07-05-2011, 03:23 PM
Real Name: Jeff
Real Name: Jeff
Belt Squealing
Just curious , how many of you have a fan belt that squeals every time you start your Runner ( for 5 or 6 seconds ) ? I tried that belt dressing , works for a while . I know it's kind of a lame question and I'm just trying to see how normal it is before wondering if my water pump may be stiff in the morning ? The belt appears to look in decent shape but it is a few years old . Do you have a squealer ?
Thanks All !
98 3.4L 4x4 Auto LTD
1998 4Runner 4WD Ltd
07-05-2011, 06:11 PM
My A/C compressor belt squeals when the engine is cold. But my belts need to be replaced.
1999 4Runner SR5 3.4L, 6000K HIDS, 2 12" JVC Subs w/ 460W amp, Sport skid plate, OEM fog lights, Rola roof rack w/ extension.
Sitting in my room: B&M 70268
Many mods yet to come
07-05-2011, 06:13 PM
Real Name: Jeff
Real Name: Jeff
Maybe it is my AC belt .
07-05-2011, 06:25 PM
Next time you start it and it squeals, quickly turn off your A/C and see if it stops. Thats how I figured out which one mine was.
07-05-2011, 06:52 PM
No belt dressing on the belts please. You are asking for nothing but more problems.
If they squeal, change them, all three that is.
07-05-2011, 07:35 PM
Real Name: Jeff
Real Name: Jeff
Ha ya , first time I ever bought a can of that stuff , right before a long trip and it was a band-aid approach . New belts a comin'
07-05-2011, 08:47 PM
Your belts are probably a little loose. Tighten them down a bit first before replacing.
96 Limited Evergreen Metallic
Nitto Terra Grapplers LT 265/75 R 16, Ironman springs front, OME 890 rear, OME Nitrocharger shocks,
Alpine cda117, morel tempo components,
HID projector retrofit; led interior lights
Coming soon: Custom skids, tranny cooler, subs (?)...
07-06-2011, 06:22 AM
There you go. As Little Caesar said, that stuff is crap. I learned the hard way. Make sure you clean the pulleys off as well before you put the new belts on.
2001 SR5 4X4, V6, 3.4L
07-06-2011, 09:20 AM
WD-40 works great on Belts and also preserves them. That's all I have used for years. It dries and doesn't hold/attract dirt like the sticky belt dressing.
I have never had a broken belt or any problems from the WD-40.
Also, check you Power steering fluid level.
2002 SR5 4x4, Dorado Gold
Suspension:Front:Toytec Coilovers w/ 5100 Bilsteins/RevTek Diff Drop, 231mm Tundra Brake upgrade. Rear: ToyTec Superflex coils/5100 Bilsteins.
Tires: 285/75/16 Bridgestone REVO 2's
The Rest:I.S.R. Mod upgraded to an Injen intake, Borla XR-1 muffler, ARB Bumper, Shrockwork's Rock Sliders, CBI Rear Bumper and a pair of Hellas. Plus a whole bunch of other accessories.Topped off with Zaino's Polish.
07-15-2011, 07:15 AM
belt squealing
Mine does the same thing in the morning but my A/C isn't on. Any other belts I should check/replace?
07-15-2011, 08:41 AM
Real Name: Robert
Real Name: Robert
WD-40? Are you joking?
1999 Toyota 4Runner Limited 4x4 - Turbocharged Garrett 57-trim T3/T4 - URD AFR Sensor Calibrator - DW255 fuel pump - 7MGE Supra 315cc “lime green” fuel injectors - 231mm Tundra Brakes - B&M 70264 Transmission Cooler - Monitoring ATF Temps and AFRs With My iPhone - DIY Projector Headlight Retrofit - Cooper Discoverer AT3 - OME 906 Coils & Rancho 9000XL Shocks (Rear) - Airlift 1000 - RadioShack $5 Rear O2 Simulator
2000 Yamaha XR1800 Jet Boat - MR1 4-Stroke Engine Swap
07-15-2011, 08:54 AM
Nope, I've been using it since the 80's. My belts never wear out, crack, break or squeal.
The WD soaks into the belts and preserves them and does not attract dirt like the traditional sticky belt dressing.
I have 95,000 miles on my current belts and they still look brand new.
07-15-2011, 09:52 AM
I figured the WD-40 contributed to my belts needing replaced. I think I wrecked them with a degreaser, tried to fix them with belt dressing, and then tried to get rid of the squeak with WD-40. They turned into messy ****. They were under a year old. The only fix was removing them, cleaning the pulleys, and putting new ones on.
The WD-40 is petroleum based, and I'm not sure if the belts have natural rubber.
Anyway, an evolution of squeaks is now nice dry beautiful belts that don't squeal if I try.
07-15-2011, 12:51 PM
My belts squeak sometimes, but that's only after it rains. They can get a little wet since I have the sport scoop.
2001 4Runner 4WD Sport Package, Millennium silver, 110,000 miles, 2nd gen TRD Supercharger, Toytec BOSS coilovers, 890 OME rear springs, Bilstein 5125 rear shocks, custom Baldlands front bumper, PIAA 520 driving lights and fogs, 4x Innovation Sliders (welded on!), 18" Magnaflow muffler, JDM corners, 65" Thule bars, 20% tint, 16x8 FJ80 wheels on 265/75-16 Duratracs, Husky mats w/ cargo, rear diff breather mod, 3M clear bra, remote start, Pioneer AVIC-8200NEX
07-15-2011, 03:42 PM
Real Name: Robert
Real Name: Robert
Adding a lubricant to the drive belts just seems like a bad idea. Do you also smear some lithium grease onto your rotors to keep the breaks from squealing?
