Agreed it is likely a bulb issue. 'Fast blinking' indicates a malfunctioning or burned out bulb 99% of the time - on all modern makes and models.
If it were the fuse, it would not be affecting just 1 bulb (would likely be affecting all turn bulbs on all corners, parking lights too, maybe even more).
If it happens again, park, check to see which lights are working and which aren't. My bet says it is a lone turn signal bulb.
2008 Limited 4WD V8 - Titanium Metallic
Factory Nav Sys, Moonroof, Adjustable Height Control, X-REAS, most everything but rear-seat DVD system...Sirius Sportster 4 controlled via Nav Sys with Sirius Toyota interface and SVCDOC1
