Originally Posted by Uneek
It's going to be a bulb, more likely than a fuse.
I disagree, it's much easier to check a bulb. Put the signal or hazard on and do a walk around.
Most Japanese cars when the signals flash rapidly, it's a indication a bulb has gone out. You should replace the bulb quickly as extended rapid flashing will shorten the flasher's life.
Thanks!....The bulb it was! Took 5 mins.!
