Old 08-22-2011, 12:00 AM #1
mrlouie's Avatar
mrlouie mrlouie is offline
mrlouie is an unknown quantity at this point
mrlouie's Avatar
Rear shocks: boot up or boot down?
Hi, I installed OME springs and Bilstein shocks over the weekend and I ended up with one question that I'm not sure on. I ordered all the parts from Toytec, and they had there eye-to-stud adapter pre-installed on the shock to where the boot would be down.
However, when I tried to install it that way the rubber bushings that were pressed into the shock eyes were the opposite(only one end was big enough to fit over the axle mounting tab). I ended up installing them boot up so I could be done, but does it make a difference? I don't like the idea of the shocks oil reservoir being exposed to any sort of flying rocks and whatever else may be coming through, and the boot itself was set to drain to the bottom, and the stickers themselves seem to be pointing to boot down being the best.
I just can't understand when the pressed in rubber bushings would be backwards... to those of you running Bilstein shocks, what did you do? Can you just swap ends with the rubber bushing inserts?
1999 SR5 V6 4x4 - 5 speed manual - OME 883 front / 891 rear - Bilstein shocks all around - FJ 6 spoke wheels and 285/70R17 Dynapro MT tires
mrlouie is offline   Reply With QuoteReply With Quote
Old 08-22-2011, 12:06 AM #2
4-Ripcord's Avatar
4-Ripcord 4-Ripcord is offline
Real Name: Jim
4-Ripcord will become famous soon enough 4-Ripcord will become famous soon enough
4-Ripcord's Avatar
Real Name: Jim
I have the same shocks, the lower bushing fit with a little effort. Mostly aided with a set of channel locks to squeeze them on.
'13 Tacoma TRD-OR: The Spruce Goose. BUILD
'02 Sport Ed.- V2.0: The better build. Totaled BUILD 2.0
'02 Sport Ed.- V1.0: The college build Sold BUILD
4-Ripcord is offline   Reply With QuoteReply With Quote
Old 08-22-2011, 12:20 AM #3
mrlouie's Avatar
mrlouie's Avatar
I didn't try to force it, but looking at it there seemed to be no hope of it fitting over that mounting tab without destroying something. I actually came inside and looked at your pictures of of relocating the shock mount to figure out if what I was doing was wrong or not, and since you mounted them boot down I thought I'd figure out what I did wrong with this post! haha
I wonder if my shock bushings were installed backwards at the factory or something...
Old 08-22-2011, 12:26 AM #4
4-Ripcord's Avatar
Real Name: Jim
4-Ripcord's Avatar
Real Name: Jim
Just put some grease on the inside of the bushing and squeeze it on. Its a tight fit, use a clamp or channel locks.
Old 08-22-2011, 10:27 AM #5
Gerdo's Avatar
Gerdo Gerdo is offline
Gerdo will become famous soon enough
Gerdo's Avatar
Most mass produced replacement shocks mount with the body down. This is because any air that is left or finds it's way into the shock will migrate away from the most usable part of the stroke.
Bilsteins can, and are, mounted up or down depending on the application. My 5125s are eye/stud and the body is down. My 2451s were also body down.
Do use the shaft boots but take a pair of wire cutters and snip a couple of 3/8" birds mouths in the bottom of the boots to allow water and dirt out.
2000 4runner Sport, SAS/4wheel Underground 3 link, Diamond axle, 14" Radflo coilovers, double locked, Custom rear 3 link, 12" Fox shocks, full armor Gerdo's Build Thread
Real Fuel Tank Skidplates for sale Lil' Skip's OffRoad
Rear control arm mount skids and Hi-Lift adapter for sale Lotus Development
Gerdo is offline   Reply With QuoteReply With Quote
cv-boot kit OEM help kakarot 3rd gen T4Rs 4 05-12-2011 10:42 AM
CV Boot rip Matrixman955 4th Gen T4Rs 2 03-19-2011 06:58 AM
Air Box Boot albrow75 Classic T4Rs 4 01-09-2009 01:58 AM
cv boot rip jk4run99 Problems & Warranty Issues 6 01-21-2005 10:13 PM
Outer Tie Rod Boot ViperFixer Maintenance/Detailing 6 04-08-2004 01:53 AM
