08-20-2019, 09:04 AM
#33016
Originally Posted by kcdehart
My personal opinion: There should *never* be coolant in your oil. None. Not trace amounts. Nothing. The fact that Blackstone brought it up means there's an issue that you should definitely look into. And it's honestly scarier (to me) than if coolant was leaking into a cylinder, which is what would cause white smoke/misfires (and is what typically happens when people talk about 4th gen headgasket issues).
It means that coolant is leaking into your crankcase somehow. It won't necessarily affect driving performance. The risk is that it thins out your oil and you spin a rod bearing because they're not lubricated well enough. Essentially destroying your engine as that will send metal shavings throughout the block.
thanks for the outlook on it. when i take it back to the shop (i don't blame them for their dismissal of the problem. maybe i didn't explain it well to them) what kind of tests should they be doing it to it? i know a few things about mechanics and the workings of a combustion engine, but the cooling system to me is a bit of a mystery (i work a bit on air-cooled motos).
08-20-2019, 09:45 AM
#33017
Real Name: Kevin
Real Name: Kevin
Honestly, coolant in the oil is the test. The headgasket should be keeping everything separate so there should be no way for coolant to get into your oil unless you pour some into it.
'04 4Runner - Build Thread | '05 CBR 600RR & 1000RR - The slow vehicles ;)
08-20-2019, 04:10 PM
#33018
I finally replaced transfer case actuator seals. It's mostly a strait forward job per the excellent write-ups here on the forum. The two bolts up top are a bit annoying to get to but after fiddling with various extensions and swivels I found that they can be reached with strait extensions of the appropriate length.
'04 SR5 4x4 V8 Titanium/Stone - 2/1/04
Mods: Homelink+x10, RS3200+, Auto Headlights, Compass Mirror, CarPC, DRL, PDF Manuals, Auto Map Lights, MGCLT Relay Saver
Future Mods: 115V Inverter, Leather, Trip Computer Fix
08-20-2019, 07:49 PM
#33019
Do you mind linking the most informative thread you used to do this?
08-20-2019, 09:14 PM
#33020
Originally Posted by Terminator03
My straps are bad, and on the list to replace in the very near future. Where did you find stainless straps? I saw the Spectra brand on Rock Auto, but it didnÂ’t mention stainless. I would definitely prefer stainless for obvious reasons!
Yes the ones on rock auto. I assumed SS because it said ST316 so I thought 316 stainless but your right, it’s actually satin coat steel or “Galvanneal”. I’ll make sure to topcoat a little more thoroughly with rust preventive.
08-21-2019, 04:12 PM
#33021
had my oil tested a while ago with blackstone, then left for a road trip. got the diagnosis back, and they said they detected traces of coolant in the oil. checked the coolant and it was indeed low. topped it off with some toyota formulated stuff, and haven't noticed a measurable drop in it.
when i got home from the trip, took it to an independent toyota shop and talked to the dude there. he didn't seem too concerned about it, as the truck is not throwing any codes, doesn't puff white on cold starts, and doesn't have a hard stumble. now, i have noticed some stumbles on cold starts, but it's more like a hiccup than anything. feeling a bit conflicted about the whole situation.
when i got the truck, i switched to mobil1 synthetic. that was 30k miles ago. for the next couple of changes i'm going back to a conv oil and send it back to blackstone.
Nice two tone look, thinking about that now.
08-21-2019, 06:32 PM
#33022
My wife made me a sticker. My first mod.
Sent from my Pixel 2 XL using Tapatalk
08-21-2019, 11:07 PM
#33023
8/16/19 - DFW trip
1999 2.7 5MT - SOLD // 2007 V8 4WD - Gone
2011 FJ 4WD - to new beginnings
// 4G V8 // 3G 2.7 5MT // Model 3 // IS300 5MT // FD RX7 //
08-22-2019, 02:48 AM
#33024
Black 2008 Sport V6 4WD | Toytec BOSS 3/2 | JBA UCA | BFG KO2 255/75/17 | Rocksteady Skids | White Knuckle Sliders | TJM Front Bumper | Superwinch
08-22-2019, 08:37 AM
#33025
Real Name: Kevin
Real Name: Kevin
Originally Posted by tv4184
IMG]https://i.imgur.com/BWULiEf.jpg[/IMG]
Super laps and RE71Rs. Very nice
08-22-2019, 08:58 AM
#33026
I went up to DFW to pick up some stuff off Facebook marketplace. I stopped by this furniture place on the west side of Fort Worth to get some mall crawling style pics. It's been on my list of places to go to around the state. Good time as any, only downside is the rig was a bit dirty from the 4 hour trip up.
Usually for these types of trips I would take the Tesla, but I ended up finding some wheels last minute for the RX7. I had the 4Runner packed pretty good with aquarium stuff and the wheels. Felt like I was back in college moving back from Austin.
It's nice to use the 4Runner for what it is once in a while. Most of the time, its just sitting in the driveway baking under the sun waiting for me to take it somewhere. 85% of the time, its used for ferrying the dogs somewhere.
funny, from where i live in south coast MA, if i drove 4 hrs i could touch RI, CT, NY, VT and NH
sweet photos- diggin the mural. USUS
volks for your rx7 or works?
08-22-2019, 06:06 PM
#33027
Are those te37s or reps on the runner?
08-23-2019, 12:34 AM
#33028
Installed an ATOTO A6 Pro (for Toyota - no dash kit needed) and Pioneer sub to replace the stock JBL nav system. Next up is a coverlay dash cover and suspension from Dobinsons!
2004 V8 LIMITED 4WD
[INT/EXT] 06+ Projectors & HIDs/LEDs/CDN Hood deflector/SS Bull Bar & Hitch Step
[ENGINE] aFe Pro DRY S Air Filter/DT Headers/TRD Dual Exhaust
[WHEELS/SUSPENSION] OEM 20" Rims(265/50R20)/Dobinsons Suspension 2" lift
08-23-2019, 06:58 PM
#33029
Registered User
Real Name: Morris
Registered User
Real Name: Morris
08-23-2019, 08:45 PM
#33030
Real Name: Richard
Real Name: Richard
Had to take a trip yesterday of about 80 miles each way. Happily driving along at 70mph and all was good, got to the first town and decided to stop and grab a drink. Started to smell something weird and was horrified to see the temp needle at high. Parked up and let the car cool down, checked coolant level all was good. Carried on with our journey and as long as the car was moving it was okay but creeped high at lights. Got back home and changed the thermostat, drove around town and all good.
Had to do the same drive today, again all good on the motorway but in towns it overheated. Went to a mechanic out of town and he said it needed burping and all would be good, he burped it with no charge and we started to head home. Again motorway speeds it's perfect but overheating at stops.
Went straight to my own mechanic and he said considering I replaced the thermostat he believed it was the radiator. So I gave him the go ahead to replace it, he gave me a call a few hours later and said there was bad coolant flow and my radiator was all blocked up, no blockages elsewhere. So a new radiator was fitted cost was $390, no idea if that's cheap or expensive but relieved it's not the head gasket.
2005 4Runner V6
