Thread Tools Rating: Thread Rating: 12 votes, 4.58 average. Display Modes
Old 09-29-2020, 03:38 PM #34681
y=mx+b's Avatar
y=mx+b y=mx+b is offline
y=mx+b has much to be proud of y=mx+b has much to be proud of y=mx+b has much to be proud of y=mx+b has much to be proud of y=mx+b has much to be proud of y=mx+b has much to be proud of y=mx+b has much to be proud of y=mx+b has much to be proud of y=mx+b has much to be proud of
y=mx+b's Avatar
Originally Posted by originalg00kster View Post
You need one of these. Not sure of the name. But it came right off with ease.
Although a torx bit will fit, its technically a 10mm allen key/male hex socket. Awesome that you were able to get yours out, California rust free must be nice lol. Me not so much, had to weld a nut on mine. Posted a pic a few replies up
y=mx+b is offline   Reply With QuoteReply With Quote
Old 09-29-2020, 03:42 PM #34682
originalg00kster's Avatar
originalg00kster originalg00kster is offline
originalg00kster is a jewel in the rough originalg00kster is a jewel in the rough originalg00kster is a jewel in the rough
Ah I got lucky then, glad I didn't strip it. Thanks for the correction.
Yes, luckily I don't have to deal with rust. I feel for you guys in the snowy areas.
07 SR5 4x4
originalg00kster is offline   Reply With QuoteReply With Quote
Old 09-29-2020, 05:09 PM #34683
Tironeous's Avatar
Tironeous Tironeous is offline
Real Name: Joe
Tironeous has a spectacular aura about Tironeous has a spectacular aura about Tironeous has a spectacular aura about
Tironeous's Avatar
Real Name: Joe
I am using a 10mm hex socket. Soaked it in PB Plaster, hit it with some heat, hit it with a hammer while turning it. Still won’t budge.
2005 4Runner Limited V8 4x4 Galactic Gray Mica
Instagram | My "Build" Thread | Bilsten 6112 with 650lb spring | Total Chaos UCAs | Bilsten 5160 with OME 895 | Stealth Custom Series GEN5 Wheels | Dirtcom Trail Swing | Sony XAV-AX5500 | Focal Integration ISS 165 (Front) | Focal RCX-165 (Rear) | Pioneer TS-SW2002D2 (Subwoofer) | Accele RVCLPMBS (Backup Camera)
Tironeous is offline   Reply With QuoteReply With Quote
Old 09-29-2020, 05:15 PM #34684
Tironeous's Avatar
Real Name: Joe
Tironeous's Avatar
Real Name: Joe
I’m changing mine with 90341-24016 from a Lexus GX. It’s the same size but instead of a 10mm hex it’s a 14mm socket. Not my picture but here’s an example
Old 09-29-2020, 05:43 PM #34685
y=mx+b's Avatar
y=mx+b's Avatar
I gotta get one of those, I warped my plug flange welding to it and it started leaking. I rtv'd the crush washer as an experiment when I had it back apart to replace a CV and it hasn't leaked yet lol
Old 09-29-2020, 06:13 PM #34686
PC1978 PC1978 is offline
PC1978 is on a distinguished road
Changed diff and transfer case fluids with Mobil-1. Can’t get the drain plug off the front. Made an appointment with the dealer to take it off. Purchased a Lexus GX diff plug, which uses a socket.
If you don’t already have an impact gun, might consider getting an electric one (unless you have a compressor, in which case you probably have an impact).
Not 100% sure but looks like it would fit to get that plug.
And it will come in real handy for other DIY jobs, especially if you have rust.
Don’t have to spend a bunch if it’s just being used for occasional DIY.
Example:
BAUER 1/2 In. Heavy Duty Extreme Torque Impact Wrench for $79.99 – Harbor Freight Coupons
Hex Impacts:
1/2 in. Drive Metric Impact Hex Socket Set, 8 Pc
Basic Impact socket set:
3/8 in., 1/2 in. Drive SAE & Metric Impact Socket Set, 37 Pc.
Universal joint:
Universal Impact Joint Socket Adapter Set,3 Pc.
PC1978 is offline   Reply With QuoteReply With Quote
Old 09-29-2020, 06:54 PM #34687
Tironeous's Avatar
Real Name: Joe
Tironeous's Avatar
Real Name: Joe
Example:
Hex Impacts:
Universal joint:
Hit it with my brushless impact. It’s only a Ryobi but it still has decent torque. The plug didn’t budge.
Old 09-29-2020, 07:17 PM #34688
4Runn1nYota's Avatar
4Runn1nYota 4Runn1nYota is offline
4Runn1nYota is on a distinguished road
Hey not yet at least! Haha.
I bought the expensive battery at o'Reilly's, some heavy AGM battery. The back panel is actually on a kill switch, so I only have it on when I need it. As for the front it's only the voltmeter that is on all the time which I'm sure gives little draw. It's also my daily so it's being turned on every 1-2 days at least.
Kill switch is def a smart move!! good thinking.
1996 4Runner (SOLD)
2005 Tundra AC
2010 FJ Cruiser (SOLD)
2019 TRD O/R
2007 V8 Limited
4Runn1nYota is offline   Reply With QuoteReply With Quote
Old 09-29-2020, 08:42 PM #34689
T4Rmiller T4Rmiller is offline
T4Rmiller is on a distinguished road
Thankfully, you're not along on the stuck front diff drain, happened to me too. I ended up welding a nut on there to get it off lol
Ive always put the weld in the middle of the nut, that way you can easily get a wrench on it
T4Rmiller is offline   Reply With QuoteReply With Quote
Old 09-29-2020, 08:54 PM #34690
montijo505's Avatar
montijo505's Avatar
That plug weld coming in clutch
Sent from my SM-G986U using Tapatalk
Old 09-29-2020, 09:14 PM #34691
y=mx+b's Avatar
y=mx+b's Avatar
I tried that but I am not the best welder and couldn't get it down in the nut lol. I had bought the welder that same weekend (this was probably 8 months ago) to both weld a nut on the plug and fix a metal bracket on a seat for my mom. I just hammered a socket on there and the plug came right out with a breaker bar. Not ideal since have only half the nut to grab on, but it worked! I was pretty newb status then, but I'm practicing and trying to get better.
Old 09-29-2020, 11:25 PM #34692
Sausage_gut Sausage_gut is offline
Sausage_gut is on a distinguished road
Got this 04 limited V8 a couple of weeks ago. I detailed it inside and out and just removed the rock feelers
Sausage_gut is offline   Reply With QuoteReply With Quote
Old 09-30-2020, 10:20 AM #34693
brakemad17 brakemad17 is offline
brakemad17 is on a distinguished road
Thanks y=mx+b! I'll have to get right on and posting then!
brakemad17 is offline   Reply With QuoteReply With Quote
Old 09-30-2020, 11:43 AM #34694
Now that I am back in Raleigh, I swear I will never buy a car with rust again.
Needed to replace the shocks and struts, sway bar links and outer tie rods (cracked/broken rubber boots), and had a front wheel bearing going.
Got my parts from 1A Auto | Aftermarket Car Parts - Buy Quality Auto Parts Online , not top of the line but not the bottom of the barrel either. This is just a daily driver/commuter and wasn’t looking to spend a bunch for a premium suspension, so hopefully it doesn’t come back to bite me.
183k miles, was a PA car for most of its life. I bought it in OH at around 120k, now in Raleigh NC.
Frame is still solid, but there is rust everywhere underneath.
It is super clean though inside and out, and paint and body are in great shape.
Front wheel hubs are an easy job, just had to get the loaner axle socket from Autozone. I just did them both since I believe the originals were still on.
Rear shock mount sleeves on both sides were rusted/seized to the mount.
Tried to pry and beat them off, no luck.
Used a jaw puller to pull them off, but just tore the rubber bushing off and left the sleeve still seized to the frame mount.
Tried for quite a while to beat it, rotary hammer drill w/chisel to the tiny crevice at the back of the sleeve, Kroil, heat, more beating, jammed an impact socket on it (didn’t have an extractor socket that big) and hit it with an impact gun hoping it would break loose.
Would budge a bit.
Finally broke out the grinder.
Started at the top and started slowly shaving it off. Didn’t cut straight in as I didn’t want to cut into mount.
Once I ground through the sleeve I could see a line differentiating the metal sleeve from the mount.
Used the line as a guide as I worked my way around shaving/grinding the metal sleeve and not shaving off the mount.
Shaved down on both sides from the top until most of the top half of the sleeve was gone.
At that point I was able to tap the edge of the remaining bottom half of the sleeve and it fell off.
Hit it real good with a wire brush on a drill to ensure all rust was removed and slathered the mount and inner sleeve of the new shock in anti-seize before installing.
Then on the front struts the top plate of the strut mount was rusted/seized to the housing.
After trying everything I could think with no luck, finally got the idea to use a ratchet strap with one hook around the top of the spring (wedges against the strut housing) and the other hook to the frame.
Cinched it down extremely tight. Got the top of housing nice and hot and a couple whacks with the hammer and it popped right off with the downward pressure from the strap.
What an ordeal, on what normally is pretty straightforward.
Probably should have expected it though, put a Magnaflow Cat-back exhaust on it after I got it and there was a lot of “extra” grinding required to get the old one out.
Used a ton a anti-seize on the reinstalls, coated every metal to metal contact surface.
But no more grinding noise from the bearing and no more “extra” bouncing over the road bumps/body roll.
Ball joints and CV axles are still good, but I’m sure my day is coming.
Will probably just replace the control arms at that time, as the current ones look pretty crusty and the bushings should probably be replaced then also.
Probably a whole lot easier (and not much more $) just to replace the CA’s.
Rust sucks.
Old 09-30-2020, 06:12 PM #34695
aemravan aemravan is offline
aemravan has a reputation beyond repute aemravan has a reputation beyond repute aemravan has a reputation beyond repute aemravan has a reputation beyond repute aemravan has a reputation beyond repute aemravan has a reputation beyond repute aemravan has a reputation beyond repute aemravan has a reputation beyond repute aemravan has a reputation beyond repute aemravan has a reputation beyond repute aemravan has a reputation beyond repute
Today I joined the big boy tire club
Sent from my SM-G970U using Tapatalk
2003 Limited V8 4runner - 37's, Tacoma Front End swap, ARB locked front and rear , LC200 rack swap
aemravan is offline   Reply With QuoteReply With Quote
4runner , 4th gen , desertarmor , mods , outgearsolutions
Bought my first 4runner today! mechagouki New Members 57 02-20-2024 01:12 PM
Weird Problem today with my 4Runner today. myT4RisGREEN 3rd gen T4Rs 12 12-11-2021 08:17 PM
My 4runner got smacked today! Rez90 4th Gen T4Rs 11 10-09-2013 05:03 PM
I got my 4Runner today NavyChiefnMD 5th gen T4Rs 5 12-17-2009 01:12 PM
