01-04-2012, 12:25 PM
#31
Hey man just wanted to thank you again for the taillights, I sure do like the newer ones better like you currently have! Clean rig by the way!
- 1998 4Runner SR5 5VZ-FE Auto + RR Diff Lock [Build Thread Here] - Sold!
- 1984 Pickup XtraCab 22R 5spd - Sold!
- 2002 4Runner Limited - Stock!
- 1972 Hilux Pickup 5spd 2rz Swap - Lowered, Enkei 92's
- 1988 4Runner 5spd 5VZ Swap - Zuk Mod, 265/75 Duratracs!
01-04-2012, 01:36 PM
#32
Purpose: Get rid of bubble on dash cluster
Process:
Obtain used cluster of same year
Remove cluster from car
Remove plastic cover from cluster
Using a fork, pull straight and remove gauge needles
Do the same on the donor cluster
Swap in new face
Remove needles with a fork
Needle removed
Repaired
Happy to do it. I hate to toss good parts and didnt want to do the c-list haggle.
01-04-2012, 04:34 PM
#33
Moderator
Real Name: Waldo
Moderator
Real Name: Waldo
someone needs to look into getting photobucket ;)
Nice truck, it's coming along great...
'99 Toyota 4Runner LTD - Dual Locked | Geared | Mid-Travel | 35s | Armored
01-04-2012, 11:03 PM
#34
Originally Posted by Brilliant
I haven't messed with it much yet honesty.
I read on the site you can read and reset codes, but not something I have tried to do as I am not throwing any codes. The MPGs seem reasonable, but I've mostly been running around town and it jumps around a lot.
The company is pretty responsive so if you are in a hurry shoot them an email and they should get back to you.
Once I get my dash figured out, I'll play with it more.
sweet! i'm just waiting for that last push to get me to bight the bullet and get this thing. I've been watching endless YouTube videos on it. haha i know i want it!
Now when you say you have to order it specifically for your car its just the Toyota one right? and does a Toyota logo pop up when you start your engine?
01 SR5 SPORT
Many mods done, Many more to come
Build Thread
http://www.toyota-4runner.org/3rd-ge...ld-thread.html
01-04-2012, 11:25 PM
#35
Damn you Brilliant, you're giving me too many ideas for mine. LOL. Looks great, good work.
01-06-2012, 07:58 PM
#36
thanks man im this close to ordering it!
01 SR5 SPORT
Build Thread
01-08-2012, 10:53 PM
#37
That bubble really was bugging you wasn't it? Did you buy the new cluster just for that guage face?
I have the same issue, but my bubble is about 1/16 the size of yours. Just a little guy that seems to inflate and deflate depending on ambient temps. When it's cold it's almost flat, when it gets hot, it bubbles up. Did you notice the same thing with yours?
I'm going to leave mine alone until it gets worse (hopefully it doesn't). Yours looked like it was almost big enough to interfere w/the tach needle.
RE the cluster lights... I will simply never be cool w/red. When I see that, it screams PONTIAC GRAND AM!! Toyotas and green dash lighting just go hand in hand for me.
01-08-2012, 11:17 PM
#38
Real Name: Instagram: briansd_97r
BigFishAllDay
It's got a lot of functionality to it. I would definitely have considered that in place of my SG2 if I'd have known it existed.
The AeroForce gauge looks pretty good but is bit more cash than a SCII.
Brilliant, did you pay the full $250 for it and do you think it was worth it after owning it for a few weeks?
Thanks
Those he commands move only in command, Nothing in love. Now does he feel his title, Hang loose about him, like a giant’s robe, Upon a dwarfish treasonous thief.
01-08-2012, 11:27 PM
#39
I bought a whole used cluster from ebay..........
Where is your bubble? - I can send you the face if its not the tach. I have both a 96-98 and 99 cluster (same as 01?).
Oh no, I got that you bought the whole cluster, I was asking if you bought the cluster JUST to get your hands on a new guage face? What was your winning bid on the cluster?
My bubble is, luckily enough, on the tach. It's located right where the upper LH corner of your bubble was located. Thanks for the generous offer though.
#40
Originally Posted by brianemc2_42
BigFishAllDay
Thanks
It was an impulse buy and I still havent messed with it much.
Would I do it again, probably. I wanted the MPG computer and I just couldnt bring myself to put in a scangauge. It was an appearance thing more than anything.
I'll make an attempt this week to figure it out and post.
01-08-2012, 11:34 PM
#41
Objective: Remove puke green dash lights, replace with red for better night vision but mostly appearance
Process:
Remove all lights, determine wedge style bulb size and quantity for cluster/switches
Use red light film for clock
Solder in red leds into window lights
Parts List
Cluster - 3 x - Type 24 | T6.5 wedge
Key - 1 x - Type 74 | T5 wedge
Ashtray - 1 x - Type 74 | T5 wedge
AT Shifter – 1 x - Type 24 | T6.5 wedge
Glove Box – 1 x Type 74 | T5 wedge
Rear Window button- 1 x – Type A | T3 8mm Japanese Instrument panel bulb
ECT/Rear Defroster - 1 x - Type A | T3 8mm Japanese Instrument panel bulb
Climate Control – 2 x – Type A | T3 8mm Japanese panel bulbs & 2 x - Type B | T4 10mm Japanese panel bulbs
Flasher - 1 x – Type A | T3 8mm Japanese panel bulbs
Cig Lighter – Custom. I pulled the old bulb out, cut off the housing from a Type 74 so it was bare LED, wires, and resistors. I put it in with a tad of silicone.
Window Switches – Micro LED, requires printed circuit board solder, modified type 74s.
I used superstars with lens covers for the Type 24s for the cluster and AT shifter. The 3 LED ones do not fit, they are too loose (maybe glue them if you want). I used narrow LEDS for all the Typa A & B, dont buy they wide square heads, they will not fit the ECT and rear window button well.
Finally I can see my climate controls!
Puke green/yellow wasn't an option for color match, so I went green.
Note: some trimming of the Type A and B bulb's locking 'slats' had to be done to make them fit. I used a hobby knife and pliers to hold the bulbs.
Where I bought them:
LED Lights, Bulbs & Accessories - SUPER BRIGHT LEDS
Automotive Car Truck Light Bulb Connectors Sockets Wiring Harnesses Receptacles
Bulb Guide: Automotive Bulb Visual Finder
I had 1 cluster, key ring, ECT, rear window, AT boot, climate controls, and glove box all out by previous owner. All better now. Hopefully this helps other limited owners sort it out what they need, but fix them. Its super easy.
OK bummer man. FYI the bubble is very very thin.
but yea. I bought the cluster just to get the face. I paid $70 for the cluster but I'd check a yard first. I got another cluster to experiment with for 40 IIRC.
01-09-2012, 03:11 AM
#42
Real Name: Alex
Real Name: Alex
I also have a bubble on my tach about 1/10 the size of yours. Doesn't bother me much, rather at all.
About the red lights though, you used a filament bulb, right? If so, is your redline still a darker shade of red than the regular areas?
2006 Lexus GX 470 Sport- RR Diff Lock, Metal Tech Sliders, RCI Aluminum Skids, Front Runner Slimline II Rack, SCS F5s, 255/80R17 ST Maxx , OME BP-51s, Dirt King UCAs, Metal Tech RR Lower Links
2016 Lexus IS300 F Sport- F-Sport Air Filter RR Racing tuner
01-09-2012, 03:48 AM
#43
your oil light is on sir... Saw it in your night time pic of the gauges. lol
Nice job on the truck man coming along nicely.
97 4runner limited, Toytec ultimate lift, 285/75 r16 duratrac, ISR mod, deckplate mod, airflow snorkel,1" diff drop, custom roof rack,Dual red top optimas w national luna solenoid, custom tube bumpers Front and rear with tire carrier, smittybuilt xrc 10000lb winch, synthetic rope, Cobra CB w 4' firestick, Rear e-locker retrofit, Manual hubs, Tundra brakes, 99 Console and head lights. Budbuilt ifs skid
Future mods. custom skids, custom sliders, tube doors, quality offroad lights lol...
01-09-2012, 12:06 PM
#44
I used a 120 degree LED. The redline is not visible anymore at night anymore. Oh well... I am happy that everything matches better now and red works better for me at night.
If you have a AT, I have a gauge face without a bubble if it gets worse or you want to fix it. Just let me know. I am not going to be using it.
Originally Posted by jmt2404
your oil light is on sir... Saw it in your night time pic of the gauges. lol Nice job on the truck man coming along nicely.
The ignition is ON but its not running, but thanks for looking out. =}
01-09-2012, 03:29 PM
#45
I figured it was. Did you ever get a new bumper?
I still have mine for sale if you want to take a look at it.
Thread Tools |
Display Modes |
Rate This Thread |
Linear Mode
