Old 08-16-2011, 01:11 PM #1
evmenke evmenke is offline
evmenke is on a distinguished road
Tire size help needed!
I have a '98 4Runner 4x4. I'm wanting to put a 2-3" body lift on it. With a 2" lift what is the biggest tire size tire I can put on it without doing extra mods and it looking goofy? What about with a three inch lift?
evmenke is offline   Reply With QuoteReply With Quote
Old 08-16-2011, 01:24 PM #2
Nelsonmd's Avatar
Nelsonmd Nelsonmd is offline
Nelsonmd is on a distinguished road
Nelsonmd's Avatar
You need to do some searching...
First, tire sizes have been discussed to death, search it. The biggest tires you can fit under with 2-3in of lift are going to be quite expensive, so do your homework first before spending that kind of money.
Second, 2-3in body lift requires alot of extra work as you need to modify the steering shaft (long extension), some of the harnesses won't reach, some hoses may need to be lengthened, you need to drop your radiator, you need to extend your shift levers... get the idea? This is why the vast majority of people only do 1-1.5" of BL. Again, do your homework, this information is VERY easy to find with google.
Thirdly, this is going to give you a gigantic gap between your body and bumper. Have you seen the pics of guys with BL's that snapped pics of their bumper gaps. Obviously not since you haven't searched it.
Not meaning to be snarky, but you just asked a big, uninformed question as your first post here. It is better to introduce yourself, read a bit, do your own research first, then ask your big questions.
2000 SR5 3.4L V6 Automatic 4x4, e-locker, 175k Miles, Rust
Imp. Jade Mica with Oak Leather Interior, Field Monitor Unit - B&M Tranny Cooler - SG2 - New (to me) rear axle assembly - Goodyear Duratrac 265/75-16 - 1.8" Ironman Front Lift, OME 906/Procomp 9000 Shocks
http://www.toyota-4runner.org/3rd-ge...ld-thread.html
Nelsonmd is offline   Reply With QuoteReply With Quote
Old 08-16-2011, 07:23 PM #3
Running4life's Avatar
Running4life Running4life is offline
Running4life is on a distinguished road
I agree on the search comment.
Lots of questions:
Is the only reason for putting on a BL for bigger tires?
Are you doing any off road activities?
Is your 4Runner a limited or SR5?
What size wheels do you have? 15" or 16"...
If you have 16"s, 265/75/16's will fit without any lift but you may get some slight rubbing on on full turn and suspension compression (depends on the flares). With a 2 inch you might get 285/75/16s on it but then you run into rubbing issues on the upper control arm (depending on the rims you have) which may require wheel spacers (which is an extra mod). It would be better to run a 1" BL. Then 265/75/16 tires would do and the gap between frame and body would not be too bad. A 3" lift (do you mean BL?) would probably look "goofy" and the gap between bumper/body and frame would be very noticeable. The more specific information you post on what you already have helps get you a better answer.
2001 4Runner 265/75/16 Goodyear Duratrac
OME 880/906 w/ RC 9000 shocks.
Yakima Load Rack bars with Load Warrior Basket (sometimes) 50 Series Flowmaster
Running4life is offline   Reply With QuoteReply With Quote
Old 08-17-2011, 12:39 PM #4
Dang. Im using this site as a way to help me do research on what I need to do not a social site. I know I need research, which I'm doing but I thought I'd get opinions from people who would know as well. Not "snarky" remarks because I'm not going about my business how you think I need to. I know I'll need extra mods for whatever lift I do I'm talking strictly about the tires. So thank you to Running4life for just helpin a brother out. My Runner is an SR5, with 16" wheels, I do off road, and I also like the look of bigger tires and a lift, but mainly want to enhance off roading.
Old 08-17-2011, 12:52 PM #5
sooner02r1 sooner02r1 is offline
sooner02r1 is on a distinguished road
I'd look into a suspension lift. you might spend a few more bucks but it will be a much easier install and will handle a lot better. a body lift will raise your center of gravity while not improving offroad capability any, and the only clearance you will gain is at the bumpers.
you can run a 265/75/16 with no lift. I'm running this size on a 2" lift and it looks good. you can squeeze a 285 but it will require cutting and possibly a re-gear.
'98 Limited 4x4- 190k and counting!
Sway-a-Way 2.0s, OME 906s, 285/75/16 Yokohama Geolandar AT-S on KMC Enduro 16x8s, 30" LED, Cobra 18 WXSTII CB, Rhino Lined fenders/rockers.
sooner02r1 is offline   Reply With QuoteReply With Quote
Old 08-17-2011, 12:54 PM #6
Your welcome. Based on that information probably best to do a 1-1.5" BL and 265's. You would get some more ground clearance and can choose AT or Mud Tire whichever you prefer. No other mods would be needed. I have thought many times about a 1" BL but am going to do the suspension instead.
Or you could do a 2" BL or higher and get 255/85/16 tires which would be like 33x10.50'sx15s. That would give you the cookie cutter look others mention and they shouldn't rub the UCA's. That should get you over the river/mountains and through the woods/mud in TN or NC whichever one you wheel in. Here is a pick of mine stock suspension, no BL on 265's.
Tire size help needed!-new-tires1-jpg
Old 08-17-2011, 01:18 PM #7
Nelsonmd's Avatar
Nelsonmd's Avatar
Well, sorry you are offended, but you asked for opinions.
Try to see your FIRST POST here as we see it. Some newb (assumed since you didn't introduce yourself and tell us your experience level) comes in saying he is going to do a big mod that is not very common (1" is common, 3" is not), because he wants to run bigger tires (common desire among mall crawlers and high school kids). Most of us will steer this person away from doing it because they are more than likely getting in over their head.
You said in your first post that you don't want to have to do "extra mods". This is why I assumed you didn't realize how many "extra mods" you will have to do to fit 2-3" of body lift instead of just the 1" lift.
Definitely use this site for research, but research isn't just asking questions that have been answered a million times. Give us a little information, say hi, introduce yourself. This isn't ask jeeves.
Since you gave some additional information in your second post, here is some more opinion. Most guys here will tell you that if you are looking to improve off road capability, then a BL with bigger tires isn't really going to help you (someone else already did in fact). You should first get a suspension lift, but don't believe me, here is a post from a guy that does off-roading for his job.
Sooo...any reason NOT to go 285's?
Anyway, do what you want, but if you tell us you are doing a 3" BL and big tires for off-road capability, then we are going to assume you are just trolling.
Old 08-18-2011, 11:51 PM #8
Ron Helmuth's Avatar
Ron Helmuth Ron Helmuth is offline
Real Name: Uhhh this is my real name
Ron Helmuth is on a distinguished road
4crawler.com
Good to hear you're considering a body lift first.
But as the other guys are mentioning, there are a lot of things to consider.
I highly recommend Mr Roger Brown and 4Crawler.com website. You will start to get an idea of all the complications the higher you lift.
06 4th gen V8 4WD of course...
08 Honda Ridgeline RT
05 Scion xB-the toaster-daily driver
my Yota Fanatic photos are on Facebook- here is link:
http://www.facebook.com/album.php?ai...5&l=5795132731
Ron Helmuth is offline   Reply With QuoteReply With Quote
Old 08-19-2011, 01:10 AM #9
jirehn jirehn is offline
jirehn is an unknown quantity at this point
I think it is about 2 to 3 inch,But maybe your budget is the main concern.
jirehn is offline   Reply With QuoteReply With Quote
Old 08-19-2011, 08:33 AM #10
Baja Runner's Avatar
Baja Runner Baja Runner is offline
Baja Runner is on a distinguished road
Id stick to a 2" body lift, you can get it on there without having any major issues. I couldn't imagine doing a 3" though...
4Crawler makes a solid kit. Get the ultimate lift blocks, with a steering extension, and front bumper bracket and you'll be good to go.
2005 Limited V8 4x4 4Runner
2005 SR5 V8 4Runner
1997 40th Anniversary FZJ80
2001 Ford F350 w/ FWC Hawk
Baja Runner is offline   Reply With QuoteReply With Quote
'98 4rnr , body , lift , size , tire
Tire help needed Coles05t4r 4th Gen T4Rs 2 08-11-2011 06:31 PM
Treadwright Tire Feedback needed chayos00 Engines / Suspension / Wheels / Tires / Audio / Accessories 21 11-09-2010 08:50 PM
lift and tire size questions...newbie help needed t4rjon02 3rd gen T4Rs 2 12-24-2009 04:00 PM
Advice needed - tire mixing of the same tire make and model rsco Engines / Suspension / Wheels / Tires / Audio / Accessories 5 08-27-2009 11:14 PM
Lift and tire advice needed ssnider 4th Gen T4Rs 1 08-22-2007 08:48 PM
