12-27-2011, 12:25 AM
#271
I'd probably go with the cheaper option. You currently have an OEM upgrade going on with the V8 swap....I'd just go with an OEM style radiator.....jut my 2 cents..
1998 4Runner SR5, ISR and Deckplate Mods, Painted Intake Manifold, TRD Tundra Struts, Diff Drop, LC 8 Wraps w/ Skyjacker shocks, Panhard Drop Bracket, Rear Tire Carrier, Maxxis Bighorns, Procomp Wheels, Custom Front Valance, Sport Edition Skidplate, Upgraded Exterior lighting
12-30-2011, 01:04 PM
#272
Real Name: Connor
Real Name: Connor
What did you end up going with?
12-30-2011, 08:26 PM
#273
I ended up going with the Aluminum 3 row. I read that aluminum was more efficient then brass. It was the perfect size for the body, the outlets were oriented on the correct sides and it was fairly inexpensive.
I went ahead and ordered a cold air intake too. I haven't received anything yet.
Since nobody makes a kit for my application, I will be making my own.
Will post some more pics as it gets here.
1999 Limited 4runner in Silver - 9th and 10th Injected TRD Supercharged 4.7 2UZ-FE swap - AISIN Manual hub lockers - Retrofitted E-locker - Downey Off road Coilovers & adjustable Pan Hard Bar - Whelen PA - 2" Personally made Body Lift - Eclipse Navigation Radio - Spider Trax - Custom Hidden Winch - Triple Electric Fans - Running boards off then back on again - Ghetto Cold Air Intake - Sequoia Brakes - V8 Badge (for extra horse power)
2002 SR5 Tacoma Extended Cab also in Silver On 37's and Guns for sale
01-02-2012, 07:35 PM
#274
Still Waiting for parts to come in. So I made my Front bumper relocation brackets.
My lift is officially done, with the exception of lifting the trailer hitch up.
I guess i went overboard on my bracket material. 1/4" plate but it was free.
It is what it is.
My bumper is mounted.
01-02-2012, 07:46 PM
#275
Looks good.
01-02-2012, 08:08 PM
#276
Real Name: Connor
Real Name: Connor
Dang that thing is riding tall!
01-02-2012, 08:35 PM
#277
At 5'7", I'd need a rocket up the wazoo to get in it.
But it looks good. I can't wait to see it being driven.
01-08-2012, 07:02 PM
#279
Looks awesome man!
01-08-2012, 07:06 PM
#280
Real Name: Sam
Real Name: Sam
Man, I'm so pumped to see what thats going to look like when everything is done. Sweet! I wish I had that kind of know-how. Unfortunately, trucks aren't my specialty (although I do love them) because I'm a musician... Looks great, keep up the good work.
2002 4runner Sport Edition SR5 2wd
Kenwood headunit/6" bazooka sub, Scangauge II, DRL disable, running boards delete
Originally Posted by t4r4life
It's a custom battery holder bro, anything custom adds 20hp. it's in the rule book of BRAAAPPPP!!!!
01-08-2012, 07:20 PM
#281
That is one tight fit.
01-08-2012, 07:26 PM
#282
Real Name: Connor
Real Name: Connor
Do you need anything more before it's done done?
01-08-2012, 07:54 PM
#283
Stuff still needed.
Slim electric puller fan
Shorten Drive Shaft
Punch list to do.
Hook up e-brake
Install and hook up EVAP canister
Splice Low side AC line - V8 to 4runner evaporator
Need to move fuel filter away from Cat
Need to Wire
Body to ECM
Body to Motor
Fuel Pump Resister
electric fans
Cruise control to ECM
Instrument cluster to body
Instrument cluster to ECM
Transponder key
transfercase to 4runner's 4x4 ECU
Evap
01-09-2012, 04:13 AM
#284
I saw where another V8 conversion (for a Tacoma though), the owner removed the AC condenser and moved the radiator forward a couple of inches.
Unfortunately, I need my AC so it is what it is.
01-09-2012, 04:17 AM
#285
Making my Air intake.
After the disappointment with the Ebay air intake, I forged on and decided to use it.
I could not fit the Sequoia Intake assemble in the stock location because it is just to big. The 4Runner Air cleaner assemble had the intake coming in at the wrong angle. Just not enough room to manipulate the intake hose from the engine to the housing.
I could have just stuck a filter on the end of the MAF sensor but that would look to ricey (as if my radiator wasn't ricey enough).
Anywho, This what i did.
I took the stock Sequoia Air filter box
And I cut the MAF mounting point out.
Cut and trimmed the MAF
Up Close
Used the crappy kit from Ebay
Attached it to the MAF
Installed into 4runner
So now my 2UZ-FE is getting cool air from outside.
