05-14-2021, 09:54 PM
#35401
Real Name: Russell (OB #9908)
My 4X Innovations sliders are prepped, primed, painted, & going on tomorrow.
Used Rustoleum Black Stainless Steel Metallic to match my roof rack.
05-15-2021, 12:27 PM
#35402
2007 Sport Edition V8 4WD w/Nav, JBL and rear seat entertainment, Fox 2.5 R/R coilovers, FJC rear springs with Fox 2.0 Pro series shocks, Rear ARB locker, 305/70R17 Ridge Grapplers, DT short headers
05-16-2021, 03:43 AM
#35403
27f would work
31 would work with some mods i think, depending on brand
94r would fit, just shorter
24f would fit, still small
34r with height adapter.
not sure what brands napa offers, but im still rocking 31m from northstar for 6+ years now. i think you might be able to find the oddysee brand.
Originally Posted by cwilliams563
Replaced my battery with a larger CCA rating. 760 CCA 70amp Hours NAPA Legend Premium AGM. I get a decent discount from NAPA due to their partnership with my job so it made sense to try it out.
Needed at least a 650cca battery for my winch I’ll be putting in, hopefully soon. Need to get my voltage booster ordered for the increased voltage charging needed.
OLD, but still good
Pioneer DEH-80PRS,Rockford Fosgate T600-2,Hertz ML 1650.3(2 pairs),T400-2,Hertz ML 280.3(2 pairs),T1000-1bdcp,(2)JL Audio 12W6v3, Mechman 240a HO Alternator, Dual Northstar 31m,Borla Dual Exhaust,AFE Magnumforce intake.Enkei WT-4 Michelin Defender LTX 275/55R20. retrofitted S2000 projectors,Philips 85122 White Vision,Morimoto 5Five Ballast.Diode Dynamics SS3 Yellow Fog Sport.2 pairs of Hella Supertones.Full led conversion on interior and exterior.HAWK Talon Rotors and LTS pads F+R,Stoptech stainless steel lines F+R.Bilstein 5100 @0.85, MOOG FJ Springs front,Bilstein B12 36-281824 rear .
05-16-2021, 09:46 PM
#35404
The 4X Innovations sliders are on. Very happy with the quality and the price is beyond reasonable. (Some competitors' shipping alone is damn near the cost of these sliders.) Painted them with the same Rustoleum Black Stainless Steel metallic paint I used on my roof rack.
05-21-2021, 05:13 PM
#35405
Left real axle seal sprayed everything. I could have fixed it when I saw the first drip but I wanted to be sure it was 80 degrees and humid. Also I love that all my brake parts got fully coated.
I've done the job plenty of times, so it was only a few hours with minimal effort other than reattaching the ebrake springs. I think it'll leak again by next year. I feel like the seal cup needs to be 1/2" instead of only 1/4" so it rides farther out onto the axle. It likely barely has engagement the way it is designed.
05-22-2021, 06:22 PM
#35406
Have you checked/replaced your diff breather?
05-22-2021, 09:32 PM
#35407
If you make one change, you can prevent it from leaking. Flip the retainer around so the bevel faces outboard. See my thread from my FJC.
Cut the old retainer off with a dremmel and cold chissel. Heat the new retainer so it expands and drop it in place. Once it cools, it will seal on the axle. Dont forget the C clip
Rear Axle leak & bearing replacement | Toyota FJ Cruiser Forum
2007 4Runner Sport 4WD 4.0L 228,000 miles
The real stats on gun murders in America compared to the world (link)
Good riddance to the Clinton Crime Family--> I Voted TRUMP…how’s it going for you now Trump is gone? Be careful what you ask for. You may just get it.
05-22-2021, 09:41 PM
#35408
After waiting 6 weeks I finslly received my new RCI gas tank skid plate and installed it this morning. Its a beast. Without the floor jack, I never could have installed it by myself. Looks great.
Got it from offroad lifestyle.
05-22-2021, 11:24 PM
#35409
I finally got around to flushing out my power steering fluid! I definitely should’ve gotten it done sooner it was nasty!
2004 SR5 V8 AWD
05-23-2021, 03:19 AM
#35410
Rotated my tires myself for the 1st time on any vehicle (always took it in since it’s free anyways). Neighbor recommended moving rears straight forward and moving fronts back and cross, seems to make sense.
Put in the voltage booster from Dirty Parts for my AGM battery I just got. Thanks for the tip
@ 4RunnerAquasport
Dirty Parts
Added right at .50volts
Before
After
Installed the Seat Jackers by Desert Does it. Definitely gives support to the back of your legs. Much better angle and cradles your butt, especially with the new seat foam I just installed and new Clazzio leather seat cover. Feels much more comfortable overall. They are pricey and I cringed at the price but they are very heavy duty and well designed.
Before
After
Hadn’t seen any photos with the trim pieces reinstalled. They snapped back on and with the Weathertech mats It’s not very obvious.
My build thread https://www.toyota-4runner.org/4th-g...ml#post3520544
2008 Titanium Metallic 4WD 4Runner V6 SR5| Satoshi Grille mod|17x8 Level 8 MK6 wheels, 275/70/17" Falken Wildpeak tires| Front-Bilstein 5100's set at 0 with ToyTec branded Eibach silver springs and 1/2" ToyTec spacer driver side, 1/4" ToyTec spacer passenger|Front Diff. drop spacer kit|sway bar relocate kit| Rear-Fox 2.0Resi and ToyTec superflex black springs|Tyger Bull bar with LED's/Lund HX tube side steps
2021 Subaru Crosstrek Limited in Crystal White Pearl
05-23-2021, 03:51 AM
#35411
im running the HKB voltage booster with my mechman 240amp alternator, seems to be getting a solid 14.6v , kinda help my dual battery setup.
Rotated my tires myself for the 1st time on any vehicle (always took it in since it’s free anyways). Neighbor recommended moving rears straight forward and moving fronts crossed and back.
Dirty Parts
Before
After
Installed the Seat Jackers by Desert Does it. Definitely gives support to the back of your legs. Much better angle and cups your butt, especially with the new seat foam I just installed and new Clazzio leather seat cover. Feels much more comfortable. They are pricey and I cringed at the price but they are very heavy duty and well designed.
Before
After
Hadn’t seen any photos with the trim pieces reinstalled. They actually snapped back on and with the Weathertech mats It’s not very obvious.
05-23-2021, 09:55 AM
#35412
Did you replace it with ATF? The fact that the 4th Gen uses ATF as PS fluid surprises a lot of people, including me when I bought mine in 2014.
05-23-2021, 10:05 AM
#35413
Yea it says it right there on the cap to use dexron atf so I don’t see why people get so confused.
2004 SR5 V8 AWD
05-23-2021, 11:44 PM
#35414
I plan on getting a dual battery setup (along with many, many other things lol) one of these days. That’s a pretty good boost.
Mine starts out at approx. 14.4v but when I start driving after a few minutes the charging Volts start to drop off and after about 15 minutes it’s down to about 13.8v-14v. Have you monitored yours? Is this normal? Just curious if the system regulates itself even with the booster? Never kept my cigarette charger with volts displayed plugged in and payed attention to it to see if it varied before.
05-24-2021, 10:25 PM
#35415
Headlight restoration
