Thread Tools Rating: Thread Rating: 3 votes, 5.00 average. Display Modes
Old 09-01-2021, 09:07 AM #151
thegipper's Avatar
thegipper thegipper is offline
thegipper is a jewel in the rough thegipper is a jewel in the rough thegipper is a jewel in the rough
thegipper's Avatar
Originally Posted by FD7683 View Post
Can I use Moly-Lithium Grease for all points since I have it? I'm sure it would be better than no grease for 10 years.
That will be fine.
1999 SR5 4x4 Auto for parts
2011 Camry SE V6
2011 Highlander Limited
thegipper is offline   Reply With QuoteReply With Quote
Old 10-05-2021, 06:10 PM #152
themightygoose's Avatar
themightygoose themightygoose is offline
themightygoose is on a distinguished road
Smile Change in grease recommendation
Originally Posted by nobb View Post
Weird that as per the TSB, Toyota's most recent recommendation is to use MP grease on all joints except for the double cardan which is moly. Isn't a double cardan joint just two U-joints? How is it different in construction vs a U-joint to require (in theory) a different grease?
It seems the reason why Toyota initially specified two greases is because of the presence of sliding vs rolling forces. Rolling forces are better serviced by a (NLGI GC rated) MP grease and sliding forces by a (NLGI LB rated) moly grease. However, these days greases have become so good that most moly and MP greases are both GC and LB rated, so it might not really matter. All the old school guys saying moly greases ruined their U-joints were probably basing their experiences on ancient greases which did not perform the same in these two applications as compared to a modern grease.
I'm curious why Toyota would switch from a moly to a MP grease for the slip yoke when sliding forces are better serviced by a moly grease.
I spent a while researching this as well because I have both a '99 and 2019 t4R, both 4x4. I was hoping the advice on the 2019 would be retroactive to the 1999 for some reason. I called a couple different entities but finally got the answer as to why the 5th gen recommendation was different from the 3rd gen. The guy at the Toyota Service Center told me Toyota uses a different metal compound in the 5th gen driveshafts. So those of you with the 5th gens don't NEED a moly lube but it's still recommended.
As for me, I'm going to have two guns, one with moly and one without. I honestly don't know why I spent so much effort trying to convince myself it's okay to use one grease on everything. An extra grease gun loaded with moly will cost me about $30 and will probably last the life of both cars. Trying to find a reason to use only one grease made me feel cheap and lazy. Having two guns will make me feel like a pro. And I kinda like that.
themightygoose is offline   Reply With QuoteReply With Quote
Old 11-09-2022, 08:23 PM #153
Rushthezeppelin Rushthezeppelin is offline
Rushthezeppelin has a spectacular aura about Rushthezeppelin has a spectacular aura about Rushthezeppelin has a spectacular aura about
Decided to finally go grab a grease gun and hit up all my grease points today on the 98 I bought a month ago. Some of them it would appear haven't been hit in ages (I remember us hitting them when I changed oil but I wonder how many lube techs ever see them anymore with all the non-servicable stuff these days). My only problem was I got a gun with a flexible tube and the twist lock to hang on the the zirk fitting. The issue I'm having is that this style isn't allowing me to hit the zirks on the single u joints on the front driveshaft at the tcase and the rear driveshaft at the dif. I can get the gun on it but can't tighten it and so the grease just flows out of the nozzle instead of into the fitting. What nozzle do I need to find to hit these?
'98 SR5 5 Speed
Rushthezeppelin is offline   Reply With QuoteReply With Quote
Old 11-10-2022, 12:33 AM #154
pluton's Avatar
pluton pluton is offline
Real Name: Keith
pluton has a spectacular aura about pluton has a spectacular aura about pluton has a spectacular aura about
pluton's Avatar
Real Name: Keith
The nozzle my Lincoln grease gun's hose came with can be either twist-locked OR simply pushed straight onto the zerk. There's a dull snap when it locks on. You have to give it a good yank to remove it, which sometimes causes your knuckles to bash into some nearby sharp metal.
pluton is offline   Reply With QuoteReply With Quote
Old 05-12-2023, 05:50 PM #155
psea17 psea17 is offline
psea17 will become famous soon enough
anyone know what size zirk i need for the #8 zirk in the diagram on pg1? mine appears to be missing. thank you!
'98 4Run SR5 v6 4x4-Orig Owner
Manual Transmission
Bilstein 5100 (front/rear)
OME 890 Springs (rear)
'99 Tall Springs (front)
psea17 is offline   Reply With QuoteReply With Quote
Old 05-12-2023, 09:40 PM #156
turbodudey2's Avatar
turbodudey2 turbodudey2 is offline
turbodudey2 will become famous soon enough
It’s an M6x1 grease fitting. You can usually find the little packs of assorted metric grease fittings at your local auto parts for for just a few bucks.
'96 Toyota 4Runner Limited 4x4, Supercharged
turbodudey2 is offline   Reply With QuoteReply With Quote
Old 05-13-2023, 10:52 AM #157
JZiggy's Avatar
JZiggy JZiggy is offline
JZiggy has a brilliant future JZiggy has a brilliant future JZiggy has a brilliant future JZiggy has a brilliant future JZiggy has a brilliant future JZiggy has a brilliant future JZiggy has a brilliant future JZiggy has a brilliant future JZiggy has a brilliant future JZiggy has a brilliant future JZiggy has a brilliant future
JZiggy's Avatar
I have a crapload of these (not OEM but vintage and high quality). I can mail you a couple if you want, just PM me.
JZiggy is offline   Reply With QuoteReply With Quote
Propeller Shaft Greasing V8 4WD 2004 hyperthread 4th Gen T4Rs 15 12-13-2011 11:01 PM
Drive Shaft/ Prop joint recall coming soon! wis99ski 4th Gen T4Rs 71 07-09-2011 04:40 PM
Propeller Shaft greasing Frenchie Maintenance/Detailing 6 11-10-2008 10:52 PM
Greasing the Propeller Shaft liquidvw 4th Gen T4Rs 5 09-25-2006 08:29 AM
Drive shaft ?'s Tobi-Wan Classic T4Rs 3 11-08-2005 04:52 PM
