Mobil1 in my vehicle. However, I have seen a few post about Redline. But, it's not available locally so I didn't purchase it. Maybe I will later.
2000 4Runner SR5 | 5 speed | 4x4 | URD Short throw Shifter | Sonoran Steel 1.2 | 231mm Tundra Brakes | 4.30 E-Locker | 2nd Gen Supercharger | URD 7th Injector kit | 1.25" Spidertrax | FJ Wheels | 265/70/17 Terra Grapplers.
06-18-2011, 01:04 PM
Cool. I'm off to the dealership. I'll check the tranny fluid too. Hopefully nothing expensive repairs are not in my future. Wish me luck!
Unless you have a posi rear end I wouldn't waste the money on synthetic gear oil. If its that big a concern to you just change it more often. Chances are the fluid in your moms car has never been changed. Diff fluid is the most commonly ignored fluid. But rear ends are the longest lasting component of the drive train because they always have plenty of lubrication. I run conventional 85w-140, but its not that big a deal. Even my 38 Cadillac has an original rear end with conventional oil.
On my runner I changed it when I bought it at 113,000 miles. I now have 225,000 and haven't changed it yet.
2000 4Runner 2.7L (Practical/efficient)
1971 Buick Riviera 7.5L (Dream car!)
1965 Chevy short-bed stepside 5.7L (Hick truck)
1938 Cadillac V16 7.1L (WOW)
2006 Dodge Magnum R/T (My 4runner replacement)
06-18-2011, 01:25 PM
Thank Tomsriv.
