Thread Tools Rating: Thread Rating: 12 votes, 4.58 average. Display Modes
Old 05-02-2021, 09:57 PM #35371
Hi-desertT4R's Avatar
Hi-desertT4R Hi-desertT4R is offline
Real Name: Matt
Hi-desertT4R is just really nice Hi-desertT4R is just really nice Hi-desertT4R is just really nice Hi-desertT4R is just really nice Hi-desertT4R is just really nice
Real Name: Matt
Figured out my rear door speaker issue with my Pioneer hu by messing with the settings for 45 minutes. Tried replacing the burnt out bulb in the information center but I guessed on the exact bulb type and got the wrong ones from Napa auto parts. The nearest Toyota dealer is about an hour and fifteen minutes away so next time I’m in Vegas I’ll get the right ones. Started on my lower link skids which are based off of the design I found on the website of member @mikestang , Mike's Garage. Cool stuff on there. I’ll get the final fit and finish this week and should have them welded on next weekend.
What did you do with your 4runner today?-c51b473d-5c49-4115-bd2a-1c9adedc47c4-jpeg
2007 Titanium SR5 4WD
Build thread: https://www.toyota-4runner.org/4th-g...ld-thread.html
Hi-desertT4R is offline   Reply With QuoteReply With Quote
Old 05-03-2021, 12:07 PM #35372
Heffernan's Avatar
Heffernan Heffernan is offline
Heffernan will become famous soon enough
Heffernan's Avatar
Finally got around to installing a pair of new OEM rear springs, along with the rear OME 10mm spacer and ToyTec front 1/4" topout spacer to fix the lean issue on the drivers side. I gain a full 1" of lift in the rear and another .5" in the front. The truck sitting perfectly level now.
2008 Toyota 4Runner Sport V6
5100s / front 4x4 FJ springs / OEM stock rear springs
ToyTec 1/4" topout spacer & OME 10mm trim packer (both driver side)
General Grabber AT2 tires
Heffernan is offline   Reply With QuoteReply With Quote
Old 05-04-2021, 04:26 PM #35373
Bluesky 07's Avatar
Bluesky 07 Bluesky 07 is offline
Real Name: Russell (OB #9908)
Bluesky 07 has a brilliant future Bluesky 07 has a brilliant future Bluesky 07 has a brilliant future Bluesky 07 has a brilliant future Bluesky 07 has a brilliant future Bluesky 07 has a brilliant future Bluesky 07 has a brilliant future Bluesky 07 has a brilliant future Bluesky 07 has a brilliant future Bluesky 07 has a brilliant future Bluesky 07 has a brilliant future
Bluesky 07's Avatar
Knocked out some maintenance items:
- Rotated the tires & checked PSI
- Checked torque on Spidertrax bolts (no issues) & the steering shaft slide yoke bolts (they were right on at 26 ft/lbs)
- Lubricated the caliper slide pins, steering shaft u-joint, and all hinges (doors, hood, hatch)
Added this voltmeter/USB port to my dash. Had to enlarge the switch opening and learned a valuable lesson about being careful with the Dremel by creating a big scratch at the lower left corner.
Bluesky 07 is offline   Reply With QuoteReply With Quote
Old 05-05-2021, 03:42 AM #35374
cwilliams563's Avatar
cwilliams563 cwilliams563 is offline
cwilliams563 has a spectacular aura about cwilliams563 has a spectacular aura about cwilliams563 has a spectacular aura about
Victory 4X4 full rack installed
Finally got around to putting my Victory rack together and swapping it out for the factory rack.
What did you do with your 4runner today?-780c436f-e1ef-43cd-b7f9-e08874ab216f-jpeg  What did you do with your 4runner today?-832d5b0d-199e-469d-9265-3f8157b4d509-jpg
My build thread https://www.toyota-4runner.org/4th-g...ml#post3520544
2008 Titanium Metallic 4WD 4Runner V6 SR5| Satoshi Grille mod|17x8 Level 8 MK6 wheels, 275/70/17" Falken Wildpeak tires| Front-Bilstein 5100's set at 0 with ToyTec branded Eibach silver springs and 1/2" ToyTec spacer driver side, 1/4" ToyTec spacer passenger|Front Diff. drop spacer kit|sway bar relocate kit| Rear-Fox 2.0Resi and ToyTec superflex black springs|Tyger Bull bar with LED's/Lund HX tube side steps
2021 Subaru Crosstrek Limited in Crystal White Pearl
cwilliams563 is offline   Reply With QuoteReply With Quote
Old 05-05-2021, 03:43 PM #35375
New OEM Headlights
I finally broke down and replaced my crummy Arcani (I think is the brand name) headlights from Amazon with new OEM’s. Bought the 4Runner and headlights were yellowed and looked a little rough. Couldn’t stomach the price of new OEM headlights.
Within 3 months the Amazon headlights already started to yellow and delaminate. Within about 5 months the passenger side turn signal bulb housing was melted and while trying to remove/replace, the bulb broke off in the headlight housing!
Removing the other headlight last night the other bulb was also stuck in the melted housing. Anyways I just threw them away last night, GOOD RIDDANCE! LOL.
Old yellowed and delaminating
Bulb broken off and stuck inside headlight housing on passenger side
Bulb stuck in melted headlight housing on drivers side from replacement last night
New OEM, such a difference! Need to get something to seal with and protect.
Old
Old 05-06-2021, 01:11 AM #35376
montijo505's Avatar
montijo505's Avatar
Anyone ever replace the weather stripping along the front windshield/roof? Mine is sticking up. What did you do with your 4runner today?-img_1947-jpg
Old 05-07-2021, 09:28 PM #35377
rdruss's Avatar
rdruss rdruss is offline
Real Name: Ron
rdruss's Avatar
Real Name: Ron
Replaced hose on PCV valve as it was pretty hard on the ends and I noticed my PS valve cover is covered in light oil/road grime, think the hard end of tube along with crappy pinch type clamp may have given up after 17 years!
Replaced with a length of 3/8 hose and stainless worm screw clamps.
PCV was clean and operative.
Old 05-10-2021, 05:57 PM #35378
Bluesky 07's Avatar
Bluesky 07's Avatar
Paid a local muffler shop $40 to cut off the resonator and reroute the exhaust to the side. As others have noted, this makes no difference in sound.
Old 05-10-2021, 09:05 PM #35379
gaber6 gaber6 is offline
gaber6 has a spectacular aura about gaber6 has a spectacular aura about
Originally Posted by montijo505 View Post
Anyone ever replace the weather stripping along the front windshield/roof? Mine is sticking up. Attachment 381512
Mine sticks up there too. I considered trying to hammer it down, but then I forget about it for 5 months.
gaber6 is offline   Reply With QuoteReply With Quote
Old 05-11-2021, 01:57 PM #35380
Got_boost Got_boost is offline
Got_boost will become famous soon enough
Weekend upgrades
I had a busy weekend, but was able to replace the radiator, new t-stat,t-stat housing, upper/lower hoses, install a trans cooler, switched to sport step/running boards, and upgraded my tires to BGF KO2s (265/70/17)
Yes, it snowed today - 11 May 2021
What did you do with your 4runner today?-4runner_new-tires-jpg
Got_boost is offline   Reply With QuoteReply With Quote
Old 05-11-2021, 02:06 PM #35381
Bluesky 07's Avatar
Bluesky 07's Avatar
I finally fixed my maddening roof rattle the other day using cutting-edge materials and techniques. My observation that I could stop the rattle by gently pulling down on the headliner right at the passenger side front corner of the sunroof opening, combined with @gRunner3's 2010 post, led to folding over a piece of cardboard and wedging it above the headliner as shown. Rattle gone!
Old 05-11-2021, 02:30 PM #35382
Real Name: Matt
Real Name: Matt
That trim piece sticks up on mine after running my light bar wiring underneath it. Looks like there’s supposed to be some adhesive in there. I’ve been considering using the 3M black super weatherstrip and gasket adhesive.
Old 05-11-2021, 07:03 PM #35383
abp79's Avatar
abp79 abp79 is offline
abp79 is on a distinguished road
abp79's Avatar
Have you drive w rear window down? I’d so, do you still get exhaust smell?
2008 V6 SE Natural White - Toytec Ultimate 3" - Chaos UCAs - Stainless Brake Lines - SCS Stealth 6 17s - 285/75/17 Toyo ATIII - JDM Black Tailights - iBrightStar LEDs - Weathertech Liners All Around
abp79 is offline   Reply With QuoteReply With Quote
Old 05-11-2021, 07:26 PM #35384
montijo505's Avatar
montijo505's Avatar
Good idea, I’ll try that!
Old 05-11-2021, 07:27 PM #35385
montijo505's Avatar
montijo505's Avatar
As someone who did this a long time ago, yes. No way around it, maybe an axle dump cut but I don’t know.
4runner , 4th gen , desertarmor , mods , outgearsolutions
Bought my first 4runner today! mechagouki New Members 57 02-20-2024 01:12 PM
Weird Problem today with my 4Runner today. myT4RisGREEN 3rd gen T4Rs 12 12-11-2021 08:17 PM
My 4runner got smacked today! Rez90 4th Gen T4Rs 11 10-09-2013 05:03 PM
I got my 4Runner today NavyChiefnMD 5th gen T4Rs 5 12-17-2009 01:12 PM
