Thread Tools Rating: Thread Rating: 9 votes, 4.67 average. Display Modes
Old 10-20-2021, 11:15 AM #35851
Romeo Foxtrot Romeo Foxtrot is offline
Romeo Foxtrot is on a distinguished road
The fan clutch went out on my Gen4 4.0 V6. I picked up a Duralast one from Auto Zone. $90
Replacement wasn't that tough.
Drop the skid plate.
Drain the radiator.
Slide the clamp off on the upper radiator hose on the thermostat housing side.
Pull the hose from the thermostat housing and move it out of the way.
Using a 12mm wrench remove the 4 nuts securing the fan clutch to the pully.
Remove the fan/fan clutch assy.
It takes some fanageling and a few cuss words, but you can work it out past the fan shroud on the passenger's side.
Once you have it out, using a 10mm deep socket, remove the 4 nuts securing the fan to the fan clutch. Remove the old fan clutch.
Install the new fan clutch in the same orientation with the fan that the old clutch had. I used some blue loctite on the threads before I tightened the nuts.
Install in the reverse order.
I reused my coolant as it was pretty fresh.
All went well. My skid plate had some janky bolts holding it on. a couple of them were almost stripped out. I'm going to chase the threads with a tap and get new bolts and reinstall the skid plate this weekend.
Love my 4th Gen! Best vehicle I have ever owned!
Romeo Foxtrot is offline   Reply With QuoteReply With Quote
Old 10-23-2021, 12:36 PM #35852
Vinyl303 Vinyl303 is online now
Real Name: Jeff N.
Vinyl303 is on a distinguished road
Real Name: Jeff N.
Well after months of putting it off, I’ve ordered a new pair of the bilstein 5100 adjustable height front dampers for the struts to replace the decade old ones on there right now. With the fj coils in front, I’ll have them set to the 3rd notch up from bottom. I think that will set it to 2.25-2.5” lift vs stock height without the fj coils. A month or so from now I’ll order rear shocks and new rear coils (going with the bilstein 5160s in rear, and +400 pound coils) so rear will be at +2.25” from stock. I’m really looking forward to this upgrade/maintenance because its getting really old having such floppy ride quality on my commute.
2004 Limited 4WD | FJ Coil Swap | 10 y/o worn out Bilstein 5100 | 265/70/17 Cooper all-terrains | Chinese Bull Bar | APF Trail lights
Vinyl303 is online now   Reply With QuoteReply With Quote
Old 10-23-2021, 03:44 PM #35853
Skiian's Avatar
Skiian Skiian is offline
Skiian will become famous soon enough Skiian will become famous soon enough
Skiian's Avatar
Got a LFD Cross bar to try out for my kayak mount before I order a few more. Looks good and the fitment was on point for the stock rack.
04 4Runner Limited V8 4WD - Toyotec Springs w/Bilstein 5100s and Icon Rear Springs w/Bilstein 5100s - MK6 17x8 -10 275/70 ST Maxx's - Victory4x4 Wench Bumper - LED Interior Swap - Pioneer Bass Upgrade -
Skiian is offline   Reply With QuoteReply With Quote
Old 10-24-2021, 02:54 PM #35854
dldsm7 dldsm7 is offline
dldsm7 is on a distinguished road
Installed a tow hitch on my SR5 today! First weekend with it and already a project!
dldsm7 is offline   Reply With QuoteReply With Quote
Old 10-24-2021, 09:55 PM #35855
Bluesky 07's Avatar
Bluesky 07 Bluesky 07 is offline
Real Name: Russell (OB #9908)
Bluesky 07 is a splendid one to behold Bluesky 07 is a splendid one to behold Bluesky 07 is a splendid one to behold Bluesky 07 is a splendid one to behold Bluesky 07 is a splendid one to behold Bluesky 07 is a splendid one to behold Bluesky 07 is a splendid one to behold
Bluesky 07's Avatar
Had a great day at 5313 Off-Road Park in Calhoun, GA with the Georgia 4Runners FB group. My 4th Gen is in the back on the left.
I donít know how well these inclinometer apps work but this was definitely the most interesting trail moment of the day!
Bluesky 07 is offline   Reply With QuoteReply With Quote
Old 10-25-2021, 09:50 AM #35856
kcdehart's Avatar
kcdehart kcdehart is offline
Real Name: Kevin
kcdehart is a jewel in the rough kcdehart is a jewel in the rough kcdehart is a jewel in the rough kcdehart is a jewel in the rough
kcdehart's Avatar
Real Name: Kevin
Getting my old girl back from the shop today! The 4.0 headgasket went kaput right around 200k miles (though I suspect it's had a small leak for the last 40k or so that I've had it...).
They did a headgasket job, decked the heads, clearanced the valves, replaced the timing system, and replaced the oil pump as it had a ton of play. They also replaced my exhaust manifold studs - fixing an exhaust leak in the process. Used all OEM parts and are giving a 2 year parts/labor warranty on anything they touched. You don't wanna know what it cost me, but let's just say I won't be getting rid of this thing anytime soon. Gotta get my money's worth
'04 4Runner - Build Thread | '05 CBR 600RR & 1000RR - The slow vehicles ;)
kcdehart is offline   Reply With QuoteReply With Quote
Old 10-26-2021, 10:45 AM #35857
aemravan aemravan is offline
aemravan is a splendid one to behold aemravan is a splendid one to behold aemravan is a splendid one to behold aemravan is a splendid one to behold aemravan is a splendid one to behold aemravan is a splendid one to behold aemravan is a splendid one to behold
Finished mounting my custom carbon fiber snorkel (3 weeks of sanding and fabricating lol)
aemravan is offline   Reply With QuoteReply With Quote
Old 10-28-2021, 10:01 AM #35858
Bluesky 07's Avatar
Bluesky 07's Avatar
Changed the oil but there's more to the story. Coincidentally, a ton of maintenance came due at ~220K miles. Since September, I've:
- installed new plugs
- refilled the radiator with fresh coolant
- done an ATF exchange with WS and added a transmission oil cooler
- cleaned the cabin & engine air filters
- flushed the power steering with fresh ATF
- changed the diff & transfer case oil
- lubricated the propeller shaft
- rotated and balanced the tires
Up next are installing an RCI transfer case skid and SS brake lines.
This is far and away the best vehicle I've ever owned. I've made some great memories with it and feel like the best is still to come.
Old 10-31-2021, 10:08 PM #35859
j4run j4run is offline
j4run is on a distinguished road
Wow! That is one fine looking snorkel!
--o-------o-
2008 4R Limited. Mostly stock and runing great!
j4run is offline   Reply With QuoteReply With Quote
Old 11-01-2021, 02:23 AM #35860
GBagwell's Avatar
GBagwell GBagwell is offline
GBagwell will become famous soon enough
GBagwell's Avatar
Decided to replace the upper control arms to gain a bit of caster. After adding the Dobinsons springs and shocks and gaining close to 3 inches in the front, it turned out to be a necessary addition. Happy with the way the install went, just a couple hours of work. Helps that I donít have much in the way of rust issues after 18 years.
What did you do with your 4runner today?-ba6f228e-9a2e-48ae-9e9f-d3a02dbfaf50-jpg
86 4Runner, 91 4Runner, 97 4Runner Limited, 2003 4Runner V8 4x4 Limited (current ride).
GBagwell is offline   Reply With QuoteReply With Quote
Old 11-01-2021, 11:02 AM #35861
kcdehart's Avatar
Real Name: Kevin
kcdehart's Avatar
Real Name: Kevin
My headlights were having some clear coat issues - they got noticeably worse after sitting at a shop for a month, as well as some specks that wouldn't come off. So I picked up a Meguiar's headlight restoration kit and was pleasantly surprised by the results. I did end up using a drill to polish the headlights with the pads that they provide. For giggles, I also did the fog lights which came out *very* clear and seem to be staying that way so far. They've been cloudy for years, so I'm glad to have em back. I liked the spray-on clearcoat. Applied nicely and dried quickly.
Didn't take any before pics, but here's the after The clear was completely peeled off of the top of that headlight with a jagged horizontal line across the middle showing the separation. The sanding took care of that and you can't tell at all now.
Old 11-01-2021, 01:12 PM #35862
phatcheeks's Avatar
phatcheeks phatcheeks is offline
phatcheeks has a spectacular aura about phatcheeks has a spectacular aura about phatcheeks has a spectacular aura about
phatcheeks's Avatar
Installed some retarded exhaust cam gears from @Mightytacoman on the Tacoma forums, and a XTP plenum spacer. Idles smoother and can feel a torque increase. Engine is just overall smoother and I don't need to give as much gas to accelerate as I used to. My MPGs also increase by at least 1 if not more. Still need to drive it more for ECU to re learn.
Install is pretty straightforward but it just really time consuming as you have to remove a bunch of wiring. Definitely worth the upgrade for our poor little v6 engines.
04 V6 4x4. Eibach Pro Truck Shocks, OME 885, Icon 2" Springs. JBA UCA. 295/70/17 Cooper Evolution MT. Spartan rear locker. PCK. Taco bumper
phatcheeks is offline   Reply With QuoteReply With Quote
Old 11-01-2021, 03:17 PM #35863
Hi-desertT4R's Avatar
Hi-desertT4R Hi-desertT4R is online now
Real Name: Matt
Hi-desertT4R will become famous soon enough
Real Name: Matt
A few small ticket items. Greased drive shafts and upper control arms. Finally did the TPMS mod after watching that light blink for about a year. Also did the axle vent mod even though there are no water crossings anywhere near me there is a chance for flash floods.
2007 Titanium SR5 4WD. Toytec superflex HD rears, Icon 2.0 shocks, Toytec adjustable track bar, extended SS brake lines and bump stop spacers. Dobinsonís lower trailing arms. Custom sway bar end links. Toytec front springs, Bilstein 5100 on 3rd groove, JBA ucaís. 1/2Ē UHMW diy body lift. American Racing Baja. 285/70 17 Kenda Klever A/T. Diy BMC. Hcf delete with K&N filter. Running board delete. Auxbeam FT-1 hi/lo. DAC relocate. ottratw switches for 30Ē, 40Ē light bars and KC rear work lights. Yakima mega warrior roof rack, diy shovel and axe mounts.
Hi-desertT4R is online now   Reply With QuoteReply With Quote
Old 11-01-2021, 04:26 PM #35864
toyoman25's Avatar
toyoman25 toyoman25 is offline
toyoman25 is on a distinguished road
toyoman25's Avatar
I spent $$$
Two weeks worth of time but
Front and rear shocks
power steering flush
Front sway bar end links
New intake surge tank
Toyo is my Name and My Ride
toyoman25 is offline   Reply With QuoteReply With Quote
Old 11-01-2021, 04:28 PM #35865
toyoman25's Avatar
toyoman25's Avatar
Do tell more....
4runner , 4th gen , mods
Bought my first 4runner today! mechagouki New Members 4 11-12-2021 01:13 PM
My 4runner got smacked today! Rez90 4th Gen T4Rs 11 10-09-2013 05:03 PM
Weird Problem today with my 4Runner today. myT4RisGREEN 3rd gen T4Rs 9 05-18-2013 10:07 PM
I got my 4Runner today NavyChiefnMD 5th gen T4Rs 5 12-17-2009 01:12 PM
Feedback Buttons provided by Advanced Post Thanks / Like (Lite) - vBulletin Mods & Addons Copyright © 2021 DragonByte Technologies Ltd.
