09-27-2019, 09:15 PM
#33166
Originally Posted by kcdehart
You have close-up pictures?
The product is solid. It is super tough and withstands rocks pelting it at highway speeds. As mentioned before you can see every imperfection of my grind job. I'm not unhappy with the result as it's my first plate bumper but if I took more time it could have been a bit better.
09-27-2019, 09:20 PM
#33167
09-28-2019, 04:25 PM
#33168
Thats how thick 50 bucks aluminium sheet cut to fit looks like. Not a rock crawling armor by any means but a great protection from mud rushing in to a rad and condenser during mud bogging
Sent from my Redmi 4 using Tapatalk
09-29-2019, 02:13 AM
#33170
I think it was around 5-6 mm. It took me about 3 hours to make it with disk grinder.
09-29-2019, 11:01 AM
#33171
Real Name: Ryan
Real Name: Ryan
09-29-2019, 09:08 PM
#33172
Added auxiliary reverse lighting, I feel like I can never see back there even with upgraded LED’s. This should work.
09-29-2019, 10:23 PM
#33173
what brand is that? im using the hella brand with the flood pattern, it works really nice.
Pioneer DEH-80PRS,Rockford Fosgate T600-2,Hertz ML 1650.3(2 pairs),T400-2,Hertz ML 280.3(2 pairs),T1000-1bdcp,(2)JL Audio 12W6v3, Mechman 240a HO Alternator, Dual Northstar 31m,Borla Dual Exhaust,AFE Magnumforce intake.Enkei WT-4 Michelin Defender LTX 275/55R20. retrofitted S2000 projectors,Philips 85122 White Vision,Morimoto 5Five Ballast.Diode Dynamics SS3 Yellow Fog Sport.2 pairs of Hella Supertones.Full led conversion on interior and exterior.HAWK Talon Rotors and LTS pads F+R,Stoptech stainless steel lines F+R.Bilstein 5100 @0.85, MOOG FJ Springs front,Bilstein B12 36-281824 rear .
09-30-2019, 01:24 AM
#33174
Generic ones I bought from a guy on TW, they seem pretty bright and I got a good deal. I figure I’ll likely smash them on a trail so no need to get expensive ones until I try it out.
09-30-2019, 09:16 PM
#33175
I replaced both of my front CV axles today. Of course one side was easy, the other side was a pain, but it was very straightforward.
What I didn't read was that my front diff would empty itself. So I guess I'm changing the front diff fluid tomorrow. On to searching for DIY's. (I've always had an indy shop do it. It only has 30k / 3 years on it).
09-30-2019, 10:17 PM
#33176
It's a bit late now, but always make sure you can remove the top fill plug before pulling the bottom plug.
2003 Galactic Gray Mica Limited V8
Inside: Pioneer AVH-2300NEX w/ backup cam | Dometic CFX3 55im | Custom floor w/ table & drawers
Outside: Hefty Fab Bumper | Warn ZR 10-S | RCI skids & sliders
Electrical: 150w solar panel | Victron MPPT controller | BlueSea breakers and panels
Suspension & Tires: Bilstein 5100's w/ Dobinson c59-314 & c59-329 | 5th Gen Trail wheels & Wildpeak A/T3W 275/70/17
09-30-2019, 11:00 PM
#33177
This is very important. Also the diff job is very easy, takes about 30 minutes
10-01-2019, 06:12 AM
#33178
Real Name: Kevin
Real Name: Kevin
Biggest recommendation for the front diff is to make sure you can get the fill plug out before you pull the drain plug.
Once the plugs are out it's a 5 minute job with a hand pump.
And for the CVs, I always just jack the truck up to the point where it's at a decent angle. That way fluid doesn't spill out.
'04 4Runner - Build Thread | '05 CBR 600RR & 1000RR - The slow vehicles ;)
10-01-2019, 09:53 AM
#33179
took my 4runner an independent mechanic we trust. Oil pump is gone. Is a $1.8K repair bill reasonable if it were to include a timing chain kit and valve cover gaskets?
10-01-2019, 09:58 AM
#33180
Real Name: Kevin
Real Name: Kevin
Ouch. Do they tell you what all needs to be removed to replace the oil pump? I know oil pan removal is a pretty large job.
Also, any idea what caused the failure? This is the first I've heard of it happening on a 4th gen.
Thread Tools |
Display Modes |
Rate This Thread |
Linear Mode
