What sort of tools/space do you have?
The rear axle seal replacement is SUPER easy. I mean, after you've done the first side, the 2nd side will take probably 30 minutes.
For each side all you need to do:
1- Take off wheel
2- Undo brake line (get a brake line stopper that threads on to the flare nut)
3 - Take cotter pin off for e-brake cable
4- Undo 4 nuts on back of drum
5 - Slide axle out
6 - Take pliers and pull the old seal out
7 - Pound in new seal using a seal seating tool, or make your own like I did. (Buy the seal, and bring it to a hardware shop, and match the inner and outer diameters of the seal with the washers.
