Old 10-06-2011, 06:49 PM #1
azaware azaware is offline
azaware is on a distinguished road
Balance Shaft
I see some engine have balance shafts. I was just calling around about getting a rebuild. I thought the core I have was bad because the balance shaft through the back bearing and destroyed that area. To save a $500 core charge I called a builder to see if the core was rebuildable. He said they don't put balance shafts in so the core is good. He said "they found that the engine runs better and more reliable. Also Improved timing and oil pump helps". What do you all think? I wonder why they put the shafts in?
azaware is offline   Reply With QuoteReply With Quote
Old 10-06-2011, 07:54 PM #2
Singtoe's Avatar
Singtoe Singtoe is offline
Singtoe will become famous soon enough
Singtoe's Avatar
It is a scam. Stay away.
1999 Limited 4runner in Silver - 9th and 10th Injected TRD Supercharged 4.7 2UZ-FE swap - AISIN Manual hub lockers - Retrofitted E-locker - Downey Off road Coilovers & adjustable Pan Hard Bar - Whelen PA - 2" Personally made Body Lift - Eclipse Navigation Radio - Spider Trax - Custom Hidden Winch - Triple Electric Fans - Running boards off then back on again - Ghetto Cold Air Intake - Sequoia Brakes - V8 Badge (for extra horse power)
2002 SR5 Tacoma Extended Cab also in Silver On 37's and Guns for sale
Singtoe is offline   Reply With QuoteReply With Quote
balance problem Gstick Engines / Suspension / Wheels / Tires / Audio / Accessories 10 09-16-2011 05:45 PM
Alignment & balance in STL MO? ryangab 4th Gen T4Rs 2 09-07-2010 02:04 PM
bfg at ko and balance issues wdhigh 3rd gen T4Rs 12 06-24-2009 10:25 PM
Tire Balance Question jeb 4th Gen T4Rs 9 10-04-2005 05:42 PM
which alloys are hard to balance? bflooks 3rd gen T4Rs 3 02-03-2005 10:27 AM
