Old 09-26-2011, 06:05 PM #1
RiverRat37's Avatar
RiverRat37 RiverRat37 is offline
RiverRat37 is on a distinguished road
RiverRat37's Avatar
brake fluid or differential fluid?
Hey everybody I have a question about brake fluid and/or differential fluid. One of the newest 4Runners I've been looking at to buy has a leak that I'm thinking is brake fluid but I've been told it could be diff fluid. It is damp on the underside of the hub like I've seen brake fluid do before and to me it smells like brake fluid. It seems thin and smooth and fairly clear when you rub your fingers together like brake fluid does. How can I tell by looking at it which fluid it is? Thanks
RiverRat37 is offline   Reply With QuoteReply With Quote
Old 09-26-2011, 06:58 PM #2
LittleCaesar's Avatar
LittleCaesar LittleCaesar is offline
LittleCaesar is just really nice LittleCaesar is just really nice LittleCaesar is just really nice LittleCaesar is just really nice
Move on, there are better ones out there. More than likely it is diff fluid if it is coming from the rear axle.
LittleCaesar is offline   Reply With QuoteReply With Quote
Old 09-26-2011, 07:00 PM #3
RiverRat37's Avatar
RiverRat37's Avatar
How bad of a problem is it if it is differential fluid? I'm going to get it at a good price if I so chose. How much would it cost if it was the diff fluid seal on that particular side?
Old 09-26-2011, 07:16 PM #4
Baja Runner's Avatar
Baja Runner Baja Runner is offline
Baja Runner is on a distinguished road
Uh... Moving on just because of a axle seal leak?! That would be stupid. They are one of the most common issues with these trucks, and are extremely easy to replace. The seal from Toyota is ~$20 and takes maybe 30 minutes to swap out.
Yeah you're supposed to change the brake shoes as well if they are saturated with diff fluid, but I often clean them good and don't have problems.
If the brake fluid is not low then you can pretty much assume its an axle seal.
2005 Limited V8 4x4 4Runner
2005 SR5 V8 4Runner
1997 40th Anniversary FZJ80
2001 Ford F350 w/ FWC Hawk
Baja Runner is offline   Reply With QuoteReply With Quote
Old 09-26-2011, 07:31 PM #5
Dous's Avatar
Dous Dous is offline
Real Name: Casey
Dous is on a distinguished road
Dous's Avatar
Real Name: Casey
If it was brake fluid it would probably be the wheel cylinder and that is very easy to replace, I don't think an axle seal is that hard. Seems like it would be pretty easy to differentiate between brake fluid and gear oil, but who knows.
'98 4runner | SAS'd | Locked F/R | Armored | Supercharged | URD Goodies |
My Build Thread
Dous is offline   Reply With QuoteReply With Quote
Old 09-26-2011, 08:31 PM #6
zcruiser's Avatar
zcruiser zcruiser is offline
zcruiser has a spectacular aura about zcruiser has a spectacular aura about
zcruiser's Avatar
Brake fluid - Caustic, will eat your paint and burns your skin
Gear oil - Won't
2012 4Runner Limited, Shoreline Blue Pearl / Beige leather, RCI skid, ext rear diff breather, Derale 13504 cooler, 110K
1993 300ZX Cherry Red Pearl with some bling, K&N intake, PowerTrix suspension, 130K
zcruiser is offline   Reply With QuoteReply With Quote
Old 09-26-2011, 10:13 PM #7
I agree, the axle seal is not that hard. And since it isn't, why wouldn't the seller change it before selling the 4runner? So, as a cynic, it makes me wonder: what else is the seller not disclosing?
If it is a great deal, then definitely take a second look by all means. The DIY fix is not that hard and there are some good write ups on how to repair those seals.
Take some pics of it and post them if ya can.
Old 09-26-2011, 10:17 PM #8
RiverRat37's Avatar
RiverRat37's Avatar
ok thanks for your input guys.. If I was to buy it I'd post some pics but I'm still shopping around for a good buy... When I get something I'll post it... You guys have helped me learn a lot in the last couple weeks. Thanks
Old 09-26-2011, 10:21 PM #9
RiverRat,
If you haven't read through this thread, do so. It covers more than everything ya need to know. If you have more questions, just ask.
3rd Gen 4Runner Buyer's Guide
Old 09-27-2011, 08:42 AM #10
Nelsonmd's Avatar
Nelsonmd Nelsonmd is offline
Nelsonmd is on a distinguished road
Nelsonmd's Avatar
Not even that, I just picked up 4 at $5 each. Had to add shipping, but I got other parts as well, so the average piece price for the seals was really only about $6.
Yeah, either way it shouldn't be too hard or expensive to fix. They should definitely smell different. Pop the filler plug and dip your finger in, smell it, see if it smells the same as what is coming out of the hub.
OP, you are talking about the rear right? If it is the front, then it is definitely brake fluid because the diff fluid doesn't reach the hubs in front.
2000 SR5 3.4L V6 Automatic 4x4, e-locker, 175k Miles, Rust
Imp. Jade Mica with Oak Leather Interior, Field Monitor Unit - B&M Tranny Cooler - SG2 - New (to me) rear axle assembly - Goodyear Duratrac 265/75-16 - 1.8" Ironman Front Lift, OME 906/Procomp 9000 Shocks
http://www.toyota-4runner.org/3rd-ge...ld-thread.html
Nelsonmd is offline   Reply With QuoteReply With Quote
Old 09-27-2011, 08:59 AM #11
cordrayj1's Avatar
cordrayj1 cordrayj1 is offline
Real Name: Johnny
cordrayj1 is on a distinguished road
cordrayj1's Avatar
Real Name: Johnny
you will mos def know if its gear oil. that crap stinks. especially after when its old and used.
2000 4Runner SR5, 5vz-fe, 5speed, 246k miles, bfg 35's on stock 1985 4runner wheels
cordrayj1 is offline   Reply With QuoteReply With Quote
Old 09-27-2011, 09:00 AM #12
cordrayj1's Avatar
Real Name: Johnny
cordrayj1's Avatar
Real Name: Johnny
nelson,
where you getting your parts?
Differential fluid change toybox Maintenance/Detailing 166 08-02-2014 11:19 AM
Differential Fluid Mano1124 3rd gen T4Rs 35 07-15-2011 11:50 AM
Deep Mud/Differential Fluid USMC_4runner 4th Gen T4Rs 30 02-16-2010 05:22 PM
differential fluid orbit Maintenance/Detailing 4 01-02-2008 11:15 AM
Brake fluid, transmission fluid, and rear differential fluid NViejeP 4th Gen T4Rs 12 03-31-2007 03:43 PM
