Old 09-21-2011, 02:27 AM #1
masson74's Avatar
masson74 masson74 is offline
Real Name: Dave
masson74 is on a distinguished road
masson74's Avatar
Real Name: Dave
HELP!!!! Do I need new bump stops or UCA's
I have read alot and done about an hour of research on the forum and still dont know what I need
So I was wheeling last weekend on a difficult rated trail (Heartbreak Ridge/Pontiac near Big Bear, CA) and came down a steep trail and had to make a sharp right hand turn. I was creeping down the sharp turn and the rubbing was insane and very loud. my tire had complety compresed under the weight up into the wheel well. In doing so my 285's ripped the bolt off of my Limited fender flares and now I have to repair them. After they were flapping around and rubbing a ton the rest of the trip.
I do have alot of weight upfront as I have an OutdoorLogic bumper and a winch. I am running the OME 882 and OME struts and shocks. I have a one inch body lift. I have 1.25 wheel spacers upfront. I have cut down the pinch weld and done some minor trimming but am tired of the rubbing?
What do I do? New bump stops? Would aftermarket UCA's help? Any tricks on keeping the flares from ripping off like that?
Thanks guys.
Dave
00 Limit. 4x4, 2.5 ICON coilovers w/ remote reses CDC valve front and rear , Rear Locker, Nitto Trail Grap.285's, BajaRack,1 in. body lift, Savage Offroad Rear bumper, spacers, sliders and full skids, ODL bumper, xrc8 winch, Deckplate Mod, VIAIR Heavy Duty onboard air, ICON UCA"S, Budbuilt diff skid, 4.88 G2 performance gears
masson74 is offline   Reply With QuoteReply With Quote
Old 09-21-2011, 03:03 AM #2
00_4runner's Avatar
00_4runner 00_4runner is offline
00_4runner is on a distinguished road
00_4runner's Avatar
Thanks guys.
Dave
New bumpstops are made for the rear axle if thats where the rubbing occurs and they prevent too much axle travel. I guess this could prevent some rubbing in the rear but Im not sure. As far as the front goes it depends on where your rubbing. Im sure someone will comment on the front soon.
00_4runner is offline   Reply With QuoteReply With Quote
Old 09-21-2011, 03:09 AM #3
masson74's Avatar
Real Name: Dave
masson74's Avatar
Real Name: Dave
Its rubbing closest to the back of the front tire or you could say closest to the door
Old 09-21-2011, 08:28 AM #4
Baja Runner's Avatar
Baja Runner Baja Runner is offline
Baja Runner is on a distinguished road
Bumpstops will just limit your uptravel in the front. Its a precious thing to loose though, but, it would work. I don't see how A-arms would limit the travel, it would just increase (only slightly) if anything.
Id personally just try my best to do some trimming where you're hitting. That, or go for a topout spacer on your 882's, or new coils, or a coilover.
2005 Limited V8 4x4 4Runner
2005 SR5 V8 4Runner
1997 40th Anniversary FZJ80
2001 Ford F350 w/ FWC Hawk
Baja Runner is offline   Reply With QuoteReply With Quote
Old 09-21-2011, 10:57 AM #5
Singtoe's Avatar
Singtoe Singtoe is offline
Singtoe will become famous soon enough
Singtoe's Avatar
You probably need another body lift to get the clearance your looking for.
I would buy your old one if you decide to go that route.
1999 Limited 4runner in Silver - 9th and 10th Injected TRD Supercharged 4.7 2UZ-FE swap - AISIN Manual hub lockers - Retrofitted E-locker - Downey Off road Coilovers & adjustable Pan Hard Bar - Whelen PA - 2" Personally made Body Lift - Eclipse Navigation Radio - Spider Trax - Custom Hidden Winch - Triple Electric Fans - Running boards off then back on again - Ghetto Cold Air Intake - Sequoia Brakes - V8 Badge (for extra horse power)
2002 SR5 Tacoma Extended Cab also in Silver On 37's and Guns for sale
Singtoe is offline   Reply With QuoteReply With Quote
Old 09-21-2011, 12:38 PM #6
J-money$$$'s Avatar
J-money$$$ J-money$$$ is offline
J-money$$$ is on a distinguished road
J-money$$$'s Avatar
Take a BFH and smash the pinch weld on the firewall until its out of the way. Then you probably want to cut some of the plastic fender lining off. THe loud rubbing tends to be the tire rubbing on that plastic
If your UCA bushings are bad enough to let the tire move back then it would be obvious. I had mine go out and that happen.
And You DONT need more of a body lift! People fit 35's with minor trimming and a 1" body lift. Trust me I just helped clearance Brian2suns fenders/firewall to fit 315's. If we got 35's in there with no rubbing , you can get 285's in there
check out my build thread My Build
J-money$$$ is offline   Reply With QuoteReply With Quote
Old 09-21-2011, 02:33 PM #7
masson74's Avatar
Real Name: Dave
masson74's Avatar
Real Name: Dave
Thanks J money. How do I keep the limited flare attached if I remove all the plastic? Can I just screw the limited flares anywhere into the body? When this happened the retainers that hold the screws in popped out.
Dave
Old 09-21-2011, 02:36 PM #8
J-money$$$'s Avatar
J-money$$$'s Avatar
those limited flares should be attached to the outside of the fender for the most part. They may have screws in the wheel well, but they also have those body clips. I would just remove the first couple screws and see how flimsy it is
Old 09-21-2011, 08:07 PM #9
Dirtco's Avatar
Dirtco Dirtco is offline
Real Name: Jeremiah
Dirtco is a name known to all Dirtco is a name known to all Dirtco is a name known to all Dirtco is a name known to all Dirtco is a name known to all Dirtco is a name known to all
Dirtco's Avatar
Real Name: Jeremiah
Here is how I clearanced mine, it's a 99' Limited with a 1" body lift and 35" MTR's. There's more pictures in my build thread (starting on page two); Dirtco's 1999 4Runner Build
And the fender back on
From the side it looks stock
Dirtco is offline   Reply With QuoteReply With Quote
Old 09-21-2011, 09:06 PM #10
masson74's Avatar
Real Name: Dave
masson74's Avatar
Real Name: Dave
Thanks Dirtco, now we are are going down the right path but How is the plastic flare being held on? I dont see the bolt holding the plastic on anymore. Awesome rig by the way!!!!
Old 09-22-2011, 09:19 PM #11
Dirtco's Avatar
Real Name: Jeremiah
Dirtco's Avatar
Real Name: Jeremiah
The bolt is missing in the pictures. I went to the hardware store and got a couple pan head screws to replace the bolts; they are smooth in case the tire rubs the fender. The rest of the hardware is stock.
Thanks!
Old 09-22-2011, 11:26 PM #12
masson74's Avatar
Real Name: Dave
masson74's Avatar
Real Name: Dave
Ding ding ding!!! and we have a winner! Thanks Dirtco. I will give it a shot. I appreciate everyones help!!!
Dave
WTB - Cone bump stops 3rd gen mizzle415 For Sale: Suspension/Wheels/Tires 0 08-19-2011 05:33 PM
Lower the Bump Stops? P6725 Engines / Suspension / Wheels / Tires / Audio / Accessories 1 06-23-2011 11:42 AM
Rear Bump stops Singtoe 3rd gen T4Rs 1 03-06-2011 10:15 PM
Loose bump stops mechagouki Classic T4Rs 0 10-06-2010 06:17 AM
Bump Stops (Daystar 2.5/1.5) DonnyB 4th Gen T4Rs 11 09-26-2010 03:05 AM
