Had my CV boots done by a local mechanic 3 years ago. My driver side had torn, and I just got both done because I figured the other was close behind it. Yesterday I put on new coils/shocks and noticed grease/dirt on one side of my LCA on the driver side (in addition to my LCA on the driver side rotating all the way down with no effort, which I assume means my bushings are worn/dead).
The grease was not fresh at all, and there was no leaking on the axle or signs of fresh grease on the axle. Could this just be old grease from my boot tear years ago that the shop didn't clean off? Is there a way to check the grease levels inside of the boot, or can I loosen the clamp and pump some more grease in there to see if there is a leak that I'm missing? I haven't noticed any problems in 4wd, no clunking, no loss of power, nothing.
Old grease on LCA - Album on Imgur
