Lines coming off the bottom go to the trans cooler inside the radiator. Which is why people buy aftermarket trans coolers, because if the internal trans cooler breaks then anti-freeze/water makes its way into the trans (bad). Look up the term pink milkshake, it will have the answers you need.
'96 4Runner SR5 2WD Auto, 30x9.5x15 Treadwright Puma, ISR mod, B&M Trans Cooler (Rad. & Trans. Separate), Magnefine (Transtar) Inline Trans Filter, 255K miles
