Old 07-25-2011, 06:27 PM #1
Dara Dara is offline
Dara is on a distinguished road
Changin out a multimode 4wd t-case
Hey guys
Quick question about changin out my multi mode 4wd transfer box
ill be changin mine pretty soon as im havin alot of trouble wit 4wd engaging
and i got a good deal on one that i know is workin 100% perfect
Iv never done a t-case in a truck before but iv done hundreds of gearboxes in cars etc...wat im wonderin is there anythin i need to look out for wen pullin the t-case off the back of the gearbox??seals or gaskets or anythin like that?
also is there any seals or gaskets that NEED to be replaced while im changin it??
Thanks
Dara
Dara is offline   Reply With QuoteReply With Quote
Old 07-25-2011, 09:26 PM #2
zcruiser's Avatar
zcruiser zcruiser is offline
zcruiser has a spectacular aura about zcruiser has a spectacular aura about
zcruiser's Avatar
I've only looked at the SR5 transfer case, and it looked pretty straight-forward. Remove front/rear driveshafts (mark for reclocking) and drop off the tc.
Your local toyota parts guy should be able to tell you if there are any seals, or you can check the on-line T4R service manual.
FSM Zip File for Download (23.6 MB)
Post pics!
2012 4Runner Limited, Shoreline Blue Pearl / Beige leather, RCI skid, ext rear diff breather, Derale 13504 cooler, 110K
1993 300ZX Cherry Red Pearl with some bling, K&N intake, PowerTrix suspension, 130K
zcruiser is offline   Reply With QuoteReply With Quote
Old 07-25-2011, 09:44 PM #3
Bamf_CT2004
Guest
Posts: n/a
Bamf_CT2004
Guest
Posts: n/a
Check all your switches before you change it out. Chances are the tcase is not the problem
Old 07-26-2011, 06:03 AM #4
Post pics!
ya iv looked at mine too an it does look fairly straight forward but jus wanted to know was there anythin hidden between the tcase an gearbox i should know about before pullin it out.
i know its not the tcase thats the problem i know exactly wats the problem is it happens to all the hilux surfs with multimode through lack of 4wd use
but i got a good deal on the knew tcase an it should be jus easier to swap out than fix the prob on the old one
Old 07-26-2011, 06:19 PM #5
YotaZach85's Avatar
YotaZach85 YotaZach85 is offline
YotaZach85 is on a distinguished road
YotaZach85's Avatar
They use RTV form-a-gasket between the transmission and transfercase from the factory so you shouldn't need to get any new parts to complete the project.
1997 3.4l SR5 5spd 4WD E-locked. Blue wire mod, 99 tall springs, 32" Duratracs, Satoshi Grill, Tundra 231 brakes, 99 center console.
1988 3.0l 5spd Pickup SAS on 35s with 5.29's, welded 8.4 rear, custom flat bed, on board air, XRC8 winch, homemade sliders.
YotaZach85 is offline   Reply With QuoteReply With Quote
Old 07-26-2011, 06:28 PM #6
raidernation raidernation is offline
raidernation is on a distinguished road
So what is wrong with it?
raidernation is offline   Reply With QuoteReply With Quote
Old 07-27-2011, 06:06 AM #7
cool thanks..a health dose of rtv it will be gettin so
this part circled in red(dont know the proper name for it) is the problem the little gear wit the contact points inside an the selector bar that goes from it into the tcase...they get messed up if they're not used regularly seems to either get stuck in 2wd or 4wd or Awd(previous owner never used 4wd or Awd)...an most of the time wen you take the 3 bolt cover off to try sort it the gear falls out an if it doesnt go back in right you have no drive an i cant find any manuals or much info of any use on it so im changin the whole tcase
Old 01-23-2021, 09:53 PM #8
Yeetwagon Yeetwagon is offline
Yeetwagon is on a distinguished road
Does any one know if the bar inside the actuator is supposed to be in or out for 2wd also how to properly clock the gear in the actuator
Yeetwagon is offline   Reply With QuoteReply With Quote
Old 01-23-2021, 10:46 PM #9
Malcolm99's Avatar
Malcolm99 Malcolm99 is offline
Malcolm99 has a spectacular aura about Malcolm99 has a spectacular aura about
Malcolm99's Avatar
This should help, Different tcase actuator depending on year, but should be similar, I don't think the gear position matters if both the actuator and tcase are in the same 2wd position, there might be index marks on the gear, or maybe the spines of the gear only engage in 1 position, but I'm unsure.
https://www.youtube.com/watch?v=kdh8tlxfgnU&feature=youtu.be
Malcolm99 is offline   Reply With QuoteReply With Quote
T-case Differences (all years of 3rd gens).. transfer case, AWD, multi-mode brian2sun 3rd gen T4Rs 179 03-05-2024 09:06 AM
Is this possible? locker, trac, multimode? Carbon Blue 3rd gen T4Rs 7 08-21-2010 11:22 PM
Advance Adapters 50-5705 Transfer Case Adapter 700R-4 To A Toyota Transfer Case 21 To NMRunner Classifieds - buy & sell (no commercial ads please) 0 08-18-2010 11:42 PM
Transfer case DIVNWND 3rd gen T4Rs 3 02-03-2010 01:19 PM
key fob case neowig 3rd gen T4Rs 3 12-25-2009 01:49 PM
