Old 01-27-2017, 11:57 PM #136
DCameraMan's Avatar
DCameraMan DCameraMan is offline
DCameraMan is on a distinguished road
DCameraMan's Avatar
Originally Posted by ZebRuaj View Post
Your link is to the D1s bulbs. You need to go these if you like the Ultra kits.
DDM Tuning: HID and LED Lighting
Personally, I think the 35w is enough. 55w is overkill.
4500k color (temp) is about the closest to natural white.
Sorry for so many questions.. You have all been super helpful!!
- What about the HID harness? I like the sound of "Premium" Dual Relay
- I have no idea what i'm reading when I look at the "Error Eliminator"
- I assume I don't need the adaptor cables?
2006 Sport v6 4x4
Videography | Photography | Guitar | Drums | Rollerblading | Road tripping | T4R
DCameraMan is offline   Reply With QuoteReply With Quote
Old 01-28-2017, 12:30 AM #137
ZebRuaj's Avatar
ZebRuaj ZebRuaj is offline
ZebRuaj will become famous soon enough
ZebRuaj's Avatar
-The HID harness bypass the "Plug & Play" factor by running power directly from the battery instead of the OEM H11 plug. It helps get power to the HID's quicker, but it's not needed.
-Error Eliminators are pretty much resistors. Some newer/euro cars will throw lighting error codes on the dash because HID's draw lower power than the halogens so the computer thinks you have no headlights. Same thing with LED error codes. Needs resistors to "trick" the system so it'll detect a normal power draw to indicate the lights are working or to stop hyper flashing that occurs.
-It should be plug n' play with the 4.5th gen 4Runners. Nothing extra needed but maybe zip ties or 3m mounting tape, depending on what the kit provides. Hardest part will be squeezing your hand behind the battery if you chose not to remove it to install the driver's side bulb.
07 T4R Sport Edition V6 4x4
ZebRuaj is offline   Reply With QuoteReply With Quote
Old 01-28-2017, 12:55 AM #138
DCameraMan's Avatar
DCameraMan's Avatar
Wow thank you. So i'll pass on the harness.. do you have a recommendation for 2 the error eliminator options?
2006 Sport v6 4x4
Old 01-28-2017, 01:37 PM #139
ZebRuaj's Avatar
ZebRuaj's Avatar
You don't need it. My 07 (same as your 06) is just plug n' play. The truck won't throw any light codes.
Old 01-29-2017, 04:08 AM #140
DCameraMan's Avatar
DCameraMan's Avatar
Just ordered! Will be sure to update when they come in! Thanks for all your help
2006 Sport v6 4x4
Old 01-29-2017, 08:23 AM #141
toyo's Avatar
toyo toyo is offline
Real Name: Steven
toyo will become famous soon enough
toyo's Avatar
Real Name: Steven
This company is hands down the authority of anything HID.
https://www.theretrofitsource.com/
2008 4R LTD V8 4WD, ICON Stage 3, TRD Pro Wheels, GOBI Rack, TRS HID Swap along with too many other mods to list here!
toyo is offline   Reply With QuoteReply With Quote
Old 01-29-2017, 10:54 PM #142
AE1M AE1M is offline
AE1M is on a distinguished road
I installed DDM HID kit in my 08 Limited a few years ago. I love them, definitely an upgrade. I didnt use the relay harness since the wattage seemed so low, who cares. My only problem was that in cold weather (say under 25 deg F) sometimes the bulbs wouldnt light. I would have to cycle the switch a few times.
I finally decided perhaps the ballasts were able to get the high current to fire the bulbs when all was very cold. I bought the single relay harness and installed it and have had no problems this winter. So, I advise using the relay harness. I connected to the battery posts screw terminals and ran the harness in a high temp loom above the radiator (under the plastic cover) to the passenger side ballast.
One thing to consider, installing HIDs on a vehicle that didnt have them originally is technically illegal (here in MA anyway, all over I think) but no yearly inspection guy has given me any problem.
Bob
2008 4R Limited Salsa Red Pearl 3Q3
AVS Bugflector,Coastal Lockpick 2,Super Z V1 Radar Detector Mount
Please, no more Hope & Change!
AE1M is offline   Reply With QuoteReply With Quote
Old 01-30-2017, 08:25 AM #143
toyo's Avatar
Real Name: Steven
toyo's Avatar
Real Name: Steven
Bob
The reason they are illegal is because It's a HID bulb in a halogen lamp assembly. Swap it out to a full projector/HID assembly and all will be good. The difference in the light that's output is night and day.
Old 01-30-2017, 10:56 AM #144
LOSTR4's Avatar
LOSTR4 LOSTR4 is offline
LOSTR4 will become famous soon enough LOSTR4 will become famous soon enough
LOSTR4's Avatar
I went with 4500k and it's gorgeous!
2005 T4R Limited V8 Dorado Gold Pearl|'06 Headlight/Taillight Update|5000k HIDs|VSC-Off|Husky-Lined|HCF Delete||IAP By-Pass|TPS By-Pass|AFE Pro Dry S|Gibson Cat-Back Side-Exit|Pioneer AVH3800BT|Sprint Booster|BD SSPro IFLs|LEDs|ICON 2.5+|SPC UCAs|TE/FJ Wheels|255/80 Cooper ST MAX|Spidertrax 1.25|Custom-ish End Links|Custom Perkins Roof Rack|40" LED Light Bar|SW Color-Matched Front Bumper
LOSTR4 is offline   Reply With QuoteReply With Quote
Old 01-31-2017, 11:27 AM #145
chaz's Avatar
chaz chaz is offline
chaz will become famous soon enough
chaz's Avatar
one thing to remember, if your even worried about it, is just because someone does a proper HID retrofit it still doesnt make it truly legal. just a couple things to consider is your modding a halogen headlight that may not hold up to the heat of HIDs ( OEM will, aftermarket maybe not) & its not self leveling. but imo, if you want/need HIDs, its the right way to go, and even tho the harness isnt needed for them to work, it will help the hids achieve theyre true potential, as will a set of OEM ballasts & better hid bulbs like phillips or osram. whatever you do, just aim them properly.
chaz is offline   Reply With QuoteReply With Quote
Old 03-07-2017, 01:21 AM #146
DCameraMan's Avatar
DCameraMan's Avatar
My DDM Plus
Got them all hooked up! I've had these hooked up for a few weeks now. They are working great. They take 30 seconds or so to come to full brightness, but it doesn't bother me. Still trying to decide if the 5500k is too blue for me. May eventually switch them out for 4500-5000k..
Before and Afters:
Ballast Locations: both screwed straight into the sheet metal
Hidden beside the battery
image hosting free
2006 Sport v6 4x4
Old 08-27-2018, 05:08 PM #147
chewyspark47 chewyspark47 is offline
chewyspark47 is on a distinguished road
So I'm getting ready to pull the trigger on this but just wanted some confirmation, I have the projectors on. 07 t4r sport, so with that I don't need to upgrade the lens, right? Just plug n play?
chewyspark47 is offline   Reply With QuoteReply With Quote
Old 08-27-2018, 05:41 PM #148
cloud cloud is offline
Banned
cloud is on a distinguished road
Banned
Just a friendly reminder for you all to ADJUST YOUR DAMN LIGHTS!
Sent from my XT1710-02 using Tapatalk
cloud is offline   Reply With QuoteReply With Quote
Old 09-04-2018, 06:36 PM #149
broncosi broncosi is offline
broncosi is on a distinguished road
Plug n play as long as you get the correct base. Please confirm this first but you should be looking for the H11 bulb. The kit should come with ballasts as well that match the correct wattage for the bulbs. Your options are typically 35w or 55w with 55w having a little more output. Temp wise, I'm sure you've done your research. As cloud said, please take it out at night and aim against a wall to see if you need to adjust your headlight housings: GUIDE HERE
Long story short, if you buy an H11 kit with ballasts, yes, it's plug n play for your 4runner.
broncosi is offline   Reply With QuoteReply With Quote
Old 09-25-2018, 09:54 PM #150
SCY7H3 SCY7H3 is offline
SCY7H3 is on a distinguished road
After playing around with aftermarket ballasts I ended up going with Denso OEM ballasts from Toyota off another model and retrofitted them into a semi breathable box to H11 based HID bulbs. Find that these tend to output much better. I'm pretty sure there are some great aftermarket brands out there.
How's the 55w output compared to 35w? Anyone have side by side comparisons?
SCY7H3 is offline   Reply With QuoteReply With Quote
hid , kit , lights , roro
Fs: 3rd gen tail lights, corner lights, turn signals, 3rd brake light set with led Stretch1100 For Sale: T4R Items 0 10-06-2011 03:42 AM
Couldn't yiu just turn the front bumper running lights into auxilary lights? Muti007 3rd gen T4Rs 6 05-03-2010 12:48 PM
leds in tail lights, no brake lights, buzzing from dash with blinkers??? jamr1 3rd gen T4Rs 0 09-12-2008 07:10 PM
Are the Progreate Jaos Special 710 offroad lights considered fog or driving lights? msanta Engines / Suspension / Wheels / Tires / Audio / Accessories 1 09-05-2006 02:49 PM
