Originally Posted by AuSeeker
Looks very good!
What brand paint did you use and where did you buy...did you use spray cans or paint gun, did you do a clear coat after color coat?
How much paint did you use?
ATX paint, I can look up to see what paint code exactly I used, they have quite a bit of variants that pull up under my cars paint code, but we went with the default and it matched pretty close.
I bought it from a local sherwin williams auto supply store where the shop my brother works out sources a lot of their stuff. I bought 2 quarts and thus far sprayed out 1 entire can using 1:1 reducers. I had JUST enough I feel like to cover the trim (excluding the front bumper) and the entire rear gate in about 3-4 coats.
and it was definitely sprayed with a gun, I've gone the spray can route before and it is harder, longer, more expensive and not even worth the comparison result wise..
I sprayed 1 light coat of clear and about 2-3 (depending on the area) heavy wet coats that were wet enough to ALMOST have some runs so that it flowed out nice.
