Originally Posted by Dirtrider216
My 06 is at 178k miles, Ive recently replaced front hubs/bearings, front calipers and rotors. Carfax shows my timing belt was done at 98K.. when do I need to start planning for another timing belt job? The dealer and car have been draining my wallet big time lately as both of my breakdowns- related to bearings and brakes- have happened while I was on the road and needed my car and didn't have another vehicle to use so I had to go to the dealer..
On the fence to just ditch the runner and get a low mile jeep TJ that's cheaper and easier to work on, to last me 1.5 more years of grad school
I had mine done when purchased at 112k. The mechanic said it was way overdue and could have broken in the near future (I didn't really look at it). I got around to it again at 210k (98k interval) and tackled it myself. The belt itself was OK, needed replacing but didn't look like it was about to break, but the water pump seal had pretty much failed and was leaking quite a bit. (When done my coolant leak vanished
You don't need a ton of space to do it, just a place to drain fluids and dispose of them, and a second person usually helps to remove the fan from the clutch (just needs to be a relatively strong person). Everything else is doable solo. If you have a buddy with a garage you could use for a weekend that'd work fine.
There is a good write up out there on a similar lexus V8 that showed me almost everything I needed to do. I made one mistake with sealing the water pump properly; the first shot took me about 20 hours with multiple parts stores runs; it ran but leaked about 2 cups of coolant over 100 miles. I re-did it in about 6 hours and it's been great, going on 15k pretty soon.
I paid $800 at a budget mechanic to do just the belt & water pump change the first time. I was quoted up to $1200 but that included cam & crank seals. I attempted those the second time but was unable to remove the crank gears, so I skipped them as none were leaking - I believe 05+ have more issues with crank seals, unfortunately.
My total costs were just under $400 the second time, and I bought the ~$70 crank holder tool and a $60 torque wrench (included in the $400). If you wanted to tackle it, don't hesitate to buy the crank holder (Schley sch64300). I bought a lot of coolant - in the future I'd probably test with water before filling up on coolant...
Also... Autozone free rentals are your friend.
