Thread Tools Rating: Thread Rating: 9 votes, 4.67 average. Display Modes
Old 07-16-2021, 07:49 PM #35551
JonDL JonDL is offline
JonDL is on a distinguished road
I take my 4runner out to do a thing called "herping" lol. It's a nerdy hobby but 4runners are great for it.
This monsoon season is causing my sunroof issues to become too hard to deal with so it brought me to this forum, lol. I've had it jury-rigged for a while but I'm trying to find ways to replace it with a manual sunroof. Once I've got my 15 replies finished I'll have to make a post.
2003 4runner SR5 v8 (4.7l) 4WD
JonDL is offline   Reply With QuoteReply With Quote
Old 07-17-2021, 01:21 PM #35552
originalg00kster's Avatar
originalg00kster originalg00kster is offline
originalg00kster will become famous soon enough originalg00kster will become famous soon enough
haha I've always wondered how it would be to go real life herping. I have 2 pacman frogs myself.
I mounted the ARB compressor to the rear passenger cubby w/ 1 gallon air tank and installed 5 LFD cross bars to the stock rack.
07 SR5 4x4
originalg00kster is offline   Reply With QuoteReply With Quote
Old 07-18-2021, 01:11 AM #35553
The G-Man The G-Man is offline
Real Name: Gary
The G-Man is on a distinguished road
Real Name: Gary
Today I replaced failing head gaskets with the help of a buddy in my garage. Took about 13 hrs with lunch. Luckily the headgasket leak was very small and no head warping so the heads went right back on without milling them.
The G-Man is offline   Reply With QuoteReply With Quote
Old 07-18-2021, 07:41 PM #35554
TN4Runnin TN4Runnin is offline
TN4Runnin is on a distinguished road
Originally Posted by Bagels View Post
Completed the 3rd gen Tacoma TRD grill swap.
Would this be applicable for an 03-05 to your knowledge? Looks awesome
TN4Runnin is offline   Reply With QuoteReply With Quote
Old 07-18-2021, 09:29 PM #35555
RangerT4R RangerT4R is offline
RangerT4R is on a distinguished road
Changed the oil in the diffs and transfer case. Thought the oil from the rear smelled a bit burnt. I took a whiff from the new bottle to compare, and nope that's just what gear oil smells like
RangerT4R is offline   Reply With QuoteReply With Quote
Old 07-18-2021, 09:40 PM #35556
MacRendar's Avatar
MacRendar MacRendar is offline
MacRendar is on a distinguished road
MacRendar's Avatar
Yea, those and ATF are not pleasant. Definitely smell 'burnt' even brand new.
MacRendar is offline   Reply With QuoteReply With Quote
Old 07-19-2021, 03:19 PM #35557
vipergrhd's Avatar
vipergrhd vipergrhd is offline
vipergrhd is on a distinguished road
vipergrhd's Avatar
Parts list?
I could not find one but once you get started you see what needs to be done. Basically just trim out the inner portion of the stock grill and then slowly remove portions of the Tacoma grill until it fits snug in place.
Then I drilled holes in the grill insert and stock grill to zip tie them together. Two on each side where the two grills touch. Covered the zip ties up with two part plastic epoxy and then put epoxy on all other contact surfaces. A little black paint on places the epoxy is viable and reinstall!
Do you mind posting what parts are needed for this grill swap? Thanks for posting.
Could you post some pics of the back side of the grill?
vipergrhd is offline   Reply With QuoteReply With Quote
Old 07-20-2021, 08:26 PM #35558
Bluesky 07's Avatar
Bluesky 07 Bluesky 07 is offline
Real Name: Russell (OB #9908)
Bluesky 07 is a splendid one to behold Bluesky 07 is a splendid one to behold Bluesky 07 is a splendid one to behold Bluesky 07 is a splendid one to behold Bluesky 07 is a splendid one to behold Bluesky 07 is a splendid one to behold Bluesky 07 is a splendid one to behold
Bluesky 07's Avatar
Today I replaced the 11 fasteners like the ones circled in the pic. They hold the black plastic cover just forward of the radiator. Most of mine were loose or missing, and these from Amazon are a perfect fit. They’re also used elsewhere on the 4R so having some spares will be handy.
Tip: the 2 holes these fit in at the bottom left & right of the piece seem smaller than the others and I found the easiest thing to do was back the screw-like part out all the way, insert the receptacle into the holes, then put the screw thing in.
I also followed up on our recent Outer Banks trip by removing the skids and doing a complete underbody wash with Simple Green (through a soap nozzle) and pressure-washer rinse. Found we had brought a little bit of the South Core Banks home with us. ;-)
Finally, I wire-brushed some surface rust off the skids and painted them with Rust Reformer.
Bluesky 07 is offline   Reply With QuoteReply With Quote
Old 07-23-2021, 03:26 PM #35559
LasVegasRunner LasVegasRunner is offline
LasVegasRunner is on a distinguished road
Originally Posted by eleven14 View Post
Installed this backup camera yesterday in anticipation of replacing the OEM head unit when I replace the evaporator core. No idea on longevity, but install was straight-forward and it looks OEM.
While waiting on Denso/Sony parts, I wanted to get the pain of routing wires around the back window and into the cabin out of the way and it didn't disappoint. I also proactively ran wiring for LED hatch lights once I get around to it, will captured details when I do.
Some install notes:
  • Since the replacement head unit hasn't shipped yet (bought this just-released Sony unit), I verified camera operation and placement using a 9V battery and spare TV. Worked like a charm.
  • For running the wires from the hatch to the cabin via the rubber grommet, liquid dish soap and water was a game-changer.
  • This seems obvious but check rear-window clearance before you button it all back up.
  • I noticed evidence of water infiltration into the hatch and will be replacing the hatch window weatherstripping to help prevent a larger issue.
I was gonna document the backup camera install process for a how-to but found that it's been covered fairly thoroughly. That said, if anyone is interested, happy to pull one together for this camera.
@eleven14 , would you be willing to document your hatch trim removal and replacement if you havenít already done it. Mine has gone bad as well and needs replacing.
2006 V8 Sport Edition
LasVegasRunner is offline   Reply With QuoteReply With Quote
Old 07-24-2021, 11:29 AM #35560
eleven14 eleven14 is offline
eleven14 will become famous soon enough eleven14 will become famous soon enough
I definitely can, but you may not need documentation (assuming this is what you're referring to). This post has the procedure from the FSM (I'm only replacing the OUTER).
Seems simple - the steps as I understand them:
  • Roll down back window
  • Pop clips on old outer weatherstripping
  • Install new weatherstripping
Will snap a few pics when I get around to it.
eleven14 is offline   Reply With QuoteReply With Quote
Old 07-25-2021, 02:52 PM #35561
Vette468's Avatar
Vette468 Vette468 is offline
Vette468 is on a distinguished road
Vette468's Avatar
I installed my Diff drop, boots were Dead right after the lift of course'..and a New Radiator-,in the last cupple weeks'..I hardly drive it but No milkshake here, I got a Compressor installed and Welded me up a Scrap Metal Bike Rack,
Hot Rodder Car Nutt- Enthusiast for over 35 years! Biker -Builder ..Amateur GunSmith-Amateur Explosives Expert-Expert P%ssy LicQer ... E-Lock Grey Wire Mod. Rough Cunt' 3'Lift' Dick Cepek DC2s- 16x8' -12 offset" 285 75 16' IRONMAN MUD COUNTRY's ' ,On-Board Air,"EngineStand Tire Carrier" 12,000lb'winch'-DualBatterys
Vette468 is offline   Reply With QuoteReply With Quote
Old 07-25-2021, 03:15 PM #35562
Bada_Bings Bada_Bings is offline
Bada_Bings is on a distinguished road
Got the new rack installed. Need to find a home for the old one.
What did you do with your 4runner today?-6f59bff7-015b-4575-b122-d085614733c4-jpeg
Bada_Bings is offline   Reply With QuoteReply With Quote
Old 07-25-2021, 09:28 PM #35563
Bagels's Avatar
Bagels Bagels is offline
Bagels is on a distinguished road
Bagels's Avatar
More pictures as requested.
Bagels is offline   Reply With QuoteReply With Quote
Old 07-25-2021, 11:31 PM #35564
maelo's Avatar
maelo maelo is offline
Real Name: Franqui
maelo is on a distinguished road
maelo's Avatar
Real Name: Franqui
Talking I'm back with 2 more 4th generations
Feels good to be back.
What did you do with your 4runner today?-img_20210413_100050_525-jpg
maelo is offline   Reply With QuoteReply With Quote
Old 07-25-2021, 11:40 PM #35565
maelo's Avatar
Real Name: Franqui
maelo's Avatar
Real Name: Franqui
Exclamation More of my 4th gens
I want them all.💰💵💸🔩⚙
What did you do with your 4runner today?-img_20210724_155545_383-jpg
4runner , 4th gen , mods
My 4runner got smacked today! Rez90 4th Gen T4Rs 11 10-09-2013 05:03 PM
Weird Problem today with my 4Runner today. myT4RisGREEN 3rd gen T4Rs 9 05-18-2013 10:07 PM
Bought my first 4runner today! mechagouki New Members 2 09-18-2010 10:03 PM
I got my 4Runner today NavyChiefnMD 5th gen T4Rs 5 12-17-2009 01:12 PM
Feedback Buttons provided by Advanced Post Thanks / Like (Lite) - vBulletin Mods & Addons Copyright © 2021 DragonByte Technologies Ltd.
