cornfed 3/2
spidertracks on the rear (fronts rub on the body mounts when installed. once i get the body mounts chopped i should be able to run them)
FJ cruiser wheels 17x7"
295/70/17 nitto terra grabbers
love the ride. same as stock. road noise is minimal.
rear mud flaps have since been removed as they were quite close to the tread on the tires.
i tow with it and the setup works great. not a problem at all. super firm and doesn't rock or sway or float at all with 4000lbs or so behind it.
