08-08-2011, 06:30 PM
Steering wheel shimmy
My 2000 4runner has a pretty significant steering wheel shimmy at 60-65 mph. The shimmy is virtually nonexistent at any other speeds.
I have new tires and today had them road forced balanced on the Hunter machine with the Hawkea adapter. I watched my buddy check the tires and we had to rotate the tires on the rims on all but one. They took much less weight to balance than before...but the shimmy is no better.
I do have some movement in the steering rack bushings. But everything I read about these bushings really concerned a "loose" feeling in the steering or problems with the steering wheel returning to center. I have none of those problems.
I have checked the tie rod ends and ball joints and cant find anything loose.
Now what?
08-08-2011, 06:35 PM
New rack bushings solved the same problem for me.
1999 4runner 4x4 Limited|Desert Dune|170,000 Miles|B&M SuperCooler|OME 881/906|265/75/16 Treadwright Guard Dogs|Deckplate Mod|All Pro 1.25" Wheel Spacers
08-08-2011, 09:07 PM
Try tightening up your steering rack guide nut? I did this to mine before I bought a new guide and spring but it didn't quite take all of the vibration out so I was planning on replacing it with a new one, however since then i've put my new wheels on and had it realigned again and most of the vibration has gone away now. I'm still planning on changing my guide out just haven't gotten around to it.
As usual, whenever I find an issue I usually try and research it like crazy, so here's some light reading for you:
Vibration Problems
Rack & Pinion issue - 2001 Taco - TTORA Forum
How to: Replace steering rack guide- Pictures
Diagnose and Fix Steering Play/Rattle - TTORA Forum
Hopefully these will at least give you some ideas. Good luck.
08-08-2011, 09:16 PM
Switch out your wheels and tires with someone and see if it still does it.
I went through multiple wheel balance and alignment on mine before getting a different set of wheels. Shimmy was gone after that..
08-08-2011, 09:26 PM
Bushings is my first guess, but here's a simple technique:
Jack front up, so tires are off ground.
Grab tire at 9 and 3 o'clock, and push/pull. There should be no movement. If there is, then its steering rack bushings or inner tie rods.
Next, grab tire at 12 and 6 o'clock and push/pull. If that moves that means that your upper and/or lower ball joints need replacement.
2005 Limited V8 4x4 4Runner
2005 SR5 V8 4Runner
1997 40th Anniversary FZJ80
2001 Ford F350 w/ FWC Hawk
08-08-2011, 09:47 PM
I own an 06 tundra also. I borrowed her wheels and tried them...still the same. there is no slack anywhere in the front end with the tires lifted on a jack. there is quite a bit of movement in the entire rack so I ordered a bushing kit. I checked on the tundra and saw no movement whatsoever so I know the bushings are at least contributing to the shimmy. I will update this thread as soon as I complete the job.
08-08-2011, 11:17 PM
Any 4runner owners tack weld the slip joint in the steering column? I assume it is just like the taco setup...? I'm thinking I may go that route if the steering rack guide doesn't eliminate the knock noise when I go offroad. My steering feels tight after I replaced the bushings, but it still knocks when I hit some good sized bumps.
08-09-2011, 07:11 AM
I thought about it econ, but its a little above my skill level. I'd also would like to hear from anybody that's done it and what kind of results they've achieved.
08-09-2011, 08:39 AM
Hold on there... It doesn't sound like the slip joint is your problem. The symptom of a bad slip joint is backlash in the steering wheel (meaning you can turn the wheel a bit and it doesn't turn the wheels, like the steering wheel is loose). You havn't described any looseness, just a knocking. A knock could come from just about anywhere, not even suspension/steering components. You would be defeating a safety feature for no purpose.
You can do an easy test to confirm the slip joint problem. You need to be absolutely sure that it your problem before welding it. Read up on it on the TTora thread linked from the tutorial and document reference sticky.
2000 SR5 3.4L V6 Automatic 4x4, e-locker, 175k Miles, Rust
Imp. Jade Mica with Oak Leather Interior, Field Monitor Unit - B&M Tranny Cooler - SG2 - New (to me) rear axle assembly - Goodyear Duratrac 265/75-16 - 1.8" Ironman Front Lift, OME 906/Procomp 9000 Shocks
http://www.toyota-4runner.org/3rd-ge...ld-thread.html
08-09-2011, 12:05 PM
Sorry, I should have taken more time to clarify. My onroad steering feels much improved and tight. Offroad steering feels sloppy and delayed. I feel the "knock" in the steering for sure. I just replaced LBJ's and OTE's less than 500 miles ago. I'm pretty sure it relates to the rack guide or the slip joint.
08-09-2011, 12:10 PM
You still need to to do the check for slip joint backlash. You could still feel a knock in your steering and have it coming from just about anywhere. The test is really quick and you don't have to disassemble anything.
08-09-2011, 12:26 PM
I guess that's true. I'll do the test. Thanks.
08-09-2011, 04:38 PM
Real Name: Phil
Real Name: Phil
Yours sounds like inner rods or the steering rack itself going bad. I had a knock in mine and the only thing that fixed it was the rack I just put on. Thread titled "jitters on bumps" might be helpful
267/75/17 Cooper ATs - Level 8ZX wheels matte black - EBC rotors/ pads - 99 coils/ Bilstein 5100s - deckplate - Sotashi/custom emblem - Hella micro DE fogs - Kenwood/Alpine/Infinity system - sound deadened interior - color matched bumpers - LED tails - Safari LTD rack - Husky floor liners - clear corners
08-09-2011, 05:08 PM
I sure hope that's not the case. Been through your thread a number of times. I'm going to try a new guide first to see if that does the trick. Then we'll see.
08-09-2011, 05:16 PM
I hope your right too econhonda... although I am in the same boat (feels good on the road, steering OK etc. but lots of clunks and issues offroad). I just did the guide and it unfortuantely did not fix the issue. I am convinced mine is the rack or inner rods. At this point however I will live with the annoyance when I wheel my Runner and save the cash. Next year at some point I will likely take another real stab at the true fix. Hopefully yours is cured via the new guide!
