Originally Posted by Zero0575
I actually considered adding some dielectric grease, and am probably going to - good call!
I got the SRS module out today... not fun! It's supposed to be covered in mud, right? Used one was $80 so rather than trying to salvage this one, I'm replacing with used which will be here in a few days. Anyone know if srs modules need to be programmed?
Never changed an srs module, but I've heard a buddy with a shop mention they do need reprogramming.
I spray some contact cleaner on the airbag sensors too, there should be 8 if I'm not mistaken.
(2 on the front radiator support bracket, 2 under the front seats, 2 on the lower side of the b pillar and 2 on the c pillar but those are shoulder height)
The flood line isn't too bad tho, check the sensors on the front, under the seats and by the b pillar.
good luck
LC Prado 150
4th Gen 4Runner
1GR-FE
OME Springs w Bilstein 5100F&R, Durobumps bumb stops, Toytec 1" BL, Exhaust cam gears with 3° retard, Prado120 Snorkel, AFE Stage 2si, Magnaflow Catback w/ dual side exit 285/70R17 Dynapros MT Energy Suspension Bushings all around
