Thread Tools Rating: Thread Rating: 7 votes, 4.57 average. Display Modes
Old 04-20-2019, 11:51 AM #32446
The_Perrycox's Avatar
The_Perrycox The_Perrycox is offline
The_Perrycox will become famous soon enough
Stoppin on a dime!
Got the whole new brake system installed last night. Centric Rotors, Hawk LTS Pads, Powerstop Calipers, and stainless lines all around. I replaced everything front and back. Definitely notice a massive difference. Brake fluid was black...pretty sure the previous owner never serviced the brakes. Now it's got fresh Pentosin Super DOT4 running through it.
Didn't get the chance to bed them last night, due to all the foot traffic from Coachella. Lots of vacation rentals here in my neighborhood...can't say I mind the festival girls though!! So early this morning I zipped around the neighborhood doing a sequence of moderate then hard stops as per Hawks instructions. Fresh brakes smell delicious when heated!
2004 Galactic Grey SR5-Fox 2.0 Coilovers Front, Fox 2.0 & OME 895e rear, FN FX Pro 17" w/285/70/17 Falken Wildpeaks, Demello single hoop bumper, Coastal Off-Road Single swing out rear, RSG Sliders, AFE Stage 2, Morimoto D2S 4.0 Retrofit with CBI Bulbs
The_Perrycox is offline   Reply With QuoteReply With Quote
Old 04-20-2019, 12:47 PM #32447
SHagood's Avatar
SHagood SHagood is offline
SHagood will become famous soon enough
MY GARAGE
SHagood's Avatar
MY GARAGE
Both rear doors were hitting my sliders every time they are opened (that are welded on). Trimmed a little fat off the steel, sanding down and painting new groove to clear the doors. Also, had a buddy cut some steel to offset a Wilco jerry can attachment.
2008 Urban Runner
SHagood is offline   Reply With QuoteReply With Quote
Old 04-20-2019, 01:07 PM #32448
SummitRunner SummitRunner is offline
SummitRunner is on a distinguished road
Oil change and radiator fluid change. Opened the hood and saw this "squirrel damage":
Patched the hood liner back together with a glue gun.
2004 4Runner Limited, v8, 4WD
Overlanding Travel App for iPhone
"Great things are done when men and mountains meet." -William Blake
SummitRunner is offline   Reply With QuoteReply With Quote
Old 04-20-2019, 01:34 PM #32449
wigsajumper wigsajumper is offline
wigsajumper is on a distinguished road
Originally Posted by Terminator03 View Post
I like that USB port. Is the readout in the cover as it appears? Is it a single port under the cover, or dual?
Readout is under the cover. Cover has a cutout for the readout. Two ports.
Sent from my Pixel 2 XL using Tapatalk
"Blanche" 2004 SR5 V6 Dorado Gold 3rd Row Seating Completely Stock
wigsajumper is offline   Reply With QuoteReply With Quote
Old 04-20-2019, 01:48 PM #32450
Trumpet Trumpet is offline
Trumpet will become famous soon enough
Did you check the airbox and fresh air intake for liner leftovers??
2007 SR5 V6 long live the kingfish !
2009 SR5 V6 ---RIP
Trumpet is offline   Reply With QuoteReply With Quote
Old 04-20-2019, 02:33 PM #32451
Airbox was clean. I didn't check the fresh air intake, good idea to check, thanks
Old 04-20-2019, 11:02 PM #32452
Formidable's Avatar
Formidable Formidable is offline
Formidable has a spectacular aura about Formidable has a spectacular aura about Formidable has a spectacular aura about
Formidable's Avatar
Raptor lights wired up!
What did you do with your 4runner today?-f4cdcf81-dcd9-40d2-8646-5085947484d0-jpg  What did you do with your 4runner today?-51a3c42b-496c-4401-ab6d-7ff9e15fa489-jpg
2008 V8 Limited Nautical Blue Metallic
URD | Rotora | Titanium Works | Toytec | JAOS | HeftyFab | RCI | FUEL | BUILD THREAD
Formidableís other little project
Formidable is offline   Reply With QuoteReply With Quote
Old 04-21-2019, 12:47 AM #32453
T4Rmiller T4Rmiller is offline
T4Rmiller is on a distinguished road
I had the same issue when I tried to replace my broken rear wiper. I didnít have a wiper puller at the time, so I ended up having to use a Dremel with a cutoff wheel to cut through the bushing so I could split it off the shaft! It was so rusted there was no other way it was coming off (without the correct puller). They sell the pullers on Amazon, so if you have the time to order one, it will make life a lot easier for that job!
The bolt on mine is rusted so that I cant even get it out, let alone pull the arm off. basically there is no head to the bolt so Im going to have to try to get it with an easy out or similar, but honestly dont think its going to come out. Im preparing to have to replace the motor
T4Rmiller is offline   Reply With QuoteReply With Quote
Old 04-21-2019, 07:11 AM #32454
earthrealm earthrealm is offline
earthrealm is on a distinguished road
so trying to chase a persistent p0174 error, LTFT on bank 2 is 37% high, while bank 1 is 14%, have cleaned, maf sensor and throttle body, changed airfilter, no luck, next step is to change fuel pump+filter, but i want to test the furl pressure first. ordered the kit from amazon, but ran into hitch, am unable to locate the fuel rail/where to hook up the fuel pressure kit. my truck is 05 v6, would appreciate any head ups for this procedure or links for videos to match.
thnks
2005 v6, galactic grey 4wd auto : pioneer avh 4400bh dvd hu, pyle reverse cam
2003 rav4 titanuim silver 4wd auto......sold
2004 rav4 titanuim silver 4wd auto : pionneer avhx 5500bt hu, pyle reverse cam
earthrealm is offline   Reply With QuoteReply With Quote
Old 04-21-2019, 02:19 PM #32455
Power steering
Being bored and having the itch to work on the 4Runner...I decided to do a power steering flush. The truck only has 83k miles on it, but it -is- an 04 so I figured it wouldn't hurt. Old fluid was pretty foul looking. Went through a little over a quart til it was coming out fresh as a daisy.
My what a difference it made. So much smoother when turning the wheel, and it feels a bit more responsive overall. Definitely worth doing!
Old 04-21-2019, 02:29 PM #32456
0verland 0verland is offline
0verland will become famous soon enough
Only 83k miles!?!? That has to be the lowest mileage on the boards.
2006 V8 Limited 4WD
| Doug Thorley Headers | Gibson | Old Man Emu | ToyTec | SPC Performance | RCI Metalworks |
| Skid Mark 4x4 | SpiderTrax | BFGoodrich KO2 | aFe Drop-In | Rutech | HCF Mod |
0verland is offline   Reply With QuoteReply With Quote
Old 04-21-2019, 02:49 PM #32457
Yep! It's actually at 82.9k =)
Purchased from a family friend who hardly did any long distance driving for a whopping $5k. Only downside is she's only 2wd...for now.
I've Had quite a few conversations with Wyatt over at Rock Solid Toys and sometime next year she'll be getting the conversion. It ain't cheap, but a 4wd 4th gen with mileage this low doesn't really exist. I don't plan on ever getting rid of this truck, so to me it'll be worth it.
Old 04-21-2019, 05:11 PM #32458
KrisB410 KrisB410 is offline
KrisB410 is on a distinguished road
Originally Posted by Bluesky 07 View Post
Wow...metro Atlanta requires emissions inspections, which cost $15-$20. What in the world are they doing for $78?
Maryland State Inspection is a 1 time safety inspection. It can be a pain in the ass and a major hassle.
I'll get an emissions notice shortly, as the current emission. Test expires next month.
KrisB410 is offline   Reply With QuoteReply With Quote
Old 04-21-2019, 10:05 PM #32459
084RUNNAH's Avatar
084RUNNAH 084RUNNAH is offline
084RUNNAH is on a distinguished road
MY GARAGE
084RUNNAH's Avatar
MY GARAGE
41k miles here!!! Nothing much to add here other than replacing my rear coil springs under warranty as one side snapped
2008 Toyota 4Runner Limited V6
| Spidertrax | OME 886 and Icon Overland Coils | Kenwood DNX9980HD | JL 8W3| HID | Full LED |
| S2000 headlight retrofit | URD Spec U Long Tube Headers | Borla Cat-Back Dual Exhaust | 5th Gen Brakes |
084RUNNAH is offline   Reply With QuoteReply With Quote
Old 04-21-2019, 11:56 PM #32460
pahaf91 pahaf91 is offline
pahaf91 is on a distinguished road
recently got a 2006 4Runner sport V6 4WD with 192k
today replaced spark plugs
rear diff oil w/mobil1
installed black housing headlights
lubed both driveshafts
replaced rear brake pads.
installed 5th gen front struts w/coil, rear strut, upper control arm
went off roading in some local areas.
pahaf91 is offline   Reply With QuoteReply With Quote
4runner , 4th gen , mods
My 4runner got smacked today! Rez90 4th Gen T4Rs 11 10-09-2013 05:03 PM
Weird Problem today with my 4Runner today. myT4RisGREEN 3rd gen T4Rs 9 05-18-2013 10:07 PM
Bought my first 4runner today! mechagouki New Members 2 09-18-2010 10:03 PM
I got my 4Runner today NavyChiefnMD 5th gen T4Rs 5 12-17-2009 01:12 PM
Copyright ©2000 - 2019, vBulletin Solutions Inc.
Search Engine Optimisation provided by DragonByte SEO (Pro) - vBulletin Mods & Addons Copyright © 2019 DragonByte Technologies Ltd.
Feedback Buttons provided by Advanced Post Thanks / Like (Lite) - vBulletin Mods & Addons Copyright © 2019 DragonByte Technologies Ltd.
User Alert System provided by Advanced User Tagging (Lite) - vBulletin Mods & Addons Copyright © 2019 DragonByte Technologies Ltd.
Copyright © 2019
