This should help, Different tcase actuator depending on year, but should be similar, I don't think the gear position matters if both the actuator and tcase are in the same 2wd position, there might be index marks on the gear, or maybe the spines of the gear only engage in 1 position, but I'm unsure.
https://www.youtube.com/watch?v=kdh8tlxfgnU&feature=youtu.be
