Old 08-16-2011, 12:46 PM #1
brandonchase2000 brandonchase2000 is offline
brandonchase2000 is on a distinguished road
Abs brake system
Fellow $ runner enthusiasts : I have a 1997 Limited 4-Runner...took it to Meineke because every time I pressed the brakes it would go all the way to the floorboard until it braked, but then a 2nd quick step and it would brake immedietly.
So he said the pads were fine, he bled out some air and that helped..but he said one thing that was interesting..(1) The initial pump when I brake is not the best, but the 2nd pump it brakes like it is supposed to. He TOLD ME I could drive it like that forever. Well that sounds great-but I have inspection coming up next month (2) will it pass inspection like this ?
(3) how much is it to replace the ABS system and would be the best/cheapest way to do it ?
Man I really appreciate all and any insight.
Brandon
Houston,Tx
brandonchase2000 is offline   Reply With QuoteReply With Quote
Old 08-16-2011, 12:52 PM #2
Nelsonmd's Avatar
Nelsonmd Nelsonmd is offline
Nelsonmd is on a distinguished road
Nelsonmd's Avatar
It sounds like this has nothing to do with ABS. ABS only comes into when you brake hard.
It could be that you have air in the ABS system that needs to be bled. Drive it around, and in a place that is safe and has some sort of slickness to it (gravel, grass, wet, something like that) slam the brakes to engage the ABS. Do this a couple times, then bleed your brakes again.
Also, make sure the rear brake's are properly adjusted. I had this same behavior happen with too loosely adjusted rear brakes.
2000 SR5 3.4L V6 Automatic 4x4, e-locker, 175k Miles, Rust
Imp. Jade Mica with Oak Leather Interior, Field Monitor Unit - B&M Tranny Cooler - SG2 - New (to me) rear axle assembly - Goodyear Duratrac 265/75-16 - 1.8" Ironman Front Lift, OME 906/Procomp 9000 Shocks
http://www.toyota-4runner.org/3rd-ge...ld-thread.html
Nelsonmd is offline   Reply With QuoteReply With Quote
Old 08-16-2011, 01:46 PM #3
JohnsD90's Avatar
JohnsD90 JohnsD90 is offline
JohnsD90 will become famous soon enough
JohnsD90's Avatar
X2 on the rear brakes, despite doing only 30% of the braking they make braking much worse when improperly adjusted.
JohnsD90 is offline   Reply With QuoteReply With Quote
Old 08-16-2011, 05:23 PM #4
Gonzo113's Avatar
Gonzo113 Gonzo113 is offline
Gonzo113 is on a distinguished road
Gonzo113's Avatar
X3 on checking rear brake adjustment.
01 Sequoia SR5 V8,
Gonzo113 is offline   Reply With QuoteReply With Quote
Old 08-16-2011, 06:50 PM #5
YotaZach85's Avatar
YotaZach85 YotaZach85 is offline
YotaZach85 is on a distinguished road
YotaZach85's Avatar
Does your pedal stay firm after the second pump? If it takes 2 pumps and then it slowly drops you more than likely will need a new master cylinder if there isn't any other leaks. I'd like to know where the air came from, if fluid isn't getting out, air shouldn't be getting in.
1997 3.4l SR5 5spd 4WD E-locked. Blue wire mod, 99 tall springs, 32" Duratracs, Satoshi Grill, Tundra 231 brakes, 99 center console.
1988 3.0l 5spd Pickup SAS on 35s with 5.29's, welded 8.4 rear, custom flat bed, on board air, XRC8 winch, homemade sliders.
YotaZach85 is offline   Reply With QuoteReply With Quote
2002 4Runner - Typical Brake System sounds 2002_thundercloud 3rd gen T4Rs 4 02-24-2011 02:56 PM
2000 4runner - Iginition System Issues and Security System emtnscs New Members 0 10-12-2010 11:15 AM
Brake system overhaul KellyJ 3rd gen T4Rs 18 04-11-2010 10:37 PM
Brake Override System Jtraskell 5th gen T4Rs 7 03-01-2010 10:21 AM
Contaminated brake system Darrin530 3rd gen T4Rs 4 11-07-2006 05:12 PM
