11-05-2011, 02:58 PM
Another cv boot leak thread
This is my 2006 sport. The inner boots are leaking on the right and left side. I installed a daystar 2.5" spacer lift on it in July. It seems that the leaks are not that uncommon after a lift. But i wanted you guys to look at it and tell me what you think. I may try to inject some more grease and add hose clamps.
Reason: pictures too BIG
11-05-2011, 03:05 PM
Real Name: Chris
Real Name: Chris
Doesn't look bad at all. I'd regrease and re-clamp both sides. I re-clamped mine a few weeks ago and havnt had a leak since. I'm gonna regrease both sides when I have some time.
2007 SE V8
HID's, interior LED mod, sweet floor mats, awesome tunes and some more stuff...
...more stuff
11-05-2011, 04:33 PM
Did you use the factory style clamp?
11-05-2011, 04:53 PM
reclamp, or just wrap em up with duct tape and regrease
2004 sr5 v8 4wd 4runner, leather,
I AM THE SEARCH POLICE!!! USE THE SEARCH BAR FIRST!!!!!!
follow my build at
http://www.toyota-4runner.org/4th-ge...t117-mods.html
11-05-2011, 05:48 PM
Real Name: Chris
Real Name: Chris
Nope, hose clamps from ACE.
2007 SE V8
...more stuff
11-05-2011, 08:59 PM
After I did my lift I got the same problem. The dealership was asking $600 plus for this job. I went home and did my research (a lot of threads about this) got an ordinary clamp from Autozone, and as the other member said "Dry as a bone". Problem solved.
11-06-2011, 01:08 AM
I had the same issue. I knew I had a little leak but one day looked under and had what looked like runny grease coming out of the small end of both inner boots.
I went ahead and had a shop clean them up and repack with grease. The outer boots were not leaking at all, BUT when they pulled the outer boots, the grease ran out like water. So I had them put a whole new boot kit on. I figured if you're going in, do it right. It was about $300 with OE parts and labor, all four boots replaced, joints cleaned and new grease.
11-06-2011, 10:57 AM
I need to tend to one of mine as well. Is there a specific grease to use or just pump it out of the cartridge?
2004 4Runner Sport Edition 4x4, V6
Stratosphere Mica
284k
11-06-2011, 11:54 AM
I'm another victim after installing my lift. It seems to affect the geometry in a bad way.
2003 4Runner Limited V8 4WD;Pacific Blue Metallic; Cornfed 3/2 Lift; Spidertrax Wheel Spacers;Magnaflow Cat-Back Exhaust; Nitto Terra Grapplers 265/70/17; aFe Pro-Dry S Air Filter; Philips 4300 Xtreme HID Low-Beams; PIAA 540 Plasma Ion Fogs; HIR Hi-Beams; HIR main fogs; Man-A-Fre Front Skid; Alpine Head Unit w/I-pod Interface; Alpine Type-R 10" Sub; Kenwood 1000W Amp; JBL 10 speaker system; Steelcraft Bull Bar; Go Rhino Hitch Step; PIAA Super Silicone Wipers; TRD Radiator and Oil Caps; Brembo brake pads & rotors; TRD Carbon Fiber and iForceV8 Emblems on Hatch; all LED interior, Running Board, Reverse and License Plate bulb replacements; Weather Tech mats and Cargo Liner; Blitz Hybrid Cabin A/C Filter
11-06-2011, 02:43 PM
any automotive grease will work, you can even mix and match if you want
follow my build at
11-06-2011, 10:50 PM
Got the clamps on this morning. I didn't have time to add grease (didn't have any), but I at least stopped the bleeding.
11-07-2011, 12:53 AM
Real Name: Chris
Real Name: Chris
Did you use stock clamps?
2007 SE V8
...more stuff
11-07-2011, 01:04 AM
Its not an issue related to lifting your vehicle, it seems to be a common issue with 4Runners and Tacomas. The small inboard CV Boot clamps leak or the boot tears at the clamp. Had it happen to my rig and seen it a lot at work.
11-07-2011, 10:17 AM
Use marine style hose clamps. The ones you find at hardware stores have sharpe edges and may cut in to the boot. Here is a great wright up.
Replacing CV bands - Toyota 120 Platforms Forum
I did mine with marine clamps i got on ebay after the dealership replacements popped off after a year.
03 Toyota 4Runner 4x4 V8
96 Toyota T100 4x4 150k miles (traded)
97 Toyota Corolla CE 167k miles (totaled)
94 Toyota p/u 4x4 150k miles (traded)
87 Toyota p/u 270k miles (sold)
11-08-2011, 09:32 AM
I thought I read that you were suppose to use HP90 grease?
I used hose clamps I had in the shop.
I am affraid the dealership won't see it that way, and won't fix it under warranty.
Thanks for the link zuke.
