01-13-2021, 01:24 AM
#35026
Heated seats install and finished floor lighting under seats
Installed my heated seats kit from Clazzio. Definitely make a huge difference as the leather Clazzio covers sure are cold in the morning! Went ahead and drilled a spot for my future “armed” power button for my push LED buttons in center console for when the dogs step on them and we’re not aware.
Also finally installed LED strips under my seats for the rear foot illumination since I already had the seats out, figured I’d complete the interior LED illumination. The Weathertech matts block a lot of the light int the rear though. Still happy, LOTS of light, love it!
My build thread https://www.toyota-4runner.org/4th-g...ml#post3520544
2008 Titanium Metallic 4WD 4Runner V6 SR5| Satoshi Grille mod|17x8 Level 8 MK6 wheels, 275/70/17" Falken Wildpeak tires| Front-Bilstein 5100's set at 0 with ToyTec branded Eibach silver springs and 1/2" ToyTec spacer driver side, 1/4" ToyTec spacer passenger|Front Diff. drop spacer kit|sway bar relocate kit| Rear-Fox 2.0Resi and ToyTec superflex black springs|Tyger Bull bar with LED's/Lund HX tube side steps
2021 Subaru Crosstrek Limited in Crystal White Pearl
01-13-2021, 04:36 PM
#35027
love the blacked out wheels
01-13-2021, 05:26 PM
#35028
Originally Posted by cwilliams563
Had this for probably at least 6 mos. Finally found a buddy that had a 220v welder. Didn’t get any before pics but definitely very close to level now for the pan hard bar. Had a pretty bad angle previously. 4Runner handles better on bumps, and bounces more vertical at higher speeds instead of wagging like it did. Feels more stable in higher speed turns as well.
I need to get under there with a wire wheel and clean the whole underside up and then paint.
Still need to do mine. Just trying to brush up on my welding before I jump in.
04 V6 4x4. Eibach Pro Truck Shocks, OME 885, Icon 2" Springs. JBA UCA. 255/75/17 Kenda Klever AT/2. Spartan rear locker(removed). PCK. Hidden Winch
01-14-2021, 06:23 PM
#35029
Just a heads up, it’s a pretty good fit on the front and side but the back has a pretty big gap and hard to access from both sides. Just an fyi to plan for that. Taking the rear driver tire helps a lot.
01-14-2021, 06:26 PM
#35030
Finally got the 4x innovations sliders fully on. Thry look great.
Sent from my SM-G970U using Tapatalk
2003 Limited V8 4runner - 37's, Tacoma Front End swap, ARB locked front and rear , LC200 rack swap
01-14-2021, 06:31 PM
#35031
Thanks for that. Ill be removing the wheel and spring when I do mine. The more space the better. Did you weld the inside too, or just the outsides?
01-14-2021, 06:38 PM
#35032
Registered User
Real Name: Morris
Registered User
Real Name: Morris
Looks good! What size tires are you running?
01-14-2021, 07:19 PM
#35033
Removing the spring to get as much room in there would help. I actually used my spring to ziptie the speed sensor cable out of the way and brake line as also. We did as much as we could on both the inside and outside. I would have liked to have it been 100% welded on both but wasn’t able to achieve that.
01-14-2021, 08:30 PM
#35034
Real Name: Doc
Real Name: Doc
While waitin' on bolt extraction sockets to arrive for the rear bump stops and spacers job, today the Krylon-painted aftermarket grille and OEM bug deflector somehow hopped up on the rig. Rusted acorn nuts and grille bolts gone!
Stock 2008 Driftwood V8 4WD Limited with X-REAS, est. late 2020. Build page to come...
01-14-2021, 09:01 PM
#35035
Thanks ! I'm on 35s. 12.5 wide i believe.
01-14-2021, 10:19 PM
#35036
Just buy those 35's already momo lol, I see you doing the research on all the associated threads.
Sent from my SM-G986U using Tapatalk
01-15-2021, 05:32 AM
#35037
Threw the RC 3” spacer lift on and some 285/70 AT’s on AR wheels. Looks great, rides like a pile of garbage lol. Couldn’t leave it stock so this will hold me over until I have the money for the 3” Pure performance kit.
01-16-2021, 02:12 AM
#35038
Yep, I have a Daystar 2.5/1.5 on mine and it just doesn't feel solid on the highway. Once I get back to my dad's garage, I'll bust off the lower frozen strut bolts and get the lift outta there. Was fun for 40k miles, but I prefer control
01-16-2021, 05:17 PM
#35039
Real Name: Doc
Real Name: Doc
Today?
Well, hell, I managed to make 4R life a little more interesting.
For some reason, the title of the movie "The Good, The Bad and The Ugly" popped into my head, along with a few tasty expletives.
But I sure like my new small pipe wrench!
Is it beer-thirty yet?
01-18-2021, 01:18 AM
#35040
Real Name: Blair
Real Name: Blair
2008 4Runner Sport Edition 4WD V6- Long Travel, Camping Rig Build Thread
2023 Lexus LX600 F Sport- Daily Driver
2023 Highlander Hybrid Limited- Wife Daily Driver
