Originally posted by J.A.
Guys, thanks for the comps!
Kenn, the roof wire harness begins at the body ECU and is connector 1A. Pin #8 is a solid white wire connected to two other wires in a small flat ribbon type cable. It runs up the A pillar to the dome light. I believe it is the center wire in the ribbon but didnt double check this info myself.
Yep, you're right. it's a flat ribbon cable with 3 wires. it's white with three blue stripes. the center cable is the ECU one you want.
