Thread Tools Rating: Thread Rating: 12 votes, 4.58 average. Display Modes
Old 05-26-2020, 11:10 AM #34141
John.Adam John.Adam is offline
John.Adam is on a distinguished road
Mechman 240 amp Alternator install after the stock one went out at 139k.
Old one out through the bottom on the v8 seems the easiest way. Thankfully I have a lift to use in the shop. Did have to move some lines and loosen the power steering pump.
New one in
SMD fuse block installed on oem fuse block lid. Only using one of the spots right now but this will give me more access points for later on. All 0 gauge knukoncepts OFC wire that’s crimped and soldered, wrapped in snake skin and then heat shrinked for the big 3. And you can see my battery terminals from Sky high car audio.
Here’s the after charging voltage cold and after warmed up.
And here it is after the gm diode was put in
Overall it wasn’t a hard install. Just time consuming waiting on the alternator to get here but that gave me enough time to run the wires for the big 3. I did use a half inch smaller belt to account for the mechmans slightly smaller pulley. This should last me very well in the future if I decide to add some power hungry additions like subs or winch etc etc.
John.Adam is offline   Reply With QuoteReply With Quote
Old 05-26-2020, 02:31 PM #34142
newton22 newton22 is offline
newton22 will become famous soon enough
The original owner of my 4R likely never left the pavement with hers. I think she only bought a 4WD because it just happened to be on the lot.
Now I'm showing it what nature smells like.
What did you do with your 4runner today?-img_20200525_120832-jpg
2004 SR5 4WD | 5100s | Level 8 MK6s
newton22 is offline   Reply With QuoteReply With Quote
Old 05-26-2020, 03:38 PM #34143
aelarson's Avatar
aelarson aelarson is offline
Real Name: Andrew
aelarson will become famous soon enough
aelarson's Avatar
Real Name: Andrew
Found a Minimum Maintenance Road over the weekend in Northern MN. Nothing too crazy, but got the Hearing Aid a little dusty and dirty. It is hard to tell it's dirty because this color hides everything!
I have a feeling this was the first time this truck has been off the pavement. It was way too clean when I bought it to have been off-road. I can even tell that the previous owner never hauled a trailer either, the paint was in perfect condition inside the hitch.
85,000 miles and she is just getting started
What did you do with your 4runner today?-1-jpg  What did you do with your 4runner today?-2-jpg
08' Limited V8 (2020-Current)
17' TRD Pro (Sold: 2017-2020) - Update/Mod/Build/Adventure Thread
08' Urban Runner (Sold: 2010-2017)
aelarson is offline   Reply With QuoteReply With Quote
Old 05-26-2020, 07:24 PM #34144
WhiskeyMike477's Avatar
WhiskeyMike477 WhiskeyMike477 is offline
Real Name: Wes
WhiskeyMike477 is on a distinguished road
Real Name: Wes
Got this awesome sticker in the mail. My daughter and I put it on together!
Sent from my Pixel 2 XL using Tapatalk
--Build Thread--
WhiskeyMike477 is offline   Reply With QuoteReply With Quote
Old 05-26-2020, 07:30 PM #34145
Real Name: Wes
Real Name: Wes
What light bar are you running? I want to put one on mine but not sure what bar I want to go with.
--Build Thread--
Old 05-26-2020, 11:08 PM #34146
aelarson's Avatar
Real Name: Andrew
aelarson's Avatar
Real Name: Andrew
Black Oak LED 30” curved!
Old 05-27-2020, 07:12 AM #34147
importman importman is offline
Real Name: Danny
importman is a jewel in the rough importman is a jewel in the rough importman is a jewel in the rough importman is a jewel in the rough
Real Name: Danny
I replaced the mode door actuator. Not really as bad as I expected. Also replaced the driver's door check. Now I don't have to listen to that annoying buzzing from the dash or that awful sound every time I put my window down.
importman is offline   Reply With QuoteReply With Quote
Old 05-27-2020, 11:51 AM #34148
Detroitdiy Detroitdiy is offline
Detroitdiy is on a distinguished road
De-chromed the front end on my “new” 05 sr5
What did you do with your 4runner today?-932d3a11-de40-4ca5-b0bf-250810b4e399-jpg  What did you do with your 4runner today?-f2829e12-d160-427e-a2d1-74f51c5e06fc-jpeg
Detroitdiy is offline   Reply With QuoteReply With Quote
Old 05-27-2020, 03:25 PM #34149
Jayson44's Avatar
Jayson44 Jayson44 is offline
Jayson44 will become famous soon enough
Jayson44's Avatar
got my wheels in. just waiting on the new 35s to get here...
J.
05 v8 Sport - K&N air filter - Toytec Ultimate front + OME 3" rear - JBA HD UCAs - Spydertrax spacers - 35" Kenati Trail Hogs - Vors v37s
Jayson44 is offline   Reply With QuoteReply With Quote
Old 05-28-2020, 06:53 PM #34150
Real Name: Danny
Real Name: Danny
I did the front portion of the Daystar lift and while I was at it I replaced both cv axles. Got tired and it was getting too late to get it aligned so I decided to get up early tomorrow and do the rear then take it straight to the alignment shop. The job wasn't all that bad but my age and my Rhematoid Artiritis made it kinda rough on me. The worst part for me was getting the two lower ball joint bolts lined up while pulling down on the spindle to get the bolts started. I finally used a bungee cord to hold the spindle/ upper control arm down then all I had to do was maneuver it around till the bolt lined up with the hole. I spent between 3.5 and 4 hours to do the spacer lift and both axles. Also refilled the front diff for what I lost when the axles were out. It's definitely higher in the front now. Can't wait to do the rear and finally have it level.
Old 05-28-2020, 09:49 PM #34151
Real Name: Wes
Real Name: Wes
Plastidipped the grill today! Waiting for my orange to get here for the emblem!
--Build Thread--
Old 05-28-2020, 10:24 PM #34152
Warwicke36's Avatar
Warwicke36 Warwicke36 is offline
Warwicke36 is a jewel in the rough Warwicke36 is a jewel in the rough Warwicke36 is a jewel in the rough
Warwicke36's Avatar
Installed my scangauge2 today. Easy as it gets... Codes worked mint on my 2004 A340 for AT trans temp. Thanks to this forum for those!
What did you do with your 4runner today?-20200528_130308-jpg
2004 Sport 4.0
Warwicke36 is offline   Reply With QuoteReply With Quote
Old 05-28-2020, 11:08 PM #34153
JBend JBend is offline
JBend will become famous soon enough
Finally got a few things done yesterday. Purchased it on 4/20 this year so have been gathering parts for suspension and maintenance as well as audio. Wednesday I swapped out the original spark plugs (155k) on them, oil change, you all convinced me to do the HCF delete, AFE pro dry is in the mail and swapped in my new head unit, a pioneer dmh-2660. I tried the headlight restoration and it seemed to turn out well, but I can't get the 'orange peel' out. Tried 3k wet sand, do I try 2k or 1k? Eibach Pro kit is in the living room and going in in two weeks(mechanic has a lot of business I guess). Deciding on wheels and tires now, so any suggestions I'll listen same with maintenance things I may have over looked.
JBend is offline   Reply With QuoteReply With Quote
Old 05-28-2020, 11:10 PM #34154
And my pictures wont load for some reason, so sorry I guess.
Old 05-29-2020, 01:19 AM #34155
Jpilot Jpilot is offline
Real Name: Joe
Jpilot will become famous soon enough Jpilot will become famous soon enough
Real Name: Joe
Bagged the old girl
I had some issues when going over speed bumps and those water drainage dips in the road. My rear end always seemed to bottom out with a good thud. I decided, instead of heavier springs, to try the airbags. At only $88, it was a quick and easy job. I am running them at 12 PSI and it does not bottom anymore. Took the truck 4 wheeling in Colorado, doing green to Red trails. It did great and had no issues whatsoever in the rear.
I do run a set of drawers in the back and keep them pretty full of recovery/camping stuff, so some additional weight. Also run a rooftop tent sometimes, so wanted some help in the rear.
What did you do with your 4runner today?-img_2793-jpg
Jpilot is offline   Reply With QuoteReply With Quote
4runner , 4th gen , desertarmor , mods , outgearsolutions
Bought my first 4runner today! mechagouki New Members 57 02-20-2024 01:12 PM
Weird Problem today with my 4Runner today. myT4RisGREEN 3rd gen T4Rs 12 12-11-2021 08:17 PM
My 4runner got smacked today! Rez90 4th Gen T4Rs 11 10-09-2013 05:03 PM
I got my 4Runner today NavyChiefnMD 5th gen T4Rs 5 12-17-2009 01:12 PM
