Thread Tools Rating: Thread Rating: 6 votes, 4.33 average. Display Modes
Old 01-22-2020, 02:33 AM #556
Wikano's Avatar
Wikano Wikano is offline
Wikano is on a distinguished road
Wikano's Avatar
Originally Posted by Brilliant View Post
[B]Objective: Add hidden winch, be able to do straight pulls to get myself out of trouble
If your were to do it again, would you have done anything differently?
98 4runner, 5speed, 2.7L 3rz, 370,000 miles, 2x4, OEM Elocker, 4.30 gears, ToyTec Ajustable Coilovers wit 500lb spring and lots of other goodies.
Wikano is offline   Reply With QuoteReply With Quote
Old 02-19-2020, 12:09 AM #557
Brilliant's Avatar
Brilliant Brilliant is offline
Brilliant is on a distinguished road
Brilliant's Avatar
I would have done drawn the plate and had it cut on a table
Brilliant is offline   Reply With QuoteReply With Quote
Old 05-28-2020, 10:08 PM #558
CWccw CWccw is offline
CWccw is on a distinguished road
On a road trip last year I used a bucket of window wash at a gas station on my headlights to clean off all the bugs. Something was in it that ate the clear coat off the headlights. I had been rolling with these discolored lights for some time and was a constant irritant.
I wasnt sure I could fix it with a restore kit, and didnt want to screw them up further. Today was the day, either it was going to get better or I'd be buying a new set. I bought a 3M kit and it seemed to work well. Not sure if it will hold up to time, but huge improvement.
BEFORE
AFTER
Ha, not sure if I will ever sell it or evolve it into more of a trail rig. I am going to get a LC200, probably next year and it might go up for sale then.
Where do I get these headlights? I saw them once in a post from Russia. Also saw some dual bulb corner markeres.
98 SR5 4wd, CS144, compass/temp mirror, 2nd gen Hilux Altimeter/Inclinometer ,Chinese knock off diesel heater, Chinese copy of Alpicool CX50, OME 3" lift, 1" Toytec body lift, Snorkel, 13WE, Borla catback, Android hu, LED H4
CWccw is offline   Reply With QuoteReply With Quote
Old 09-13-2020, 03:04 PM #559
bryanbgw's Avatar
bryanbgw bryanbgw is offline
bryanbgw is on a distinguished road
bryanbgw's Avatar
Objective: Get more light in the back hatch
Process:
  • Source a rear interior light from a yard
  • Run a wire from rear interior light
  • Make a template, trace the pattern, and cut
  • Glue in light with epoxy
  • Install LED panels
We should do that. I like going fast rather than crawling and don't want to beat up the body.
By the way, your recent coilovers were why I ended up looking for a set. I was talking about and showing your 4runner to the GF last week.
So where do you get power from when wiring this ?
bryanbgw is offline   Reply With QuoteReply With Quote
Old 09-17-2020, 06:10 PM #560
datsuyama datsuyama is offline
datsuyama is on a distinguished road
Wow. This is an amazing build
Dude, the love and dedication you put into transforming this rig is nothing short of amazing. I've only made it through half of the thread but just absolutely love the work you've done.
datsuyama is offline   Reply With QuoteReply With Quote
Old 10-20-2020, 01:47 PM #561
Ashura's Avatar
Ashura Ashura is offline
Ashura is on a distinguished road
Ashura's Avatar
How is it guys, does anyone have a writeup on the tire carrier install? Looking to purchase and I'm fascinated by the Japanese Domestic Market stuff and would like to get a Japanese version tailgate and the tire carrier but I am not finding a write up on the carrier installation process.
OP were you able to install it? If so can you please share?
[B]Purpose: Install Surf hatch
practicing on a door
Hatch found on ebay
large spoiler removed
mounting holes to weld up
welding filler plates
welded, ready to finish and fill
finished, ready to take to body shop for final finish and paint
Ashura is offline   Reply With QuoteReply With Quote
Old 10-23-2020, 04:43 PM #562
Ashura's Avatar
Ashura's Avatar
Nice
Nicely done on the hatch, so the carrier piece; i take it that that is reinforced behind the body. What kind of tubing setup did you use? Have you had any issue with the carrier separating from the body due to strain? Came across a hatch like yours on ebay and working with the seller now on the shipping. Thanks
First day I was able to make any measurable progress on the surf hatch.
Couple things I didnt know when buying a hatch. There are 3 styles of spoilers, mirrored, diving board, and the small one that Jaos/bertman have replicated. Both the diving board spoiler and the mirrored spoiler are paired with a different hatch then the small spoiler.
The mirrored version has a hole in the sheetmetal for brackets and for the harness to pass through. Something to keep in mind if you want to interchange spoilers.
I began patching the holes in the panel today.
Got the hatch holes patched and a small amount of filler applied. Took a bit of time to tact in the patch. Also drill a hole and ran the wire for the rear light.
Also put a coat of paint on the carrier. The hinge isn't frozen any longer after using most of a can of pb blaster. I got this for $30 and didn't know until I got it why it was so cheap.
Excited to get this on today, but too tired to finish it. I had them paint the licence plate light body color to make it cleaner on the rear.
I had to pull the emblem off and fill the cover panel but I think its going to look much cleaner than the black light.
Old 10-30-2020, 02:12 PM #563
T4RJJ T4RJJ is offline
T4RJJ is on a distinguished road
Cool
[QUOTE=Brilliant;949666]Objective: Remove puke green dash lights, replace with red for better night vision
Process:
Remove all lights, determine wedge style bulb size and quantity
Solder in red leds into window lights
any details on how you did the light for the climate control? Mine is out and i want to replace it when I do the backlights for the dash... all I've been able to find is the part #'s for oem replacements
T4RJJ is offline   Reply With QuoteReply With Quote
Old 11-26-2020, 04:32 PM #564
Ashura's Avatar
Ashura's Avatar
He's no longer active but if you search, I believe Ripcord and a couple of others have full writeups of bulbs and everything.
Old 11-26-2020, 07:57 PM #565
Twan's Avatar
Twan Twan is offline
Twan will become famous soon enough Twan will become famous soon enough
Twan's Avatar
LED Dash lights FAQs
2000 SR5 Sport - 4EAT and E-locker, King 2.5s, EimKeith PCK, SPC UCAs, 33" KO2s on Black Rhino Boxer gloss gold 17x8.5, Savage/Lotus skids, 4xInnovations front bumper/sliders, Shrockworks bumper & tire carrier, Lil Skip Gas Tank Skid, Magnaflow Overland cat back
Twan is offline   Reply With QuoteReply With Quote
Old 01-03-2021, 03:50 PM #566
Gegene Gegene is offline
Real Name: Raphaël
Gegene is on a distinguished road
Real Name: Raphaël
He wrote he got them from Rumin sports. And I do have them too. But as the plasic of the lens holder did not match my expectations I replaced it with somethig more solid. And put real HID in.
The truck looks gorgeous with those headlights :-)
Raphaël
Brilliant's Mod Thread-rumin-headlights-jpg
1997 4Runner 4x4 SR5 3.4l
Gegene is offline   Reply With QuoteReply With Quote
Old 12-27-2021, 06:46 PM #567
Brilliant's Avatar
Brilliant's Avatar
Climate takes the same wedge style led bulbs, 4 IIRC. I forget what size. Since my climate is again on the fritz, ill be replacing them again soon.
Started the runner for first time in 9 months... started right up (after replacing the battery). Kinda frustrating, 31M battery from odyssey swapped terminal sides and kept the same part number. I ended up wasting a lot of $ on shipping to find that out. I had to revert to a 34 and buy an new tray/holder.
We had some snow and it will linger for a weekish and the ms. needs something to drive.
Old 12-28-2021, 03:11 PM #568
busmup808's Avatar
busmup808 busmup808 is offline
busmup808 is a jewel in the rough busmup808 is a jewel in the rough busmup808 is a jewel in the rough busmup808 is a jewel in the rough
busmup808's Avatar
Howzit Brilliant! It’s been a while. Good to here the truck is alive and well. The group 34 by Odyssey is different than the ones I’m running. They have a different part number. We should go out exploring a day before I move back home. Brilliant's Mod Thread
Busmup808 all day, all night!
busmup808 is offline   Reply With QuoteReply With Quote
Old 04-08-2022, 09:46 PM #569
Brilliant's Avatar
Brilliant's Avatar
Plain center caps for FJ/tundra wheels cab be found on ebay... I seem to get PMs more on this than anything. Hope it helps... These will fit the FJ wheels I run.
4Pcs Sequoia Tundra 03-07 Wheel Center Hub Caps Silver 56069440 For Toyota
4Pcs Sequoia Tundra 03-07 Wheel Center Hub Caps Silver 56069440 For Toyota | eBay
Old 04-08-2022, 09:59 PM #570
octanejunkie's Avatar
octanejunkie octanejunkie is offline
Real Name: C8H18 Mike
octanejunkie has much to be proud of octanejunkie has much to be proud of octanejunkie has much to be proud of octanejunkie has much to be proud of octanejunkie has much to be proud of octanejunkie has much to be proud of octanejunkie has much to be proud of octanejunkie has much to be proud of octanejunkie has much to be proud of octanejunkie has much to be proud of
Curious that they've blurred out the Toyota logo on that eBay ad LOL
For some reason none of the pictures in your thread are showing up for me
Sent from my Pixel 4 XL using Tapatalk
1999 Toyota 4Runner SR5 Un-Sported 2WD, V6 Auto ->2WD 4runner Journal Thread
octanejunkie is offline   Reply With QuoteReply With Quote
Not another DRL thread domstriker 3rd gen T4Rs 23 06-29-2017 03:20 PM
This thread is a build thread. TacticalSR5 3rd gen T4Rs 24 12-30-2011 05:35 PM
Another:What is this? thread. cabowally 4th Gen T4Rs 7 07-03-2011 10:59 AM
First Thread - Need Help with my 87 SR5 justgio928 Classic T4Rs 9 01-28-2011 05:40 PM
Hi all!!!! first thread 4me here! bolt 4th Gen T4Rs 2 04-11-2006 12:49 AM
