Thread Tools Rating: Thread Rating: 14 votes, 3.57 average. Display Modes
Old 09-22-2021, 07:05 AM #196
BigNuge's Avatar
BigNuge BigNuge is offline
Real Name: Jim
BigNuge is on a distinguished road
BigNuge's Avatar
Real Name: Jim
Originally Posted by Addyme03 View Post
So, they STILL can’t figure it out. They have pulled all the codes from the car but none lead to a solution? I am just so frustrated! Been to the shop n back 3 times. Goes a long way freeway driving no problem but in town going 3 miles will quit and spontaneously restart no problem. This is really weird? Thanks for the feedback!
Does this 4R have an A/M remote start/alarm? This definitely should NOT have re-started itself, and this random shutdown stiff wreaks of a faulty remote starter.
2002 Sequoia Limited
As you sow, so shall you reap
BigNuge is offline   Reply With QuoteReply With Quote
Old 09-24-2021, 11:05 AM #197
Addyme03 Addyme03 is offline
Addyme03 is on a distinguished road
Thumbs down No A/M remote start all original
So there is no remote start. It was pointed out to me that she noticed it happening when she down shifts, bit not all the time, it is an automatic. She finally took it in the freeway and drove about 10-12 miles. It did not die on the way there but on the way home it died about 5 times in the first section before getting on the freeway and the second time it died she had to pull over and manually shut off and restart. It then died once on the freeway then spontaneously restarted. Cannot consistently replicate the issue? I have LOVED Toyota’s all my life but this has really shaken my faith.
Addyme03 is offline   Reply With QuoteReply With Quote
Old 10-11-2021, 10:50 PM #198
W.E.G. W.E.G. is offline
W.E.G. is on a distinguished road
...spontaneously just die.
...a month goes by and now it just died for no reason, loss of all mechanical and electrical full stop.
...They clean the throttle body and off we go and they are stumped as well.
...BOOM it dies 4 times and each time it starts up again ON IT'S OWN! I did not even have time to turn the key off before it starts again?
Probably an ignition switch issue.
The idiots who charged you for throttle-body cleaning as a supposed remedy for this issue are nothing but thieves. The idea that anything relating to the cleanliness of the throttle body has anything to do with the vehicle spontaneously shutting off or re-starting is beyond absurd. It is fraud.
The vehicles are wired such that once you turn the key to full crank position, you don't actually have to hold the key to the full crank position in order to cause the starter to keep turning until the engine fires. I don't care for that feature, but it is fundamental to understanding why your vehicle is cranking all by itself.
The only reasonable explanation is that the ignition switch is failing (internally) such that the switch activates the FULL CRANK POSITION without you actually turning the key to that position.
Similarly, since we are operating on the notion that the ignition switch is the culprit here, it is equally logical that the failing switch will fall (internally) to the IGNITION OFF position just as easily as it will fall to the FULL CRANK position.
The switch could be tested with a multimeter for correct operation in the various positions. Jostling the switch during testing may cause cause it to move to unintended positions, and may verify this to be the cause of the erratic behavior.
Frankly, I feel so certain that it is a failing mechanical switch that has seen long use in an old vehicle, I would just replace the switch, and I would lay strong odds this will cause the problem to cease. At worst, the problem remains and you have a new switch on your old vehicle, and you have elimintated the switch as a suspect.
Lastly, you DO NOT want to be taking that old vehicle to the TOYOTA DEALERSHIP for service. They are the absolute worst at helping owners of older vehicles. Just look at how they robbed you on that "throttle body service" for something that even a first-year technician should have immediately identified as an electrical issue.
If you are going to keep old vehicles, you must make it your life's mission to find an INDEPENDENT REPAIR SHOP that has competent technicians who are willing to work on older vehicles. Such shops do not advertise, and they always have long wait-times for service. If you are going to keep old vehicles, you have to accept these long wait times for competent service. Which unfortunately means you need TWO VEHICLES if you are going to use old vehicles as your daily driver. While vehicle A is down, you drive vehicle B. You have to get your head wrapped around the reality that it may take several weeks to get competent repair at an independent shop.
The only reason to take a vehicle to the dealership is for WARRANTY SERVICE.
W.E.G. is offline   Reply With QuoteReply With Quote
Old 11-05-2021, 07:35 PM #199
ToyoToyo ToyoToyo is offline
ToyoToyo is on a distinguished road
Service manuals
maybe someone will need it
4Runner Service Repair Manual. EWD - Free PDF's
ToyoToyo is offline   Reply With QuoteReply With Quote
Old 11-15-2021, 04:40 PM #200
Nitrosanity Nitrosanity is offline
Nitrosanity is on a distinguished road
Been looking for these, thanks OP!
Nitrosanity is offline   Reply With QuoteReply With Quote
Old 11-27-2021, 01:26 PM #201
rando's Avatar
rando rando is offline
rando is on a distinguished road
rando's Avatar
For whomever was just clicking it, I updated my link in post #110 ... should work again.
rando is offline   Reply With QuoteReply With Quote
Old 12-03-2021, 10:02 AM #202
mp52dave's Avatar
mp52dave mp52dave is offline
Real Name: David
mp52dave is on a distinguished road
mp52dave's Avatar
Real Name: David
This is what I needed - thanks!!
mp52dave is offline   Reply With QuoteReply With Quote
Old 01-05-2022, 04:41 PM #203
lpell7 lpell7 is offline
lpell7 is on a distinguished road
this is great stuff thanks for posting!
lpell7 is offline   Reply With QuoteReply With Quote
Old 01-13-2022, 08:52 PM #204
zameul40's Avatar
zameul40 zameul40 is offline
zameul40 is on a distinguished road
zameul40's Avatar
Manuals
Anyone else get a plain white screen when they click on the manual links?
zameul40 is offline   Reply With QuoteReply With Quote
Old 01-14-2022, 05:56 PM #205
damstr damstr is offline
damstr is on a distinguished road
Links seem dead now.
damstr is offline   Reply With QuoteReply With Quote
Old 03-13-2022, 10:40 AM #206
Mcolla882 Mcolla882 is offline
Mcolla882 is on a distinguished road
Thanks for this!
Mcolla882 is offline   Reply With QuoteReply With Quote
Old 03-13-2022, 12:31 PM #207
Jakeepoo3's Avatar
Jakeepoo3 Jakeepoo3 is offline
Jakeepoo3 has a spectacular aura about Jakeepoo3 has a spectacular aura about Jakeepoo3 has a spectacular aura about
Jakeepoo3's Avatar
Originally Posted by cabowally View Post
Thanks to AdamF and NCTTORA over at 4x4wire.com for putting up links to multiple FSM downloads. Here is what they have that is 4Gen specific:
2003 4Runner FSM
http://www.ezdries.net/Vidpics/4Runn...%204Runner.zip
2003 4Runner wiring diagrams
http://www.ezdries.net/Vidpics/4Runn...%20Diagram.zip
2006 4Runner FSM
http://www.ezdries.net/Vidpics/4Runn...pairManual.zip
Plus a bunch of other stuff here:
Toyota Tacoma/ 4Runner/ Tundra/ FJ Cruiser Factory Service Manual Page
You're a gentleman and a scholar for posting this information which should come with the truck. Next time I buy a vehicle I'll make sure they include the full FSM set. It's so much smoother and enjoyable to work on your vehicle without browsing the internet and endless forums for hours to find simple information! Anyone other gentleman out there have the 2010-2013 FSM's? I use the 2016-2020 which is great and mostly the same but would be in love with the one for my year especially the electrical section. Anyone know something?
Jakeepoo3 is offline   Reply With QuoteReply With Quote
Old 06-13-2022, 04:08 PM #208
clirizarry clirizarry is offline
clirizarry is on a distinguished road
Yo still da man! After 10years. Merci Beaucoup!
clirizarry is offline   Reply With QuoteReply With Quote
Old 06-14-2022, 01:29 PM #209
1950884 1950884 is offline
1950884 is on a distinguished road
Originally Posted by triethylborane View Post
Heres a CD, if you still have a reader
More Information for DAVE GRAHAM 03T4RUC
Digital factory repair manual for $30 is a fair deal. I ordered one. I'll let you know if it is anything other than what it is advertised as.
1950884 is offline   Reply With QuoteReply With Quote
Old 06-14-2022, 03:14 PM #210
Jakeepoo3's Avatar
Jakeepoo3's Avatar
Where is the electrical section!!! F_ck been looking for years.
Download 1996-2002 Service repair manual here! Carl58 3rd gen T4Rs 95 03-06-2024 11:20 PM
2010 4Runner Parts Manual download harper7 5th gen T4Rs 20 08-15-2019 04:16 PM
owners manual download? dustpan Classic T4Rs 2 02-26-2012 07:55 PM
User manual download? Orion427 3rd gen T4Rs 3 12-23-2009 01:31 AM
Owner's manual service or Dealer service? swooopeno Maintenance/Detailing 5 05-24-2005 06:11 PM
