08-15-2020, 09:30 PM
#34516
I took my truck out on the beach for some sun!
Ben
1996 T4R SR5 4wd 5speed manual 3.4 V6
Evergreen Pearl w/ Taupe cloth
265/75 16 BFG AT T/A KO2, E load
297,000+ miles...
08-16-2020, 04:29 PM
#34517
Real Name: Joe
Real Name: Joe
Originally Posted by GBagwell
Full disclosure, I did not do this today. But I’ve done a ton in 2020 while being somewhat confined to my shop. The best bang for your buck was these reverse lights Luyed LED light bulbs. I was looking at adding some reverse lights, but between these that light up like headlamps and another mod I did I’m super satisfied. For like $13 and push-in to install it’s a no brainer. I hope the photos do it justice but I think you get 5hr picture.
Thanks to this forum for ideas, sourcing and inspiration. I’ll share more in the days to come.
I've got those too. Makes a huge difference at night backing up!
08-16-2020, 04:53 PM
#34518
Real Name: Joe
Real Name: Joe
Mono.75 I think your build post was the one that convinced me to go with the GTA Bluetooth. I’m very happy with it and also the factory head unit. On my 2003 4RNR. I’m sticking it hit as long as holds up.
This forum has provided a ton of good advice and inspiration.
Was thinking about the GTA kit myself, but head-units with bluetooth and CarPlay aren't too much more. You don't realize how much the factory radio/speakers have degraded until you replace them. It's kind of like being in a room that smells bad. After a while you get used to it and don't notice the smell. You don't realize how bad the factory radio sounds until you replace it. Adding bluetooth to a 15+ year old truck doesn't really do much. The new radio really brought some life back into my speakers.
08-17-2020, 12:10 AM
#34519
Originally Posted by Nahrah
Did you disable your old 3rd brake light? Could you also tell me the sellers name? Thank you
07 SR5 4x4
08-17-2020, 12:13 AM
#34520
Swapped out for ss extended brakelines and cv axles.
07 SR5 4x4
08-17-2020, 12:56 AM
#34522
I just pulled the bulb out and put back the housing. I then used dorman Conduct-Tite Blue 16-14 Gauge T-Tap Terminal to spice into the original wire. I basically drilled three holes two for the bolt and one for the led brake light wire to go through. I also got 3m double sided molding tape to to secure it more even though it came attached with some foam seal. I also watched a video on youtube where a fellow 4th gen owner installed his.
Here's the ebay listing Factory Style Rear Roof Mount Painted Rear Spoiler Fits 2003-2009 Toyota 4Runner | eBay
seller is autorestylers
Current - 21 TRD ORP, Method 316 on 285/75/17 Toyo MT, Bilstein 5100’s OME 885/889, Spc UCA
Old(still in the family) - 07 Sr5 V6 2wd, Bilstein 5100's, Ome 884/895e, TRD ORP wheels, SPC UCA and CBI front skid plate.
08-17-2020, 01:09 AM
#34523
Took a drive and ended up at a local watering hole.
Waited til it cooled down to tackle this abs pump motor replacement.
The new abs motor is a lot quieter, but still have the noise behind the dash when the pump kicks on. I'm starting to think its the accumulator.
08-17-2020, 05:47 AM
#34524
Real Name: Skip
Real Name: Skip
You're going to still hear the motor running, that's normal, NOW if it runs for a long time is when I would worry about the accumulator being bad, the motor running for around 10 second or so and then again after you depress the brake pedal 3 or 4 times is normal, any more often than that then it's possibly not hold pressure.
2004 Limited V8
08-17-2020, 12:43 PM
#34525
Mine does it even when the brake pedal is not being pressed. Kicks on for 10sec then off then back on a few minutes later, but there's a screeching noise that goes along with it behind the dash. Started happening when I took a trip to Sequoia national Park.
08-17-2020, 04:55 PM
#34526
Real Name: Skip
Real Name: Skip
It sounds like the booster/ABS pump that the electric motor drives is going bad, IMHO.
2004 Limited V8
08-17-2020, 05:11 PM
#34527
That's what I'm afraid of.
08-17-2020, 10:09 PM
#34528
2003 Limited V8 4runner - 37's, Tacoma Front End swap, ARB locked front and rear , LC200 rack swap
08-18-2020, 12:52 AM
#34529
Thank you!
Swapped out my old hatch struts for some new ones. Simple swap and no more squeaking struts! It lifts up by itself now.
07 SR5 4x4
08-19-2020, 01:19 PM
#34530
Real Name: Russell (OB #9908)
I replaced these with aftermarket a couple of years ago and one of them just physically broke where it attached to the little ball at the bottom. Decided to go OEM this time when I found them for $33 each through Cobb County (Metro Atlanta) Toyota’s online parts store. Have to say the experience was great; placed the order on Monday morning, got the email that the parts were ready on Tuesday morning, and was in & out of the parts department in about 30 seconds that afternoon. I installed them this morning and the hatch operation is better than it’s ever been since I bought the truck in 2014.
I also spent $10 on some reflective insulation & about 30 minutes cutting some custom sunshades for the front side windows. I had a set for my Xterra and it makes a real difference over just having the windshield shade. In fact, if I lived out west & my truck sat outside all day, I would make a set for all around.
It’s easy to do, just cut a piece a little larger than the window, then hold it in place with one hand while you go around the edge of the window & crease the material with the other. Use the creases as a cutting guide, going a little bit outside the crease, then trim as needed for a snug fit.
Thread Tools |
Display Modes |
Rate This Thread |
Linear Mode
