01-08-2020, 06:38 PM
#1156
Originally Posted by mesooohoppy
see bold.
edit: i cant see pics here at work, but i looked it up via a google search and i got what came up in post 1148. i looked up the picture on post 3 on my phone and it looks like its something different. i apologize.
The person was asking about 3rd Gen Tacoma rims per his picture.
The Bold is the 2nd Gen Tacoma rims (2005-2015).
16" 2nd Gen Tacoma "Snowflake" TRD Off Road wheels PIC
Owned 82, 83, 87 pickup, 98, 99 SR5 4runner
Currently own a 98 SR5, 5spd, 4x4, e-locker, no sunroof. 2012 LTD with the normal options.
01-08-2020, 06:57 PM
#1157
i googled the bold text (because i cant see the img gur pics here at work) and i got more results of the of the picture he posted. that is why i said it was on post 3 cause i was assuming google was right.
99 4runner limited; imperial jade mica
IG: mesooohoppy
01-19-2020, 07:35 AM
#1158
This is great info!
Sent from my Toaster!
01-26-2020, 02:02 PM
#1159
Bump
Hello, first time post for these forums. I've spent the last couple of days reading the wealth of information in this thread. I have not seen if anyone is running the sr tacoma wheels with the 231mm calipers.
Does anyone on here have experience with these wheels and the tundra brake upgrade without spacers?
Any input would be appreciated try to figure this out before I get new tires.
02-13-2020, 07:15 PM
#1160
Any luck with the Gen 3 Tacoma Wheels?
Originally Posted by Dabiddabird
Bump
Any luck? I was looking at a set too.
02-20-2020, 03:44 AM
#1161
No. Looking at the wheels that are said to fit and comparing their offset with the sr wheels, it looks like they would but im not 100% certain.
02-20-2020, 09:14 AM
#1162
Real Name: Matt
Real Name: Matt
Unfortunately, I think the OP has stopped updating the “will fit” list
'98 4WD Limited, Warm Grey, 172k, Factory E-Locker, Ride-Rites, 265/75-16 Wildpeak AT3s
02-25-2020, 07:27 PM
#1163
Originally Posted by zombie_barbarossa
I might have missed it somewhere but will 231mm work with these rims? Also, does anyone know what these rims came off of? They were already on this 4runner when I bought it a few months ago.
Did you ever find out where these came from? I have the same rims on a 2005 Tacoma Prerunner and I am trying to find out more about them as well.
03-07-2020, 06:15 PM
#1164
Links to pictures no longer work. I'd like to know if these wheels (see attached) will fit with 231mm or 199mm. Please and thank you.
Living and breathing and bleeding Toyota
RIP my ‘96.
03-12-2020, 01:45 PM
#1165
TBU Upgrade Write-up
Excellent write-up!
On my list to do this summer. I priced everything with AutoZone & after taxes the total is $497.24, with a refundable core charge of $40 per caliper, bringing the total price to $417.24.
Excited to get this done!
03-31-2020, 03:15 PM
#1166
Didn't find it in the search of this thread, but Method Race 301 fits over the 231 Tundra brakes just fine, no issues. Looks nice too against the red calipers
98 4Runner SR5 Evergreen Pearl, tan interior/sport seats
Toytec Ultimate 3" lift, 4Crawler 2" body lift (removed)
OME rear shocks/springs, Toytec diff drop, Energy poly body mounts
231 Tundra brake upgrade with Brembo rotors, All Pro 1.5" spacers (removed)
Method Race 105 wheels (16 x 8), Definity Dakota 285/75R16
05-04-2020, 09:09 AM
#1167
I think I already know the answer but, I want to make sure. Do the 16" 3rd Gen Split 3-Spoke Wheels fit the 231MM 13WL Tundra brake upgrade? FYI, the pictures did not work for me either.
05-04-2020, 09:29 AM
#1168
Interesting observation re the size of the 199 pads and the 231 pads being the same (see post #1138). I would guess the 231mm rotor would dissipate the heat better since it has more area and mass. I have the 16" 3rd Gen split 3 spoke wheels which I don't think will fit with the 231mm upgrade. So, the 199's may be my only option assuming I don't upgrade my wheels. In any event, if you want more stopping power, your not towing anything, and you have a RWD 4Runner like I have that weighs less than the 4WD then I would think the 199's would be fine. In my case I'm not sure how much extra stopping power I'm going to get with the 231's over the 199's. I mean 4mm doesn't seem like much. Like I said I think the main benefit of the 231's over the 199's is the bigger rotor not so much the caliper especially given your observation re the pads.
05-04-2020, 10:48 AM
#1169
Real Name: Leon
Real Name: Leon
231's and 199's both use the same Tundra rotors, only the calipers are different.
1997 4Runner Limited 4WD E-Locker ~200k | Falken Wildpeak A/T3W 265/75/16 | Pro Comp 69 16x8 | OME 2906 | B&M 70264
Addicted Offroad Front Bumper | Spiker Engineering High-Lift Hood Struts and Ultragauge Mount
05-04-2020, 01:00 PM
#1170
Wow... this has to be one of the most in-depth looks on the bigger Tacoma brakes. Thank you for the wealth of knowledge OP!! awesome stuff!!
Thread Tools |
Display Modes |
Rate This Thread |
Linear Mode
