10-08-2011, 03:50 PM
Tundra brake upgrade question?
I was wondering if i can do the upgrade with the factory 3 spoke wheels? Let me know guys thanks.
1998 4Runner SR5
Mods: lift, tires, cb radio, blacked out things.
Future mods: Center Console Swap, Exterior lighting, Roof Rack, ARB-AIR Lockers
10-08-2011, 04:12 PM
Not unless you get wheel spacers or shave the inside face of the rims a little.
2021 Tacoma 4x4 TRD Off Road Double Cab Short Bed (my DD)
2017 4Runner 4x4 Limited (the wife’s)
10-08-2011, 05:16 PM
Which Tundra kit? I believe the 199 will work but not the 231.
10-08-2011, 06:15 PM
You're right, I believe the 199s will work.
10-08-2011, 06:54 PM
Ok thanks guys just wanting to know. So if i buy a 17inch wheel they would fit no problem then right? since the tundras do have 17inch wheels?
1998 4Runner SR5
10-08-2011, 07:18 PM
Right. But they also fit with the 16" 5 Stars. (assuming it's the 231 Tundra kit). The 199 kit will fit with the Split Spokes.
10-08-2011, 07:24 PM
Not necessarily^. It's not the diameter of the wheel that matters (any 16s or 17s will clear the Tundras that way). But the Tundra calipers stick out past the mounting flange on the hub, so if the other mounting flange (on the wheel itself) is too close to the inside face of the wheel, the face will hit the caliper before it's sitting flat on the flange. Hope that makes sense.
Another option is to just run wheel spacers with 3 spokes. They will push the inside face of the rim away from the caliper.
10-08-2011, 07:27 PM
Ok Brian so your saying that it will fit depending on my backspaceing on the wheel? Another thing i could get 1" wheel spacers and be fine either way right?
1998 4Runner SR5
10-08-2011, 07:46 PM
It's not really the BSing. BSing is how far the inside edge (not face) of the wheel is from the mounting flange of the wheel. For instance, I have 4" BS on my Cragars (which you'd think would clear the Tundras just fine since they stick out 5/8" more than stock wheels), but they don't clear the Tundras without spacers because the inside face of that wheel is still too close.
10-08-2011, 07:53 PM
ok i get it now. Thanks. so i would be better off just buying a set of spacers then it sounds like.
1998 4Runner SR5
10-08-2011, 08:04 PM
Which Tundra kit are you planning in using? It will help us give you better advice.
10-08-2011, 08:07 PM
Probably the 231 set going as big as i can. Want more stopping power lol. another thing is i dont have to upgrade any brake lines or anything do i?
1998 4Runner SR5
10-08-2011, 08:24 PM
No line upgrade, just the calpiers, pads and rotors. I used the 5 spoke 99 and up wheels to clear mine. Worked great and they look better than my old corroded 97 wheels anyway.
1997 4runner Limited 4wd- Purchased new by family 12/96
Factory 4.30 e-locker conversion, 265/75 BFG AT, FX-R Hid Retrofit, Kenwood Nav, 231mm Tundra brakes, Grey FJZ80 Wheels, Deckplate mod, ARB Bumper, Hella 4000 compacts, Sonoran Steel 7.2a, Scangauge 2, Extended Diff Breather, Custom Sway Bar Endlinks, Black No Rust Rear Bumper
10-08-2011, 08:27 PM
Yea well i like the 3 spoke split wheel and mine are in perfect condition except for the center caps lol. So id like to keep my factory wheels.
1998 4Runner SR5
10-08-2011, 09:56 PM
You'll have to shave down the inside of the wheel to use them. Go with either the 5 stars or some 17" Tundra, Sequioa wheels. Or go with the 199 kit and keep your wheels.
