Originally Posted by Brentif
I have another question to further my decision process. Camburg is just around the corner from my work, and I plan on getting upper control arms, whether I will be able to afford to get them at the same time as the coil overs is a different story. If I purchase the long travel version of the Icon and install it without a uniball upper control arm will it damage the shock? Or is the stock uca just going to limit the amout of travel?
You will only damage the upper ball joint. And it wont take long if you wheel often. If you dont its not worth the money to get the extended Icons. In all actuality the Standard coil-over and the Extended coil-over are the same, its just the standard has a stopper inside to keep it from fully extending.
Icons are great coil-overs and they have wonderful customer service. So are Camburg's coil-overs and UCA's. You will not have any complaints with that set-up.
1999 4Runner SR5, with some stuff...
OverlandNV
You can also follow us:
Facebook OverlandNV
Twitter OverlandNV
