Old 05-28-2019, 09:16 AM #16
Danradz Danradz is offline
Danradz is on a distinguished road
I figured I would post an update just to keep anyone interested up to date. I got my battery tested and it seemed that nothing was wrong with the battery. After looking around the internet at some other people's problems I think I figured out that whoever installed the previous owner's aftermarket radio/DVD receiver most likely did not do it correctly or theres possibly a short somewhere. I unhooked the battery for about 45 minutes (I know I only needed to do it for 15 but I got distracted) and when I hooked it back up everything went back to normal. The clock no longer stays on when I turn the car off and the rear wipers no longer turn on when the car turns off. Like I said it most likely has something to do with the installation of the aftermarket radio but it may also be a bad ignition switch leaving the car in the ACC position. Either way, its okay for now.
2008 4Runner Limited V8
2006 4Runner SR5 (RIP)
Danradz is offline   Reply With QuoteReply With Quote
Old 05-28-2019, 05:47 PM #17
AuSeeker AuSeeker is offline
Real Name: Skip
Real Name: Skip
I suspect that it's possible your ECU just needed to be reset and disconnecting the battery for a short time period does that, if it were your ignition switch I would think you would still have the same issues.
2004 Limited V8
Old 05-29-2019, 08:44 AM #18
Haha its funny you say that, I was walking my dog right after I posted this and I realized the same thing. Definitely just needed the ECU reset
Old 03-03-2020, 12:01 PM #19
Mlittle Mlittle is offline
Mlittle is on a distinguished road
4 runner rear wiper
Really hoping posting this on a dead thread will find its way to someone. Having a similar issue in my 2006 SR5 4Runner except mine happens when I turn my truck OFF. Also I can hear a repeated clicking coming from the fuse area under the steering wheel. Another thing I noticed, sometimes while this is happening my key fob wont work and the air will be blowing even though the car is off. Very confused, if anyone has any advice it would be much appreciated.
Did you resolve the 4Runner issue? I’m having the same identical problem. Any help will be greatly appreciated.
Mlittle is offline   Reply With QuoteReply With Quote
Old 03-04-2020, 07:40 AM #20
Yep, all I did was reset the ECU by disconnecting the battery for 15 minutes. I'm not one of the experts here so I'm sure there's another way to do that. Hope that helps you!
Old 10-07-2020, 12:20 PM #21
Dwater05 Dwater05 is offline
Dwater05 is on a distinguished road
I am also having the same exact problem with me 2006 SR5. Key fob does not work, ac fan and clock stay on when key is removed as well as rear wiper will occasionally stay on only after key is removed. Already tried disconnecting my battery and putting a new battery in and neither fixed the issue. I presumed it was my ignition switch until the rear wiper started today. Any help is appreciated, really hoping it’s not the body control module.
Dwater05 is offline   Reply With QuoteReply With Quote
Old 10-07-2020, 02:40 PM #22
Try an ECU reset, take off the negative battery terminal, leave it for 15 mins. Should do the trick!
Old 10-07-2020, 07:58 PM #23
Thanks for the response! I’ve tried that three times with no success. I even left it unhooked over night with no luck.
Old 03-23-2023, 09:22 PM #24
MarGarb MarGarb is offline
MarGarb is on a distinguished road
I'm sad to see this thread died without resolution. I am having the exact same experience when turning my 2007 OFF. Rear wiper runs, key fob doesn't work, all windows remain powered even after opening doors, climate control screen does funny stuff, and I hear the brake accumulator charge up from time to time... All with the key off and removed. Troubleshooting for days. Suspected bad body ECU. OBD2 scanned no problems. Checked fuses, cleaned grounding points, checked suspected wiring harnesses for issues and moisture (been raining alot). Ultimately replaced battery and all went back to normal. Then next morning, after a rainy night, problem is back. Did anyone else find their smoking gun?
MarGarb is offline   Reply With QuoteReply With Quote
Old 03-25-2023, 07:50 PM #25
Replying to myself here, with a resolution. I discovered an additional odd behavior where all of the electrical issues would go away if I just put my wiper control arm all the way down. Boom, no odd behavior from the keyless entry and everything was functioning tip top. I researched to see how the front wiper controls interfaced with the Body ECU and best I could tell, then don't. So, I was about to start checking for shorts in the driver's kickpanel wire harnesses to see if the wiper controls were sending some weird signal to the ECU, maybe moisture. And that is when I found some dampness, then started following it back and discovered a pretty serious amount of water soaked carpet due to a rear window leak issue (I posted separate on that). So while I didn't find a smoking gun, as soon as I pulled everything up and dried out all of the obvious wet and damp areas, which included the run of wire along the driver's side threshold, everything is back to functioning normally. All I can suspect is dampness causing some unintended voltage signal reaching the body ECU and confusing it. A window leak turns into two weekends lost! Ah well, thanks for being a resource everyone.
Rear window, rear defrost, rear wiper not working BREX25 3rd gen T4Rs 14 06-23-2013 11:22 PM
4LO light comes on randomly in 2H, rear wiper weird, rear window sticks! Summit Problems & Warranty Issues 5 11-29-2012 07:48 PM
Rear wiper/rear defroster/dome light not working... fuses? BBV 4th Gen T4Rs 5 03-12-2011 02:55 PM
1998 rear window and rear wiper INOP JSchulz Problems & Warranty Issues 0 09-14-2010 10:37 PM
Which fuse controls the Rear Defroster and Rear Windshield wiper BigK75 4th Gen T4Rs 2 10-09-2009 10:18 AM
