07-27-2011, 01:35 PM
No OEM Roof Rack Rails - any direct mounting options?
My SR5 came with no OEM roof rack, just the plastic strip thingies where the rails would normally bolt onto. I have searched high and low to find an OEM rack setup or just the roof rails but these things are like gold dust. Wreckers don't have them, Toyota discontinued them, and when ever they're on eBay they seem to get snapped up mighty quick.
The deal is, I want to mount a basket and could have swore I saw a guy on here once work it so that he could use the existing 'holes' where the rails bolt into the roof to mount a basket directly. Anybody know about this or was I dreaming it? Could this actually be possible or not? Anybody tried?
Thoughts?
1999 SR5 3.4 V6 4WD | Desert Dune Metallic | Big City Weekdays & Back Country Camping Weekends
265/75/16 Goodyear Wranglers| Bilstein HD Shocks | OEM 'Tall' Springs | Hella 500s | Clear Corners & Signals | Cobra CB | Rust
07-27-2011, 01:40 PM
Thoughts?
Don't remember seeing that myself, but you should just troll the part outs here, on yotatech, and some of the other places. I am sure you could find a stock on eventually.
2000 SR5 3.4L V6 Automatic 4x4, e-locker, 175k Miles, Rust
Imp. Jade Mica with Oak Leather Interior, Field Monitor Unit - B&M Tranny Cooler - SG2 - New (to me) rear axle assembly - Goodyear Duratrac 265/75-16 - 1.8" Ironman Front Lift, OME 906/Procomp 9000 Shocks
http://www.toyota-4runner.org/3rd-ge...ld-thread.html
07-27-2011, 06:28 PM
Yeah, you're probably right. I'm on Kijiji and Craigslist everyday as well. Hopefully something will show up sooner or later!
07-27-2011, 08:14 PM
It hasn't been but a couple months that the local Toyota dealer told me that he could still get the factory roof rack as an "Accessory." My cost was going to be $199 or so, if I remember correctly. Lurk the wrecking yards.
07-27-2011, 08:35 PM
Thanks for the tip. I rarely do business with dealers except for the small stuff but since this has been a real task, I would be willing to part with $200.00 for a minty OEM rack setup. I'll call around my local guys. I called to ask them about OEM front mudflaps a month or so ago...$50.00...EACH! WTF? Haha!
07-30-2011, 05:38 PM
Well I did some hardcore hunting and discovered a guy about an 1 hr 20 mins away from me who has a boatload of 2nd Gen trucks and Runners plus parts as well as a couple of 3rd Gens plus parts in his yard. He dug me up a full mint OEM rack setup from an '02 Limited and I got it for what would equate to about $85.00 US today. Score! Just installed it with the help of my 11 year old daughter. She rocks and will also be assisting me with my spark plug change, MAF/throttle body clean on Monday.
Here we go...
07-30-2011, 10:30 PM
your lucky you have the plastic strips that cover the holes for the OEM stuff.
I dont even had that so I get to Drill and add my own strips and lots of sealant to prevent any leaks.
I got some Proline tracks that are longer than stock so I can move around my thule cross bars or even add a third down the road.
happy shopping.
SOLD- 00 5spd, rear locker, OME 882/890, CBI front bumper, rear swing away, sliders by CBI too, warn M8000, Lightning force 170's, 265/75/16, (on the list, roof rack) LC wheels (graphite), diff drop, http://www.toyota-4runner.org/3rd-ge...ld-thread.html
01-04-2013, 09:54 PM
Where did you drill the holes for installing the strips? How did it go? I would like to do a similar install on my 4th Gen 4runner but want to enusre I do not drill into a roof support....
Thanks
01-04-2013, 10:11 PM
Here we go...
I am going to get a set of roof rack for a fellow 4runner member. Once I find the price, I'll let you know. PM me your contact number if you are interested. There are 5 4runners in the junk yard.
07-11-2018, 01:47 PM
Have to revive this thread...are there any updated options to get roof tracks for my SR5? Just got my Rocky Mtn Rack in the mail and havent had much luck finding info about whether any aftermarket tracks might work. Cant find stock tracks anywhere.
I could never get that stupid 'mention' tag to work on my posts. Flemster do you know about any aftermarket racks that would work?
'02 SR5
"Gas pedal's on the right.'
~Logan
07-11-2018, 03:28 PM
i pulled the stock roof rack off of my 1996 and plan to use the stock mounting locations that the stock roof rack rails bolted through the sheet metal to when I fab up a roof rack one of these days. The stock front to back rails have a cap on each end front and back and then there are 4 bolts mounting the rails to the sheet metal roof supports behind the headliner on each side. pretty easy to remove if you don't strip the heads of the bolts.
07-11-2018, 03:39 PM
For anyone reading this thread here is a link to a thread where a curt rack was mounted directly to the rails using aluminum square tube.
Inexpensive Full Length Roof Rack (Curt Rack)
97 4Runner SR5 4x4 manual trans.
2.5” lift, OME 881/890, Bilstien 5100(4Runner specific)
Tundra brake upgrade (231mm)
07-11-2018, 04:47 PM
Real Name: John
Real Name: John
Originally Posted by Hockeyjock
The original OP didn't even have the tracks just the plastic covers that come on our rigs from the factory that didn't have roof racks, so one would still need the tracks to use that rack in the thread you posted.
SILVER 2000 4runner Limited TOTALED
WHITE/SILVER 1999 4runner Limited l Rear Locker l Tundra/890 coils | 5100 Bilsteins all around | Sonoran Steel Bumpstops l 199 mm Tundra brake upgrade | SCS Matte Gray Ray10 Rims | 275 70 17 BFG KO2 tires | LR UCAs | EIMKEITH panhard brackets | LED interior upgrade l Rear LED tailights l Pioneer AVH-X5700BHS Alpine Type "R" speakers NVX JAD800.4 Class D Amp Kenwood Under seat Subwoofer l Front window tint 20% l Weathertech window visors and floormats l OutGear Solutions Full Length roofrack l Morimoto 40" LED lightbar
07-11-2018, 10:34 PM
This is what the roof looks like if the rails are taken off. Duct tape on front an back cover clip holes and the 4 shiny dots are stainless steel button head cap screws to fill the bolt holes so water doesn’t come in
07-12-2018, 01:38 AM
I don't know why people keep saying the roof rack is rare...
Found 3x 4Rs in junkyards locally, all of them had the racks on (2 limited, 1 SR5)
Only of them had a damaged cross bar, the other where all in good condition (faded paint/finish but otherwise OK).
