Old 08-22-2011, 05:50 PM #16
brian2sun's Avatar
brian2sun brian2sun is offline
brian2sun has a spectacular aura about brian2sun has a spectacular aura about
brian2sun's Avatar
It might have had manual hubs, I don't remember. I still don't think it would do anything just driving it for 30 seconds around the block, but I'll concede that there's a small chance the bearings could get damaged or pressed out a little. I wouldn't worry about it myself, but the OP can now at least be warned.
I guess you could always re-use the thrust washers and throw a big nut and bolt through the holes to hold the hubs together while you drive with the CVs out. Personally though, I wouldn't care if it's a CV so I wouldn't even bother checking them. Sooner or later, mine will break on the trail anyways and new ones will go in.
1997 4Runner 4x4 SR5 - Geared, Locked & Armored
**CLICK FOR '97 BUILD THREAD**
2021 Tacoma 4x4 TRD Off Road Double Cab Short Bed (my DD)
2017 4Runner 4x4 Limited (the wife’s)
brian2sun is offline   Reply With QuoteReply With Quote
Old 08-22-2011, 10:51 PM #17
Singtoe's Avatar
Singtoe Singtoe is offline
Singtoe will become famous soon enough
Singtoe's Avatar
If the noise is still there when the diff is locked but in 2hi, You should chk the the diff to see if it unlocks. Lift up the drivers side and spin the tire. Nothing else should spin (the front drive shaft or the passenger side Half shaft.
1999 Limited 4runner in Silver - 9th and 10th Injected TRD Supercharged 4.7 2UZ-FE swap - AISIN Manual hub lockers - Retrofitted E-locker - Downey Off road Coilovers & adjustable Pan Hard Bar - Whelen PA - 2" Personally made Body Lift - Eclipse Navigation Radio - Spider Trax - Custom Hidden Winch - Triple Electric Fans - Running boards off then back on again - Ghetto Cold Air Intake - Sequoia Brakes - V8 Badge (for extra horse power)
2002 SR5 Tacoma Extended Cab also in Silver On 37's and Guns for sale
Singtoe is offline   Reply With QuoteReply With Quote
Old 08-22-2011, 11:39 PM #18
prospectator's Avatar
prospectator prospectator is offline
prospectator is on a distinguished road
Originally Posted by Singtoe View Post
Don't drive the 4runner without the front axes in it. The outer CV joint actually holds the hubs together. If you drive without it, the hub will come out of the knuckle causing catastrophic failure.
If you can't remove the axle, how does a 2wd 4Runner work? Isn't it the same upright and hub with caps sealing the bearings? I don't recall seeing a bolt through a 2wd hub? I agree you shouldn't drive without them because you can contaminate the front differential, but I didn't think you could severely damage the spindle and bearing. I'm just curious, I don't intend to start a war on Toyota's hub design.
Sorry if this derails this thread........... Any response can be sent via PM. Thanks.
1997 SR5 V6 4X4, E-Locker, Total Chaos LT with Fox C/O and Fox 2.5 Bypass, LC 7.5 Wrap, LC TrekMaster shocks, 315/75R16 BFG KO2's on Limited wheels, 4:88 gears, Custom front bumper, Patco fabrications rear bumper, Patco fabrications custom rear arms
http://www.prospectator.com
prospectator is offline   Reply With QuoteReply With Quote
Old 08-23-2011, 10:56 AM #19
Singtoe's Avatar
Singtoe's Avatar
2wd 4runners use the same knuckle and bearing but everything else is different. The Hubs of 2wd 4runners are held on with a giant nut on the back side. It is torqued to 215 foot pounds and then staked.
There is no war over Toyota's hub design. Almost all car manufacturers use a big nut and outer CV joint to hold the hub bearings together.
Old 08-23-2011, 10:15 PM #20
Here's a picture of a 2WD spindle. Is the nut behind the large cover on the back? It doesn't seem like there's enough room. I was always under the assumption the bearing was pressed into the upright and the hub was pressed into the bearing held in with a large snap-ring. I've been wrong before though.....
Old 08-23-2011, 10:28 PM #21
Singtoe's Avatar
Singtoe's Avatar
it would look similar to this.
3rd-gen , arb lockers , drivetrain , regear , suspension
Regear after 285's Spish 3rd gen T4Rs 35 02-24-2020 01:38 PM
Regear for 275/70/17 forwardnum1 4th Gen T4Rs 14 05-25-2012 10:15 AM
Regear 4:88 worth it mory 3rd gen T4Rs 2 05-03-2011 12:20 PM
Quote for regear! Lignum 3rd gen T4Rs 11 04-01-2010 03:36 PM
225/70/15 to 265/75/16 - regear? Washington4R Engines / Suspension / Wheels / Tires / Audio / Accessories 6 09-29-2006 04:27 PM
