Old 09-05-2011, 09:50 PM #1
awinter78's Avatar
awinter78 awinter78 is offline
awinter78 is on a distinguished road
awinter78's Avatar
97 4cylinder 3RZ-FE distributor?
I could find nothing anywhere so Im soliciting your help
Im wondering if my Runner has a distributor? Rock Auto has one for my year and engine but I see nothing that resembles this under the hood-
I attached a pic...Im getting ready to change plugs but am confused what the wires are going into..
Sorry in advance if this is a BIG idiot question :/
Thanks A LOT!!
awinter78 is offline   Reply With QuoteReply With Quote
Old 09-05-2011, 10:00 PM #2
miheckman's Avatar
miheckman miheckman is offline
miheckman is on a distinguished road
miheckman's Avatar
hey i have a 4 cylinder in my 1996 and i have a disttruper cap on mine
miheckman is offline   Reply With QuoteReply With Quote
Old 09-05-2011, 10:20 PM #3
awinter78's Avatar
awinter78's Avatar
Hmmm where is it located? Thx!
Old 09-05-2011, 11:02 PM #4
miheckman's Avatar
miheckman's Avatar
in that same spot i will take a pic of mine tomorrow
Old 09-05-2011, 11:09 PM #5
miheckman's Avatar
miheckman's Avatar
i do believe those are coil packs i did looking around and from the pic you posted and what i found online they look like coil packs here is what i found hope it helps
Buy BWD/Intermotor Ignition Coil E767 at Advance Auto Parts
Old 09-06-2011, 05:40 PM #6
flatboy flatboy is offline
flatboy is on a distinguished road
Yes those are coil packs, I have them on my 2000 2rz Tacoma.
shayne
flatboy is offline   Reply With QuoteReply With Quote
Old 09-06-2011, 08:01 PM #7
YotaZach85's Avatar
YotaZach85 YotaZach85 is offline
YotaZach85 is on a distinguished road
YotaZach85's Avatar
95.5 Tacoma's and 96 4Runner and Tacoma had the distributor, 97 was the first year of distributorless ignition.
1997 3.4l SR5 5spd 4WD E-locked. Blue wire mod, 99 tall springs, 32" Duratracs, Satoshi Grill, Tundra 231 brakes, 99 center console.
1988 3.0l 5spd Pickup SAS on 35s with 5.29's, welded 8.4 rear, custom flat bed, on board air, XRC8 winch, homemade sliders.
YotaZach85 is offline   Reply With QuoteReply With Quote
Old 09-06-2011, 08:42 PM #8
Nelsonmd's Avatar
Nelsonmd Nelsonmd is offline
Nelsonmd is on a distinguished road
Nelsonmd's Avatar
Ah, that explains alot. I didn't realize they changed it from 96 to 97.
2000 SR5 3.4L V6 Automatic 4x4, e-locker, 175k Miles, Rust
Imp. Jade Mica with Oak Leather Interior, Field Monitor Unit - B&M Tranny Cooler - SG2 - New (to me) rear axle assembly - Goodyear Duratrac 265/75-16 - 1.8" Ironman Front Lift, OME 906/Procomp 9000 Shocks
http://www.toyota-4runner.org/3rd-ge...ld-thread.html
Nelsonmd is offline   Reply With QuoteReply With Quote
Old 09-06-2011, 09:59 PM #9
awinter78's Avatar
awinter78's Avatar
Geeeeeezus! Thx for the replys- ive been racking my brain trying to figure out where eff they stuck it...
Again thanks
Old 09-06-2011, 10:58 PM #10
iowajosh iowajosh is offline
iowajosh is on a distinguished road
I ran into this when searching for plug wires. I read there were three versions. One distributer, one with the coil packs like above and one with coil packs right on top of the spark plug.
iowajosh is offline   Reply With QuoteReply With Quote
Old 09-07-2011, 04:46 PM #11
YotaZach85's Avatar
YotaZach85's Avatar
Good point, I think they went to coil-on-plug in 2000 or 2001.
Old 12-01-2022, 01:50 PM #12
Jordan River Jordan River is offline
Jordan River is on a distinguished road
So im having a tough time finding the spark plug wires for my 2000 3rz 4cyl. I have no distributor? They plug directly to my Ignition Coil and I see the wires all come together inside a plastic heat shield casing, and appers to run over into my passenger side glove box.
I'm getting a P0300 and was going to change spark plugs, coils, and wiring harness. But I can't seem to find the right spark plug wires- that plug in like a wiring harness clip.
So no change out on these wires?
Jordan River is offline   Reply With QuoteReply With Quote
Old 12-01-2022, 09:49 PM #13
davidch davidch is offline
davidch will become famous soon enough
Unless your engine has been replaced with a much earlier 3rz-fe (which had a distributor) or a post-2000 engine from a Tacoma (which will have coil-on-plug, COP) you have two coils, each with two leads, mounted on the engine block.
If you've got either of the other arrangements, considerable rewiring was done to make this happen. Or maybe it has some strange aftermarket "improved" ignition system.
Here are numerous sets of wires:
2000 TOYOTA 4RUNNER 2.7L L4 Spark Plug Wire | RockAuto
I've owned a 2000 4-cylinder 4Runner for 19 years, so I've looked at that engine many times. Mine still has the NGK wires a previous owner installed. It now has 240,000 miles.
Don't forget to check your 3rz-fe engine's valve clearances.
davidch is offline   Reply With QuoteReply With Quote
Distributor help!!! Please!!! 4 X 4RUNNER Classic T4Rs 5 01-16-2011 10:00 PM
864R Distributor air gap ultrabongo Classic T4Rs 2 06-02-2009 10:59 PM
Audio Distributor DEVILMAN Engines / Suspension / Wheels / Tires / Audio / Accessories 1 10-07-2008 09:47 PM
Distributor Problem KJG912 4th Gen T4Rs 1 10-04-2005 06:47 AM
Any way to make the 4cylinder quicker? alphonsus 4th Gen T4Rs 7 02-16-2004 12:33 PM
