Originally Posted by Tenn_volsfan56
Just normal driving on paved roads. No real change except it seems louder at slower speeds.
I replaced the front struts with a complete quick strut assembly and had an alignment.
roaring never comes from any suspension components, it's almost always something in the running gear, wheel bearings,gears and associated bearings, cv's, even the u-joints on drive shafts can make that noise.
but nothing in your coil over assy or suspension will ever make that noise, roaring is caused by rotational movement usually.
as far as replacing that stuff you would have been better off replacing the wheel bearing yourself and paying the shop to do the r&p bearings, not that it's hard i just hate opening the diffs up if there is any other way and if your this far in might consider doing a re-gear while your in there if it is the pinion bearing it will cost a bit more but saves you the work in future if your going to go with bigger tires and the rest. that said new gears can be had for around $400 for both front and back. and the bearings/install kit is around $75-100, so $600 total you have new gearing, or you can just spend $100 and buy the install kit for the front and be done with it.
first though try jacking the front end up put it into 4wd and nuet and try spinning the wheels by hand and see if you can locate for sure where the sound is coming from.
