Old 08-23-2011, 03:36 PM #1
BradB's Avatar
BradB BradB is offline
BradB is on a distinguished road
BradB's Avatar
I thought rear shock replacement was supposed to be easy.
Got new shocks in hand. I jacked up the 4Runner and am attempting to remove the nut off the top of the shock on the drivers side. Holy cow, there is not much space to work up there. I can only get a 3/8 socket wrench with a deep well 14mm up there. I can only just grab the wrench with my fingertips. Not near enough strength to turn it.
Any tricks to this? I am reaching up and over the axle. Does anyone remove anything to help access? The shop manual just says 'remove it.' Duh.
I have the axle jacked up which compresses the shock a bit, not sure if this helps or hurts.
Geez! Seems like such a stupid-simple job but 2 hours later I am stuck.
‘23 Toyota 4Runner TRD ORP / ‘96 Porsche Carrera 4S / ‘14 Porsche Carrera S / ‘17 Audi TTS / ‘17 Porsche Macan GTS / ‘21 Honda CRF300L / ‘23 BMW R1250GS / ‘23 Husqvarna Norden / ‘22 Honda CB500X / 1959 Radio Flyer
BradB is offline   Reply With QuoteReply With Quote
Old 08-23-2011, 03:43 PM #2
TN_Soljah808 TN_Soljah808 is offline
TN_Soljah808 is on a distinguished road
Sawzall! Is what I used to remove mine. I tried removing but to much rust. Get a Sawzall or borrow one and it will be removed in 2 minutes per side!
2000 4Runner SR5 | 5 speed | 4x4 | URD Short throw Shifter | Sonoran Steel 1.2 | 231mm Tundra Brakes | 4.30 E-Locker | 2nd Gen Supercharger | URD 7th Injector kit | 1.25" Spidertrax | FJ Wheels | 265/70/17 Terra Grapplers.
TN_Soljah808 is offline   Reply With QuoteReply With Quote
Old 08-23-2011, 03:48 PM #3
traffic61's Avatar
traffic61 traffic61 is offline
traffic61 is on a distinguished road
traffic61's Avatar
New guy here. I know, I am working on a proper intro.
Seems like the last time I replaced the rear shocks on my '97 Limited, I had to put a wrench on the nut and then get some big pliers and twist the upper shock body to get them loose.
I didn't own a Sawzall then, But I do now.
traffic61 is offline   Reply With QuoteReply With Quote
Old 08-23-2011, 04:09 PM #4
BradB's Avatar
BradB's Avatar
I tried but there is no room to get my Sawzall up near the top of the shock on the left side. Gas tank and other obstacles. This could work on the right side, though.
I will try spinning the shock as suggested.
I can't believe this is beating me.
Old 08-23-2011, 04:11 PM #5
IanB's Avatar
IanB IanB is offline
IanB has a spectacular aura about IanB has a spectacular aura about
IanB's Avatar
Your 1st post says the rear suspension is compressed, try putting jackstands under the frame and letting the rear suspension droop, you might find you have more room to work that way.
'93 Toyota LandCruiser VX Ltd 4.2TD - 3X e-lockers, winch, factory fridge, 285/75/16E Duratracs, ICON Stage 1 3" lift, GTurbo Grunter Extreme
'04 Lexus GX470 Ultra Premium - Dobinsons 2F/1R lift, Tandem 612's w/ 265/70/17 Wildpeaks, XD HID lows
'15 Lexus GX460 - FJC 6-spokes w/ 265/65/17C Duratracs Weathertech HP & Canvasback liners
'15 4Runner Limited - 1" Cornfed level, 255/75/17SL Duratracs on FJC 8-holes, XD HID lows, Sprint Booster, Canvasbacks & Husky Liners - SOLD
'96 Toyota Hilux Surf SSR-G 3.0TD RIP - 265/75/16C Duratracs, '99 tall fronts, OME 906's rear
IanB is offline   Reply With QuoteReply With Quote
Old 08-23-2011, 04:26 PM #6
Singtoe's Avatar
Singtoe Singtoe is offline
Singtoe will become famous soon enough
Singtoe's Avatar
Get the socket to sit up top with the ratchet and use some vise grips to turn the shock shaft. It will mess up the shock but will get er done.
1999 Limited 4runner in Silver - 9th and 10th Injected TRD Supercharged 4.7 2UZ-FE swap - AISIN Manual hub lockers - Retrofitted E-locker - Downey Off road Coilovers & adjustable Pan Hard Bar - Whelen PA - 2" Personally made Body Lift - Eclipse Navigation Radio - Spider Trax - Custom Hidden Winch - Triple Electric Fans - Running boards off then back on again - Ghetto Cold Air Intake - Sequoia Brakes - V8 Badge (for extra horse power)
2002 SR5 Tacoma Extended Cab also in Silver On 37's and Guns for sale
Singtoe is offline   Reply With QuoteReply With Quote
Old 08-23-2011, 04:28 PM #7
BradB's Avatar
BradB's Avatar
BINGO!
TN_Soljah808: Thanks for giving me the balls to use a saw!
IanB: Thanks for giving me the brains to use the saw correctly! The extra space did it.
Now I will have a beer while the burned rubber smell dissipates in the garage. Cough! Cough!
Old 08-23-2011, 04:32 PM #8
Hepar's Avatar
Hepar Hepar is offline
Hepar is a jewel in the rough Hepar is a jewel in the rough Hepar is a jewel in the rough Hepar is a jewel in the rough
Hepar's Avatar
If you ever come across this problem again, another easy solution is to drill a hole in the outer casing, shove a screwdriver in there and twist off.
2001 4Runner 4WD Sport Package, Millennium silver, 110,000 miles, 2nd gen TRD Supercharger, Toytec BOSS coilovers, 890 OME rear springs, Bilstein 5125 rear shocks, custom Baldlands front bumper, PIAA 520 driving lights and fogs, 4x Innovation Sliders (welded on!), 18" Magnaflow muffler, JDM corners, 65" Thule bars, 20% tint, 16x8 FJ80 wheels on 265/75-16 Duratracs, Husky mats w/ cargo, rear diff breather mod, 3M clear bra, remote start, Pioneer AVIC-8200NEX
Hepar is offline   Reply With QuoteReply With Quote
Old 08-23-2011, 04:46 PM #9
IanB's Avatar
IanB's Avatar
Originally Posted by BradB View Post
BINGO!
Glad I could help, I just spent some quality time under there this past weekend, lol. Now that the strut is out, how do you get the new one in? You don't want to score the new strut by holding it in place with visegrips right? Or is the new strut stiff enough to resist the shaft spinning, and the new nut threads on easier than the old rusty one?
Old 08-23-2011, 05:06 PM #10
Nelsonmd's Avatar
Nelsonmd Nelsonmd is offline
Nelsonmd is on a distinguished road
Nelsonmd's Avatar
Hehe, lots of complaints about trying to do that. I used an angle grinder with cutoff wheel. It's a PITA. Wasn't nearly as bad as getting the fronts off mine though. I had to take a dremel to the frame-side stud and just slit the thing until I could break the nut off. I probably blew through 10-15 cutting wheels on it.
2000 SR5 3.4L V6 Automatic 4x4, e-locker, 175k Miles, Rust
Imp. Jade Mica with Oak Leather Interior, Field Monitor Unit - B&M Tranny Cooler - SG2 - New (to me) rear axle assembly - Goodyear Duratrac 265/75-16 - 1.8" Ironman Front Lift, OME 906/Procomp 9000 Shocks
http://www.toyota-4runner.org/3rd-ge...ld-thread.html
Nelsonmd is offline   Reply With QuoteReply With Quote
Old 08-23-2011, 05:22 PM #11
BradB's Avatar
BradB's Avatar
The new strut popped in pretty easily and tightened right up. I only hope I got the configuration of washers and bushings correct. The top seemed odd, but looks like (from the bottom) washer, bushing, washer, frame mount, bushing, washer, nut.
I can tighten the shock as much as I want. Just not sure what is too tight. I have the bushings pretty mushroomed, but not totally squeezed down. And that's not with much pressure on my 3/8 wrench.
I went with Sensatracs since my truck is just a grocery getter and supposed to be my 'cheap' ride. I know Bilsteins and other shocks seem preferred but with a 40% off coupon from Advance Auto the Monroes were a deal.
I was hoping the oem shocks, surely original, would feel really weak but they don't feel all that bad. I hope I feel improvement with the new ones. No turning back!
Old 08-23-2011, 05:24 PM #12
BradB's Avatar
BradB's Avatar
Oh great. Thanks for the words of encouragement. I'm doing the fronts later this week. I'm sure you'll hear from me!
Old 08-23-2011, 05:27 PM #13
IanB's Avatar
IanB's Avatar
I had to cut one of the studs off my tophats when I did my fronts as well as the stud came loose and just spun with the nut, ended up using an angle grinder on it, luckily it was the middle one, and not the rearmost, that would have gotten ugly. Be very careful not to round the nut on that rear one, it's tight getting in there.
Old 08-23-2011, 05:48 PM #14
LittleCaesar's Avatar
LittleCaesar LittleCaesar is offline
LittleCaesar is just really nice LittleCaesar is just really nice LittleCaesar is just really nice LittleCaesar is just really nice
I thought the Audi was the grocery getter?
You should have thrown some new springs in while you were in there.
Your 4runner looks to have zero rust on the undercarriage. Looks nice.
LittleCaesar is offline   Reply With QuoteReply With Quote
Old 08-23-2011, 06:25 PM #15
BradB's Avatar
BradB's Avatar
You sound like my wife! Shhh. Or she will take it away from me.
I know. Budget restraints. Get to that later. And need to research what to get.
It's pretty amazing how good of condition this is inside and out. Looks two years old! It was garaged and babied all it's life.
Front and Rear SHock Replacement Bulldog2 4th Gen T4Rs 8 06-28-2011 06:17 PM
is the rear wiper supposed to do this? help? fileechino 4th Gen T4Rs 9 10-14-2009 08:09 PM
easy speaker replacement suggestions pipspeak 4th Gen T4Rs 3 12-04-2008 09:09 PM
Rear shock replacement Al Hanks Maintenance/Detailing 5 07-01-2008 07:29 AM
Are rear seat latches supposed to lock? Baba Booey 4th Gen T4Rs 41 01-12-2006 10:05 PM
