Old 09-16-2011, 05:40 PM #1
Clemsonfan15's Avatar
Clemsonfan15 Clemsonfan15 is offline
Clemsonfan15 will become famous soon enough
1.25" vs 1.5" vs 2" Wheel Spacers
Wheels spacers are next up on my list, but I can't decide on which size to get.
I know that Spidertrax only makes 1.25", but All-Pro makes all three sizes.
Right now I'm running 265/70/17 on Tundra rims. When I turn the wheels the tire is fairly close to my Limited flares.
Will any of these sizes cause rubbing?
Which of the three sizes will bring the tires closest to the Limited flares?
Pictures would also be helpful.
Thanks.
Check out my garage.
Clemsonfan15 is offline   Reply With QuoteReply With Quote
Old 09-16-2011, 10:21 PM #2
Gerdo's Avatar
Gerdo Gerdo is offline
Gerdo will become famous soon enough
Gerdo's Avatar
What is the backspacing on those wheels?
I'm running stock 4runner 5 spoke wheels and Spidertrax spacers with 265/75-16 (close to the same size tire). My tires rub a little, after adding the spacers, while turning even when flexing. They do rub slightly on the top of the fender flare at full flex. the stock wheels have a BS of ~4.65" minus the 1.25" spacer I have an effective BS of 3.4"
2000 4runner Sport, SAS/4wheel Underground 3 link, Diamond axle, 14" Radflo coilovers, double locked, Custom rear 3 link, 12" Fox shocks, full armor Gerdo's Build Thread
Real Fuel Tank Skidplates for sale Lil' Skip's OffRoad
Rear control arm mount skids and Hi-Lift adapter for sale Lotus Development
Gerdo is offline   Reply With QuoteReply With Quote
Old 09-16-2011, 10:26 PM #3
240m3srt's Avatar
240m3srt 240m3srt is offline
240m3srt is on a distinguished road
240m3srt's Avatar
Im pretty sure i have the spidertrax 1.25 and my 315's stick out a couple of inches past the limited fender flares and just barely rub the frame under full lock.
Also, make sure you buy hubcentric spacers or it will vibrate.
Black Beauty-96' 4Runner 4WD Limited V6, 353k mi.
240m3srt is offline   Reply With QuoteReply With Quote
Old 09-17-2011, 02:05 AM #4
They are 4.5" backspacing.
240- Those tires are a solid 2" wider than mine. So I guess 1.5" or 2" is the way to go.
The reason I was curious about 2" is because I haven't heard of anyone using those. That's a pretty big spacer.
Old 09-17-2011, 10:37 AM #5
HuntNFish HuntNFish is offline
HuntNFish is on a distinguished road
I wouldn't want a 2" spacer. I have the 1.25" AllPro's, and I think it is about perfect. I'll try to snag some pics for you.
HuntNFish is offline   Reply With QuoteReply With Quote
Old 09-17-2011, 11:17 AM #6
I have 265/75 **** Cepeks on TRD wheels, not sure how much BS they have. I haven't put my front spacers on yet. If I had to do it again I probably would have done 1.5" in back and 1.25" in front, but that quarter inch doesn't really matter. Anyways, here are a few pictures:
Old 09-17-2011, 11:27 AM #7
Gerdo's Avatar
Gerdo's Avatar
Fact: The rear axle is ~1/2" narrower than the front track.
Old 09-17-2011, 11:56 AM #8
Wish I had known that before I bought mine. Again, the quarter inch isn't really a big deal to me, but I think it would look better.
Is there a reason it is narrower?
Old 09-17-2011, 12:56 PM #9
Rc4r's Avatar
Rc4r Rc4r is offline
Rc4r is on a distinguished road
Rc4r's Avatar
You will still rub the pinch weld.
96 limited 4x4- Toytech ultimate, 1" bl, 285 toyos mts, XD hoss, 1.5" spacers, RF subs, speakers, Out Door Logic bumper, 5.29 yukons, grizzly locker, k&n cai, magnaflow highflow cat, borla xr-1 muffler, some paint, and stickers to make it fast.
Rc4r is offline   Reply With QuoteReply With Quote
Old 09-17-2011, 06:09 PM #10
Yeah. The 2" sounds a little extreme.
Thanks for the pictures. They are helpful. Looks like those tires are pretty flush. I could probably go up to 1.5", but I don't like the look if the tires stick out too far.
I think those rims are either 4.5" or 4.8" backspacing.
Good to know. I wonder if it's a good idea to get a 1/2" smaller for the fronts to even things out or if they need the 1/2" difference.
Even if I don't rub now?
Old 09-17-2011, 11:26 PM #11
Gerdo's Avatar
Gerdo's Avatar
The rear is a total of 1/2" narrower so you would want spacers that are each a 1/4" thicker. I would have done 1.5" in back and 1.25" in front if ST sold 1.5s.
Old 09-18-2011, 01:00 AM #12
Good call.
What's the reasoning behind making the rear 0.5" narrower?
Old 09-24-2011, 11:37 AM #13
Baja Runner's Avatar
Baja Runner Baja Runner is offline
Baja Runner is on a distinguished road
Yep. I just added some 1.25" spacers I had in my garage, and I am rubbing on the pnch weld now. I was not rubbing beforehand. And I am running 2" of lift up front.
I guess I need to start doing some cutting....
2005 Limited V8 4x4 4Runner
2005 SR5 V8 4Runner
1997 40th Anniversary FZJ80
2001 Ford F350 w/ FWC Hawk
Baja Runner is offline   Reply With QuoteReply With Quote
Old 09-24-2011, 09:14 PM #14
Victor Victor is offline
Victor is on a distinguished road
Whoa! Talking about 1.5-2inch! 1.25 is the max you guys should run, depending on the wheel offset. Eg: Stock wheels + 1.25 spacers are plenty good. You start going bigger spacer, you're looking at wheel bearing replacement much much sooner and more often. Especially if you guys wheel your trucks! I'm running Sequoia 17 inch wheels with the All-Pro 1.25 spacers, it see's a lot of wheeling and touring duty. I've replaced both front wheel bearings this past june.
Victor is offline   Reply With QuoteReply With Quote
Old 09-24-2011, 09:31 PM #15
Dang. I hope it's not too bad. Not a big fan of trimming.
I have the Sequoia's too. Is yours a Limited? I really want my tires flush with the flares.
WTB: 4th Gen "4Runner," "Limited," and "Toyota" badges James_T Want to Buy/Trade 3 06-25-2011 11:42 AM
Zero point didnt work how to turn off "VSC TRAC" & "VSC OFF" & "ABS" lights sciff5 4th Gen T4Rs 6 09-27-2010 12:10 AM
"fog lights", front "grill?", and sport model questions mkingphoto 3rd gen T4Rs 2 03-31-2007 09:47 AM
2.5" Rear & 1.5" Front Cornfed Spacers for sale... ravencr Classifieds - buy & sell (no commercial ads please) 0 11-27-2005 10:15 PM
problem solved. yipeeee. thanks to "live4swell" here & "jataga"from 4x4Wire. Michael Maintenance/Detailing 1 11-23-2004 01:29 PM
