Originally Posted by Singtoe
Don't drive the 4runner without the front axes in it. The outer CV joint actually holds the hubs together. If you drive without it, the hub will come out of the knuckle causing catastrophic failure.
If you can't remove the axle, how does a 2wd 4Runner work? Isn't it the same upright and hub with caps sealing the bearings? I don't recall seeing a bolt through a 2wd hub? I agree you shouldn't drive without them because you can contaminate the front differential, but I didn't think you could severely damage the spindle and bearing. I'm just curious, I don't intend to start a war on Toyota's hub design.
Sorry if this derails this thread........... Any response can be sent via PM. Thanks.
1997 SR5 V6 4X4, E-Locker, Total Chaos LT with Fox C/O and Fox 2.5 Bypass, LC 7.5 Wrap, LC TrekMaster shocks, 315/75R16 BFG KO2's on Limited wheels, 4:88 gears, Custom front bumper, Patco fabrications rear bumper, Patco fabrications custom rear arms
http://www.prospectator.com
